7839A 0601000
7839A 0601000
    BELDEN
    6 PRS #22 FRPP FS PVC
7839A 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7839A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable For more Information please call 1-800-Belden1 General Description: 22 AWG solid tinned copper conductors, twisted pairs, flame retardant polyolefin insulation, overall Beldfoil® shield (100% coverage), 22 AWG solid tinned copper drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 6 22 Solid TC - Tinned Copper .0264 Total Number of Conductors: 12 Insulation Insulation Material: Insulation Material FRPO - Flame Retardant Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 Solid TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.380 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue/White Stripe 2 White/Orange Stripe & Orange/White Stripe 3 White/Green Stripe & Green/White Stripe 4 White/Brown Stripe & Brown/White Stripe 5 White/Gray Stripe & Gray/White Stripe 6 Red/Blue Stripe & Blue/Red Stripe Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 70 lbs/1000 ft. Max. Recommended Pulling Tension: 93.600 lbs. Min. Bend Radius/Minor Axis: 4 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: MPR/CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7839A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Riser Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 100 Nom. Inductance: Inductance (µH/ft) 0.21 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 16 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 29 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.4 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.6 Nom. Attenuation: Attenuation (dB/1000 ft.) 4.3 @ 772 KHz Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 3.5 Amps per conductor @ 20°C Electrical Characteristics-Premise (Overall) Premise Minimum NEXT: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) NEXT (dB) .772 50 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7839A 0601000 1,000 FT 79.000 LB CHROME C 6 PRS #22 FRPP FS PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 0 Revision Date: 08-22-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7839A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
7839A 0601000 价格&库存
很抱歉,暂时无法提供与“7839A 0601000”相匹配的价格&库存,您可以联系我们找货
