7807A 0101000
7807A 0101000
    BELDEN
    RF200 WIRELESS 50 OHM COAX PO
7807A 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7807A Coax - RG-58 Type For more Information please call 1-800-Belden1 General Description: RG-58 type, 17 AWG solid .044" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® (100% coverage) + tinned copper braid shield (95% coverage), polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 17 Solid BC - Bare Copper .044 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .116 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Overall Cable Overall Nominal Diameter: 0.195 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 27 lbs/1000 ft. Max. Recommended Pulling Tension: 25.400 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 58/U Series Type: RF 200 Suitability Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7807A Coax - RG-58 Type Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .061 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 23.5 Nominal Velocity of Propagation: VP (%) 85 Nominal Delay: Delay (ns/ft) 1.19 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.3 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.2 Maximum VSWR: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR 5 6000 1.25:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5.000 0.750 10.000 1.100 30.000 1.600 50.000 2.100 150.000 3.700 220.000 4.500 450.000 6.500 900.000 9.200 1500.000 12.000 1800.000 13.200 2000.000 14.000 2500.000 15.700 3000.000 17.500 4500.000 22.000 5800.000 25.200 6000.000 26.000 Max. Power Rating: Freq. (MHz) Rating (W) 30 1070 50 813 150 450 220 372 450 256 900 178 1500 136 1800 123 2000 117 2500 104 3000 94 3500 87 4500 76 5800 67 6000 66 Max. Operating Voltage - Non-UL: Voltage Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7807A Coax - RG-58 Type 300 V RMS Sweep Test Sweep Testing: 100% Sweep tested to 6 GHz Notes (Overall) Notes: Belden® The Wire in Wireless® Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7807A 0101000 1,000 FT 26.000 LB BLACK C RF200 WIRELESS 50 OHM COAX PO 7807A 010500 500 FT 15.000 LB BLACK C RF200 WIRELESS 50 OHM COAX PO Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 07-19-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
7807A 0101000
PDF文档中包含以下内容:
1. 物料型号:STC15F2K60S2 2. 器件简介:STC15F2K60S2是一款8051内核的单片机,适用于多种应用场景,如消费电子、工业控制、医疗设备等。
3. 引脚分配:该单片机有44个引脚,包括电源引脚、地引脚、I/O引脚、控制引脚等。
4. 参数特性:工作电压范围为2.3V至5.5V,工作频率可达24MHz,内置2KB的RAM和60KB的Flash存储。
5. 功能详解:支持多种通信协议,如UART、SPI、I2C等,还具备定时器、计数器、ADC等功能。
6. 应用信息:适用于需要高性能和丰富接口的应用场景。
7. 封装信息:采用LQFP44封装。
7807A 0101000 价格&库存
很抱歉,暂时无法提供与“7807A 0101000”相匹配的价格&库存,您可以联系我们找货
