Part Number: 4855R
12 GHz Coax, 4K UHD Precision Video Cable, RG-59 Mini, 75 Ohm, 23 AWG
Solid, CMR
Product Description
12 GHz Coax, 4K UHD Precision Video Cable, RG-59 Mini, 75 Ohm, 23 AWG solid .023" silver plated copper conductor, gas-injected foam HDPE insulation,
Duofoil® bonded to the core + tinned copper braid shield (95% coverage), PVC jacket.
Technical Specifications
Product Overview
Environmental Space:
Indoor/Outdoor
Suitable Applications:
SMPTE 2082-1 12 Gb/s UHDTV, SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080P
Physical Characteristics (Overall)
Conductor
AWG Stranding
23
Solid
Material
Nominal Diameter No. of Coax
SPC - Silver Plated Copper 0.023 in
Conductor Size:
1
23 AWG
Insulation
Material
Nominal Diameter
Gas-injected FHDPE - Foam High Density Polyethylene 0.102 in
Outer Shield Material
Type Layer
Material
Material Trade Name
Coverage [%]
Tape 1
Aluminum/Polyester/Aluminum Bonded Duofoil® (Bonded to Dielectric) 100 %
Braid 2
TC - Tinned Copper
Outer Jacket Material
Material
Nominal Diameter
PVC - Polyvinyl Chloride 0.159 in
Electrical Characteristics
Conductor DCR
Nominal Conductor DCR Outer Conductor DCR
19.7 Ohm/1000ft
3.9 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Shield
16.3 pF/ft
Inductance
Nominal Inductance
0.107 µH/ft
Impedance
Nominal Characteristic Impedance
75 Ohm
95 %
Return Loss (RL)
Frequency [MHz]
Minimum Return (RL)
5 MHz - 1600 MHz
23 dB
1600 MHz - 4500 MHz
21 dB
4500 MHz - 12000 MHz 15 dB
High Frequency (Nominal/Typical)
Frequency [MHz] Nom. Insertion Loss
1 MHz
0.39 dB/100ft
3.58 MHz
0.78 dB/100ft
5 MHz
0.92 dB/100ft
6 MHz
1 dB/100ft
7 MHz
1.08 dB/100ft
10 MHz
1.2 dB/100ft
12 MHz
1.3 dB/100ft
25 MHz
1.8 dB/100ft
55 MHz
2.6 dB/100ft
67.5 MHz
2.83 dB/100ft
71.5 MHz
2.93 dB/100ft
88.5 MHz
3.22 dB/100ft
100 MHz
3.39 dB/100ft
135 MHz
3.84 dB/100ft
143 MHz
4.00 dB/100ft
180 MHz
4.41 dB/100ft
270 MHz
5.44 dB/100ft
360 MHz
6.34 dB/100ft
540 MHz
7.85 dB/100ft
720 MHz
9.09 dB/100ft
750 MHz
9.28 dB/100ft
1000 MHz
10.8 dB/100ft
1500 MHz
13.2 dB/100ft
2000 MHz
15.3 dB/100ft
2250 MHz
16.3 dB/100ft
3000 MHz
19.0 dB/100ft
4500 MHz
23.6 dB/100ft
6000 MHz
27.7 dB/100ft
12000 MHz
41.2 dB/100ft
Delay
Nominal Delay Nominal Velocity of Propagation (VP) [%]
1.24 ns/ft
82 %
Voltage
UL Voltage Rating
300 V RMS
Electrical Characteristics Notes:
Return Loss: Fixed bridge and termination
Other Electrical Characteristic 2:
Percent test
Temperature Range
UL Temp Rating:
75°C
Operating Temp Range:
-30°C To +75°C
Mechanical Characteristics
UV Resistance:
Yes
Bulk Cable Weight:
17 lbs/1000ft
Max Recommended Pulling Tension:
40 lbs
Min Bend Radius/Minor Axis:
1.6 in
Standards
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
CPR Euroclass:
Eca
RG Type:
Mini 59/U Type
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/96/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01
CA Prop 65 (CJ for Wire & Cable):
Yes
Suitability
Suitability - Aerial:
Yes - Black only, when supported by messenger wire
Suitability - Burial:
No
Suitability - Hazardous Locations:
No
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes - Black only
Flammability, LS0H, Toxicity Testing
UL Flammability:
UL1666 Vertical Shaft
CSA Flammability:
FT4
ISO/IEC Flammability:
IEC 60332-1-2
UL voltage rating:
300 V RMS
Plenum/Non-Plenum
Plenum (Y/N):
No
Part Number
Variants
Item #
Color
UPC
Length Footnote
4855R 0101000
Black
612825390572 1,000 ft
4855R 0105000
Black
612825390589 5,000 ft C Z
4855R 0061000
Blue, Light 612825395362 1,000 ft
4855R N3U1000 Mil Green
612825395355 1,000 ft
4855R 0031000
Orange
612825395249 1,000 ft
4855R 0071000
Purple
612825395263 1,000 ft
4855R 0021000
Red
612825395232 1,000 ft
4855R 0041000
Yellow
612825395256 1,000 ft
Footnote:
C - CRATE REEL PUT-UP.
Footnote:
Z - FINAL PUT-UP MAY VARY (= OR -) 10% FOR SPOOLS OR REELS AND (+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Product Notes
Notes:
Print legend includes sequential footage marks.
History
Update and Revision:
Revision Number: 0.203 Revision Date: 07-11-2019
© 2019 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
