Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
73604WS Multi-Conductor - 600V Shielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles
For more Information
please call
1-800-Belden1
General Description:
16 AWG stranded (26x30) bare copper conductors, PVC insulation, oil-resistant PVC inner jacket, tinned
copper braid shield, 85% coverage, oil-resistant overall PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material Dia. (in.)
3
16
26x30
BC - Bare Copper
0.060
Total Number of Conductors:
4
Ground Wire
Ground Wire (Y/N):
Y
Ground Wire AWG:
16
Ground Wire Stranding:
26X30
Ground Wire Conductor Material:
BC - Bare Copper
Ground Wire Insulation Material:
PVC - Polyvinyl Chloride
Insulation
Insulation Material
Wall Thickness (in.) Dia. (in.)
PVC - Polyvinyl Chloride 0.022
0.104
Insulation Color Code Chart:
Color
Description
Black
Individually Numbered
Yellow/Green Ground
Inner Jacket
Inner Jacket Material:
Nom Wall (in.) Nom. Dia. (in.)
PVC - Polyvinyl Chloride 0.030
0.318
Outer Shield
Outer Shield Material:
Outer Shield Material Coverage (%)
TC - Tinned Copper
85.000
Outer Shield Separator Material:
Tissue Tape, 25% Overlap, Min.
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.035
Overall Cable
Overall Nominal Diameter:
0.416 in.
Mechanical Characteristics (Overall)
Storage Temperature Range:
-40°C To +90°C
Installation Temperature Range:
Flexing: -5°C To +90°C
Operating Temperature Range:
Bulk Cable Weight:
227 lbs/1000 ft.
Max. Recommended Pulling Tension:
91 lbs.
Min. Bend Radius/Minor Axis:
2.100 in.
Min. Bend/Installation:
2.100 in.
Min. Bend Radius (Continuous Flexing):
2.100 in.
Flex Cycle Rating:
1 Million Flexes
Page 1 of 2
10-02-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
THHN/THWN Singles
AWM Specification:
UL Style 2587 (600 V 90°C)
CSA Specification:
600 V AWM I/II A/B
EU Directive 2011/65/EU (ROHS II):
Yes
Other Specification:
AWM/STYLE 2587, AWM I/II A/B, FT1, VDE 0472, Section 803 Oil Test, EU Low Voltage Directive
2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California
Proposition 65
Flame Test
CSA Flame Test:
FT1
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/ft)
0.180
Nom. Capacitance Cond. to Other Cond. & Ground:
Description
Freq. (kHz) Capacitance (pF/ft)
Nom. Cond. to Cond 1.000
51.000
Nom. Ground.
92.000
1.000
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
4.100
Nominal Outer Shield DC Resistance:
2.480
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
73604WS 008100
100 FT
28.200 LB
GRAY
Notes
Item Desc
16AWG 26/30 4C SHIELDED
73604WS 0081000
1,000 FT
241.000 LB
GRAY
73604WS 008500
500 FT
122.500 LB
GRAY
Revision Number: 0
Revision Date: 09-27-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
10-02-2017
很抱歉,暂时无法提供与“73604WS 008500”相匹配的价格&库存,您可以联系我们找货
