7731A.00305
7731A.00305
    BELDEN
    BELDEN - 7731A.00305 - Coaxial Cable, RG11, 14 AWG, 75 ohm
7731A.00305 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7731A Coax - Low Loss Serial Digital Coax For more Information please call 1-800-Belden1 General Description: RG-11/U type, 14 AWG solid .064" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® + tinned copper braid shield (95% coverage), PVC jacket. Usage (Overall) Suitable Applications: SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080p Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 14 Solid BC - Bare Copper 1.6256 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) Gas-injected FHDPE - Foam High Density Polyethylene 7.112 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 10.160 mm Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Bulk Cable Weight: 129.473 Kg/Km Max. Recommended Pulling Tension: 644.989 N Min. Bend Radius/Minor Axis: 101.600 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 11/U Page 1 of 3 07-21-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7731A Coax - Low Loss Serial Digital Coax RG Type: 11/U Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black only. Suitability - Aerial: Yes - Black only, when supported by messenger wire. Suitability - Burial: No Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 7732A Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.318257 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 52.496 Nominal Velocity of Propagation: VP (%) 85 Nominal Delay: Delay (ns/m) 3.97001 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 8.2025 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 4.9215 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1.000 0.525 3.580 0.951 5.000 1.116 7.000 1.280 10.000 1.509 67.500 3.445 71.500 3.576 88.500 3.970 100.000 4.200 135.000 4.823 143.000 4.954 180.000 5.545 270.000 6.464 360.000 7.579 540.000 9.416 720.000 11.155 750.000 11.319 800.000 11.812 1000.000 13.518 1500.000 16.733 2000.000 19.817 2250.000 21.097 3000.000 25.034 4500.000 31.366 6000.000 37.830 Page 2 of 3 07-21-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7731A Coax - Low Loss Serial Digital Coax Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: TDR Impedance: 75 +/- 3 Ohms Other Electrical Characteristic 2: Return Loss: Fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5.000 1600.000 23.000 1600.000 4500.000 21.000 4500.000 6000.000 15.000 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 6 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7731A N3U1000 1,000 FT 92.000 LB GREEN, MIL C #14 PE/GIFHDLDPE SH FRPVC 7731A N3U4000 4,000 FT 376.000 LB GREEN, MIL C #14 PE/GIFHDLDPE SH FRPVC 7731A 0011000 1,000 FT 92.000 LB BROWN 7731A 0014000 4,000 FT 376.000 LB BROWN C #14 PE/GIFHDLDPE SH FRPVC 7731A 0021000 1,000 FT 92.000 LB RED C #14 PE/GIFHDLDPE SH FRPVC 7731A 0024000 4,000 FT 376.000 LB RED C #14 PE/GIFHDLDPE SH FRPVC 7731A 0031000 1,000 FT 92.000 LB ORANGE 7731A 0034000 4,000 FT 376.000 LB ORANGE 7731A 0041000 1,000 FT 92.000 LB YELLOW 7731A 0044000 4,000 FT 376.000 LB YELLOW 7731A 0061000 1,000 FT 92.000 LB BLUE, LIGHT 7731A 0064000 4,000 FT 376.000 LB BLUE, LIGHT C #14 PE/GIFHDLDPE SH FRPVC 7731A 0071000 1,000 FT 92.000 LB VIOLET C #14 PE/GIFHDLDPE SH FRPVC 7731A 0074000 4,000 FT 376.000 LB VIOLET C #14 PE/GIFHDLDPE SH FRPVC 7731A 0081000 1,000 FT 92.000 LB GRAY 7731A 0084000 4,000 FT 376.000 LB GRAY 7731A 0091000 1,000 FT 92.000 LB WHITE 7731A 0094000 4,000 FT 376.000 LB WHITE C #14 PE/GIFHDLDPE SH FRPVC 7731A 0101000 1,000 FT 92.000 LB BLACK C #14 PE/GIFHDLDPE SH FRPVC 7731A 0104000 4,000 FT 376.000 LB BLACK C #14 PE/GIFHDLDPE SH FRPVC 7731A 010500 500 FT 46.500 LB BLACK C #14 PE/GIFHDLDPE SH FRPVC #14 PE/GIFHDLDPE SH FRPVC #14 PE/GIFHDLDPE SH FRPVC C #14 PE/GIFHDLDPE SH FRPVC #14 PE/GIFHDLDPE SH FRPVC C #14 PE/GIFHDLDPE SH FRPVC #14 PE/GIFHDLDPE SH FRPVC #14 PE/GIFHDLDPE SH FRPVC C #14 PE/GIFHDLDPE SH FRPVC #14 PE/GIFHDLDPE SH FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 9 Revision Date: 06-17-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 07-21-2016
7731A.00305 价格&库存
很抱歉,暂时无法提供与“7731A.00305”相匹配的价格&库存,您可以联系我们找货
