Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
5220FL Multi-Conductor - Commercial Applications - 2 Conductors Cabled
For more Information
please call
1-800-Belden1
General Description:
Fire Alarm Cable, Riser-FPLR, 2-16 AWG solid bare copper conductors with polyolefin insulation, Overall
Beldfoil® shield, PVC jacket with ripcord
Usage (Overall)
Suitable Applications:
Fire Protection, Alarm, Signal, Monitor/Detection, Audio Circuits, Control Circuits, Initiating Circuits,
Notification Circuits
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
2
16
Solid
BC - Bare Copper
Total Number of Conductors:
2
Insulation
Insulation Material:
Insulation Material Wall Thickness (in.)
PP - Polypropylene 0.007
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Outer Shield Material
Beldfoil®
Coverage (%)
Aluminum Foil-Polyester Tape 100
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
24
Solid
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.017
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Cabling Lay Length & Direction:
Length (in.) Twists (twist/ft)
2.500
4.800
Overall Cabling Color Code Chart:
Number Color
1
Black
2
Red
Overall Nominal Diameter:
0.170 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +75°C
UL Temperature Rating:
75°C
Bulk Cable Weight:
24 lbs/1000 ft.
Max. Recommended Pulling Tension:
75 lbs.
Min. Bend Radius/Minor Axis:
1.750 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
FPLR
NEC Articles:
760
Page 1 of 3
01-05-2017
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
CSA Flame Test:
FT4
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Plenum Number:
6220FL
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/ft)
0.140
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
65.500
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
118.000
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
3.9
Nominal Outer Shield DC Resistance:
16.900
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Description
Current
10C Temperature Rise 6.3 Amps per conductor @ 25°C
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
5220FL D151000
1,000 FT
25.000 LB
BLUE
Notes
Item Desc
5220FL 002A1000
1,000 FT
27.000 LB
RED
5220FL 0021000
1,000 FT
25.000 LB
RED
5220FL 004U1000
1,000 FT
26.000 LB
YELLOW
2 #16 PP FS FRPVC
5220FL 0041000
1,000 FT
25.000 LB
YELLOW
2 #16 PP FS FRPVC
5220FL 0091000
1,000 FT
25.000 LB
WHITE
2 #16 PP FS FRPVC
2 #16 PP FS FRPVC
2 #16 PP FS FRPVC
C
2 #16 PP FS FRPVC
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 3
Revision Date: 08-20-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
Page 2 of 3
01-05-2017
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“5220FL D151000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+3.216541000+0.40352
