Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
7806R Coax - RG-58 Type
For more Information
please call
1-800-Belden1
General Description:
RG-58 type, 19 AWG solid .037" bare copper conductor, gas-injected foam HDPE insulation, Duofoil®
(100% coverage) + tinned copper braid shield (90% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
1
19
Solid
BC - Bare Copper
.037
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .110
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Duofoil®
2
Coverage (%)
Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100
Braid TC - Tinned Copper
90
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Nominal Diameter:
0.195 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +75°C
Bulk Cable Weight:
27 lbs/1000 ft.
Max. Recommended Pulling Tension:
40 lbs.
Min. Bend Radius/Minor Axis:
1.750 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
58/U
Series Type:
RF 195
Page 1 of 3
08-26-2016
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
CSA Flame Test:
FT4
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
.064
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
24.3
Nominal Velocity of Propagation:
VP (%)
77
Nominal Delay:
Delay (ns/ft)
1.320
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
7.6
Nominal Outer Shield DC Resistance:
4.2
Maximum VSWR:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR
5
6000
1.25:1
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
5.000
0.750
10.000
1.000
30.000
2.000
50.000
2.500
150.000
4.000
220.000
4.900
450.000
7.100
900.000
10.300
1500.000
13.700
1800.000
15.200
2000.000
16.100
2500.000
18.300
3000.000
20.500
4500.000
26.500
5800.000
31.200
6000.000
32.000
Max. Power Rating:
Freq. (MHz) Rating (W)
30
890
50
694
150
403
220
336
450
231
900
162
1500
124
1800
113
2000
107
Page 2 of 3
08-26-2016
2500
95
3000
87
3500
80
4500
70
5800
62
6000
61
Max. Operating Voltage - UL:
Voltage
300 V RMS
Notes (Overall)
Notes: 100% Sweep tested. 6 GHz. Belden® The Wire in Wireless®
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
7806R 0101000
1,000 FT
28.000 LB
BLACK
C
RF195 WIRELESS 50OHM COAXFRPVC
7806R 010500
500 FT
16.500 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 7
Revision Date: 08-13-2014
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“7806R 0101000”相匹配的价格&库存,您可以联系我们找货
