7810R 0101000
7810R 0101000
    BELDEN
    #10 LDPE/FHDPE SH FRPVC
7810R 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7810R Coax - RG-8 Type For more Information please call 1-800-Belden1 General Description: RG-8 type, 10 AWG solid .108" bare copper-covered aluminum conductor, gas-injected foam HDPE insulation, Duobond® II + tinned copper braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 10 Solid Dia. (in.) BCCA - Bare Copper Covered Aluminum .108 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .285 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.403 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C UL Temperature Rating: 60°C Bulk Cable Weight: 86 lbs/1000 ft. Max. Recommended Pulling Tension: 150 lbs. Min. Bend Radius/Minor Axis: 4 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 8/U Series Type: RF 400 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7810R Coax - RG-8 Type Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) 0.060 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 23.0 Nominal Velocity of Propagation: VP (%) 86 Nominal Delay: Delay (ns/ft) 1.17 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.34 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2 Maximum VSWR: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR 5 6000 1.25:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 30 0.7 50 0.9 150 1.5 220 1.8 450 2.7 900 3.8 1500 5.1 1800 5.6 2000 6.0 2500 6.7 3000 7.5 3500 8.2 4500 9.5 5800 11.1 6000 11.4 Max. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 30 0.70 50 0.93 150 1.58 220 1.94 450 2.83 900 4.06 1500 5.32 1800 5.98 2000 6.35 2500 7.08 Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7810R Coax - RG-8 Type 3000 7.97 3500 8.80 4500 10.23 5800 12.00 6000 12.23 Max. Power Rating: Freq. (MHz) Rating (W) 30 3427 50 2588 150 1428 220 1195 450 817 900 575 1500 437 1800 399 2000 375 2500 334 3000 305 3500 282 4500 247 5800 217 6000 213 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Sweep Test Sweep Testing: 100% Sweep tested to 6 GHz. Misc. Information (Overall) Notes (Overall) Notes: 100% Sweep tested. 6 GHz. Belden® The Wire in Wireless® Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7810R 0101000 1,000 FT 95.000 LB BLACK C #10 LDPE/FHDPE SH FRPVC 7810R 010500 500 FT 47.000 LB BLACK C #10 LDPE/FHDPE SH FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 5 Revision Date: 10-03-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
7810R 0101000 价格&库存
很抱歉,暂时无法提供与“7810R 0101000”相匹配的价格&库存,您可以联系我们找货
