23-80361
23-80361
    BELDEN
    E DROP WIRE CLAMP 1PR.
23-80361 数据手册
A BELDEN BRAND ® Diamond Drop Hardware Drop Wire Clamps for CATV and Telephone Cable Universal Messenger Cable Drop Wire Clamp •• Permits cable to “float” free, fully protected from strain and chafing. •• Drop clamp for the suspension of a messengered drop cable between the pole, midspan and house. •• For use with RG59, RG6 and other cables •• Stainless steel bail wire and aluminum body. Installation: Part Number Description SC02MFA-SS Universal Messenger Drop Wire Clamp 1. Begin separation of the messenger wire from the cable using the end-edge of the SC02MFA-SS Drop Clamp. Note: Never use a knife or other sharp tool to separate messenger and cable. 2. Fit the cable and messenger wire into the SCO2MFASS Drop Clamp as shown, so that the Clamp Bail is between the two. 3. Grasp the separated end of the messenger and cable with one hand and grip the Clamp Body, as shown, with your other hand. Then, pull the SC02MFA-SS back, in a straight line, separating the length of messenger wire needed to make the wrap; about 15 to 18-inches. 4. Pull the messenger wire around the center of the bearing surface as shown, toward the rear or dropside of the Clamp. Note: If at the house end of the drop, this will be done while tensioning or “sagging” the drop. 5. Pass the messenger wire through the “L” Slots and begin the wrap about the SC02MFA-SS body, as shown. Inner Pack Outer Pack -- 125 1 2 3 4 5 6. Continue the messenger wire wrap for two full turns. 7. Pass the messenger wire through the “L” Slot, as shown, to the drop-side of the SC02MFA-SS and cut the excess wire away, or ground it to the strand. Note: For drop cable with larger messenger wire, one wrap is sufficient. Wrap the end of the wire around the end of the SC02MFA-SS and bring it back up the “L” Slots, then cut away the excess, or ground it to the strand. www.ppc-online.com 6 A BELDEN BRAND 6 7 Customer Support: 800.800.6652 Drop Hardware ® Diamond Drop Hardware Drop Wire Clamps for CATV and Telephone Cable "B" Drop Wire Clamp •• Used to support both ends of telephone drop, at strand and building. •• Suitable for 1-2 pair .200” max. height and .410’ max. width. •• 6 pair version: .300” max. height and .500" max. width. •• Stainless steel bailwire on all versions. •• Special Packages available. Please check with your PPC/Belden Representative. Part Number Description Material Pair Shim Type Inner Pack Outer Pack 23-44441 "B" Drop Wire Clamp Aluminum 1-2 Serrated -- 500 23-44444 "B" Drop Wire Clamp (Bell Packaging) Aluminum 1-2 Serrated 25 500 23-44445 "B" Drop Wire Clamp Aluminum 1-2 Serrated 2 250 23-82350 "B" Drop Wire Clamp Aluminum 6 Dimpled 1 75 23-82351 "B" Drop Wire Clamp Aluminum 6 Dimpled 25 150 23-88881 "B" Drop Wire Clamp (Bulk Packaging) 1-2 Serrated 25 500 23-88885 "B" Drop Wire Clamp Stainless Steel Stainless Steel 1-2 Serrated 2 250 Installation: 1. Lay cable in shell. 2. Place shim on top of cable with raised embossings against cable. 3. Insert wedge in shell (on top of shim) and pull to engage. (Small end of wedge should be initially engaged in track of large end of shell). 4. Place bailwire on “B” drop wire hook (ram’s horn)with wedge loose. Pull drop wire through clamp until proper sidewalk/alley clearance is achieved. 5. Grasp clamp (bailwire still on ram’s horn) and pull tightly to secure. Customer Support: 800.800.6652 www.ppc-online.com 7 A BELDEN BRAND A BELDEN BRAND ® Diamond Drop Hardware Span Clamps "Q" Span Clamp •• Provides drop wire take offs at mid-span. •• Steel components mechanically galvanized ASTM B695. Part Number Description 27-00185 "Q" Span Clamp Span Clamp for P3 2700185-LA "Q" Cable w/Messenger Material Clamp Range PigTail Diameter Inner Outer Pack Pack Steel 1/4"-7/16" 1/4" -- 100 Plates - Aluminum Pigtail - Steel
23-80361 价格&库存
很抱歉,暂时无法提供与“23-80361”相匹配的价格&库存,您可以联系我们找货
