7939A 1NH1000
7939A 1NH1000
    BELDEN
    CBL 4 BONDED PR 24AWG CAT5E SHLD
7939A 1NH1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7939A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) bare copper conductors, bonded pairs, polyolefin insulation, polyester separator, Beldfoil® shield (100% coverage), drain wire, industrial grade sunlight- and oil-resistant PVC jacket. Sequential marking at two foot intervals. Usage (Overall) Suitable Applications: Industrial Ethernet, Harsh Environments, Flexible Applications, 200MHz Category 5e, Industrial Patch Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, CMX - Outdoor, RJ-45 Compatible Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 7x32 BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) Industrial Grade PVC - Polyvinyl Chloride 0.030 Outer Jacket Ripcord: No Overall Cable Overall Cabling Separator Material: Polyester Overall Nominal Diameter: 0.295 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Mechanical Characteristics (Overall) Installation Temperature Range: -25°C To +75°C Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 35 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 0.600 in. Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7939A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 08/23/2007 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1 Category 5e Patch, ICEA 661 Category 5 Patch, UL verified to Category 5e Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Oil Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15.000 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 69.000 Maximum Delay: Delay (ns/100 m) 510.000 Typical Delay Skew: Delay Skew (ns/ft) 12.000 Max. Delay Skew: Delay Skew (ns/100 m) 45.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.380 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3.000 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.500 65.3 62.3 62.8 59.8 20.000 23.0 4 4.900 56.3 53.3 51.4 48.4 23.000 23.0 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7939A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable 8 6.900 51.8 48.8 44.9 41.9 24.500 24.5 10 7.800 50.3 47.3 42.5 39.5 25.000 25.0 16 9.900 47.3 44.3 37.4 34.4 25.000 25.0 20 11.100 45.8 42.8 34.7 31.7 25.000 25.0 25 12.500 44.3 41.3 21.8 28.8 24.300 24.3 31.25 14.100 42.9 39.9 28.8 25.8 23.600 23.6 62.5 20.400 38.4 35.4 18.0 15.0 21.500 21.5 100 26.400 35.3 32.3 8.9 5.9 20.100 20.1 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 63.8 60.8 4 100 ± 15 100 ± 15 51.7 48.7 8 100 ± 15 100 ± 15 45.7 42.7 10 100 ± 15 100 ± 15 43.8 40.8 16 100 ± 15 100 ± 15 39.7 36.7 20 100 ± 15 100 ± 15 37.7 34.7 25 100 ± 15 100 ± 15 35.8 32.8 31.25 100 ± 15 100 ± 15 33.9 30.9 62.5 100 ± 15 100 ± 15 27.8 24.8 100 100 ± 15 100 ± 15 23.8 20.8 Notes (Overall) Notes: Operating temperatures are subject to length de-rating. Cable passes -40C Cold Bend per UL 1581. Notes (Cont'd.): T568A Plug Compatible Part Number: R301601 T568B Plug Compatible Part Number: R301602 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7939A 0021000 1,000 FT 40.000 LB RED C 4 PR #24 PP FS FRPVC 7939A 0061000 1,000 FT 40.000 LB BLUE, LIGHT C 4 PR #24 PP FS FRPVC 7939A 0081000 1,000 FT 40.000 LB GRAY C 4 PR #24 PP FS FRPVC 7939A 0101000 1,000 FT 40.000 LB BLACK C 4 PR #24 PP FS FRPVC 7939A 0102000 2,000 FT 80.000 LB BLACK C 4 PR #24 PP FS FRPVC 7939A 1NH1000 1,000 FT 40.000 LB TEAL 1NH C 4 PR #24 PP FS FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 07-19-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
7939A 1NH1000 价格&库存
很抱歉,暂时无法提供与“7939A 1NH1000”相匹配的价格&库存,您可以联系我们找货
7939A 1NH1000
  • 1+53.373461+6.92690
  • 50+42.2285950+5.48050
  • 100+37.78806100+4.90420
  • 305+33.43460305+4.33920
