Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
7808R Coax - RG-8X Type
For more Information
please call
1-800-Belden1
General Description:
RG-8X type, 15 AWG solid .057" bare copper conductor, gas-injected foam HDPE insulation, Duobond® II
+ tinned copper braid shield (95% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
1
15
Solid
BC - Bare Copper
.057
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .150
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Bonded Duofoil®
2
Coverage (%)
Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100
Braid TC - Tinned Copper
95
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Nominal Diameter:
0.240 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +75°C
UL Temperature Rating:
60°C
Bulk Cable Weight:
40 lbs/1000 ft.
Max. Recommended Pulling Tension:
74 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
8/X
Page 1 of 3
01-05-2017
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
CSA Flame Test:
FT4
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
.060
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
23.0
Nominal Velocity of Propagation:
VP (%)
86
Nominal Delay:
Delay (ns/ft)
1.18
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
3.2
Nominal Outer Shield DC Resistance:
2.8
Maximum VSWR:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR
5
6000
1.25:1
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
5.000
0.580
10.000
0.770
30.000
1.300
50.000
1.600
150.000
2.800
220.000
3.400
450.000
4.900
900.000
7.000
1500.000
9.100
1800.000
10.100
2000.000
10.700
2500.000
12.000
3000.000
13.400
3500.000
14.600
4500.000
16.700
5800.000
19.500
6000.000
19.800
Max. Power Rating:
Freq. (MHz) Rating (W)
30.000
1526.000
50.000
1186.000
150.000
673.000
220.000
556.000
450.000
382.000
900.000
268.000
1500.000
205.000
1800.000
187.000
Page 2 of 3
01-05-2017
2000.000
177.000
2500.000
156.000
3000.000
143.000
3500.000
132.000
4500.000
116.000
5800.000
102.000
6000.000
100.000
Max. Operating Voltage - UL:
Voltage
300 V RMS
Sweep Test
Sweep Testing:
100% Sweep tested to 6 GHz.
Misc. Information (Overall)
Notes (Overall)
Notes: Belden® The Wire in Wireless®
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
7808R 0101000
1,000 FT
44.000 LB
BLACK
C
RF240 WIRELESS 50OHM COAXFRPVC
7808R 010500
500 FT
21.500 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 7
Revision Date: 01-06-2014
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“7808R 0101000”相匹配的价格&库存,您可以联系我们找货
