Part Number: 4731ANH
12 GHz Coax, 4K UHD Precision Video Cable, RG-11/U Type, 75 Ohm, 14
AWG Solid
Product Description
12 GHz Coax, 4K UHD Precision Video Cable, RG-11U Coax, 14 AWG solid .064" silver-plated copper conductor, gas-injected foam HDPE insulation,
Duofoil® bonded to core + tinned copper braid shield (95% coverage) + bonded to jacket, LSZH jacket.
Technical Specifications
Product Overview
Environmental Space:
LSZH
Suitable Applications:
SMPTE 2082-1 12 Gb/s UHDTV, SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080p
Physical Characteristics (Overall)
Conductor
AWG Stranding
14
Solid
Material
Nominal Diameter No. of Coax
SPC - Silver Plated Copper 0.064 in
Conductor Size:
1
14 AWG
Insulation
Material
Nominal Diameter
Gas-injected FHDPE - Foam High Density Polyethylene 0.280 in
Outer Shield Material
Type Layer
Material
Material Trade Name
Coverage [%]
Tape 1
Aluminum/Polyester/Aluminum Bonded Duofoil® (Bonded to Dielectric)
100.0 %
Braid 2
TC - Tinned Copper
95.0 %
Tape 3
Aluminum/Polyester
Bonded Beldfoil® with shorting fold (bonded to jacket)
Outer Jacket Material
Material
Nominal Diameter
LSZH - Low Smoke Zero Halogen 0.400 in
Electrical Characteristics
Conductor DCR
Nominal Conductor DCR Outer Conductor DCR
2.5 Ohm/1000ft
1.5 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Shield
15.5 pF/ft
Inductance
Nominal Inductance
0.097 µH/ft
Impedance
Nominal Characteristic Impedance
75 Ohm
Return Loss (RL)
Frequency [MHz]
Minimum Return (RL)
5 MHz - 1600 MHz
23 dB
1600 MHz - 4500 MHz
21 dB
4500 MHz - 12000 MHz 15 dB
High Frequency (Nominal/Typical)
Frequency [MHz] Nom. Insertion Loss
1 MHz MHz
0.16 dB/100ft
3.58 MHz MHz
0.30 dB/100ft
5 MHz MHz
0.34 dB/100ft
6 MHz MHz
0.37 dB/100ft
7 MHz MHz
0.39 dB/100ft
10 MHz MHz
0.45 dB/100ft
12 MHz MHz
0.49 dB/100ft
25 MHz MHz
0.67 dB/100ft
55 MHz MHz
0.95 dB/100ft
67.5 MHz MHz
1.04 dB/100ft
71.5 MHz MHz
1.07 dB/100ft
88.5 MHz MHz
1.17 dB/100ft
100 MHz MHz
1.24 dB/100ft
135 MHz
1.41 dB/100ft
143 MHz
1.45 dB/100ft
180 MHz
1.61 dB/100ft
270 MHz
1.96 dB/100ft
360 MHz
2.27 dB/100ft
540 MHz
2.81 dB/100ft
720 MHz
3.27 dB/100ft
750 MHz
3.34 dB/100ft
1000 MHz
3.89 dB/100ft
1500 MHz
4.83 dB/100ft
2000 MHz
5.65 dB/100ft
2250 MHz
6.02 dB/100ft
3000 MHz
7.07 dB/100ft
4500 MHz
8.81 dB/100ft
6000 MHz
10.45 dB/100ft
12000 MHz
16.39 dB/100ft
Delay
Nominal Delay Nominal Velocity of Propagation (VP) [%]
1.2 ns/ft
85.0 %
Voltage
UL Voltage Rating
300 V RMS
Electrical Characteristics Notes:
Return Loss: Fixed bridge and termination
Temperature Range
Operating Temp Range:
-30°C To +75°C
Mechanical Characteristics
UV Resistance:
Yes
Bulk Cable Weight:
87 lbs/1000ft
Max Recommended Pulling Tension:
145 lbs
Min Bend Radius/Minor Axis:
4.0 in
Standards
RG Type:
11/U Type
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/11/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive Compliance:
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2016-04-01
CA Prop 65 (CJ for Wire & Cable):
Yes
Suitability
Suitability - Aerial:
Yes - Black only, when supported by messenger wire
Suitability - Burial:
No
Suitability - Hazardous Locations:
No
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes - Black only
Plenum/Non-Plenum
Plenum (Y/N):
No
Part Number
Variants
Item #
Color
Length
4731ANH G751000 Aqua
1,000 ft
4731ANH 0101000
Black
1,000 ft
4731ANH 0061000
Light Blue 1,000 ft
4731ANH N3U1000 Mil Green 1,000 ft
4731ANH 0071000
Violet
1,000 ft
Product Notes
Notes:
Print legend includes sequential footage marks.
History
Update and Revision:
Revision Number: 0.11 Revision Date: 07-11-2019
© 2019 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“4731ANH 0101000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+55.509351000+7.20230
