7960A 1SW2000
7960A 1SW2000
    BELDEN
    4COND PROFINET TYPE A CAT 5/5E
7960A 1SW2000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7960A Multi-Conductor - Category 5e DataTuff® Quad Cables For more Information please call 1-800-Belden1 General Description: 22 AWG Symmetric quad solid bare copper conductors, polyolefin insulation, FRPE bedding, industrial grade sunlight- and oil-resistant PVC jacket, rip cord. Sequential marking at two foot intervals. PROFINET Type A cable Usage (Overall) Suitable Applications: Industrial Ethernet Cable, Harsh Environments, Category 5e, ProfiNet, 100BaseTX, CMX - Outdoor, PLTC Listed, Approved for Cable Tray Use in Class 1, Division 2, Hazardous Areas and Non-hazardous Areas, Cable Trays, Raceways, Conduit and Supported by Messenger Wires, Approved for Outdoor Usage Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (in.) 4 22 Solid BC - Bare Copper 0.026 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Dia. (in.) PO - Polyolefin 0.059 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) FRPE 0.164 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® 2 Coverage (%) Tape Aluminum Foil - Polyester Tape 100.000 Braid 85.000 Outer Jacket Outer Jacket Material: Outer Jacket Material Industrial Grade PVC Overall Cable Overall Nominal Diameter: 0.268 in. Pair Pair Color Code Chart: Number Color 1 White 2 Blue 3 Yellow 4 Orange Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +80°C Installation Temperature Range: -20°C To +60°C Operating Temperature Range: -40°C To +80°C Bulk Cable Weight: 40.700 lbs/1000 ft. Max. Recommended Pulling Tension: 55 lbs. Min. Bend Radius/Minor Axis: 2.560 in. Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7960A Multi-Conductor - Category 5e DataTuff® Quad Cables Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG, CMX-Outdoor, ITC, PLTC CEC/C(UL) Specification: CMG AWM Specification: UL Style 21047 EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Flame Test UL Flame Test: UL1685 FT4/IEEE 1202 Vertical Tray Flame Test C(UL) Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Oil Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 66 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 552.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 5.700 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. ACR (dB) Min RL (dB) 1 2.100 65.3 63.2 23.000 4 4.000 56.3 52.3 23.000 10 6.300 50.3 43.9 25.000 16 8.000 47.2 39.1 25.000 20 9.000 45.8 35.2 25.000 31.25 11.400 42.9 31.3 23.600 Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7960A Multi-Conductor - Category 5e DataTuff® Quad Cables 62.5 16.500 38.4 21.6 21.500 100 21.300 35.3 17.1 20.100 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ACRF (dB) 1 100 ± 20.2 105 ± 10 64.0 4 100 ± 14.2 100 ± 10 52.0 10 100 ± 11.3 100 ± 10 44.0 16 100 ± 11.3 100 ± 10 39.9 20 100 ± 11.3 100 ± 10 38.0 31.25 100 ± 13.2 100 ± 10 34.1 62.5 100 ± 16.9 100 ± 10 28.1 100 100 ± 20.0 100 ± 10 24.0 Notes (Overall) Notes: Operating temperatures are subject to length de-rating. Cable passes -40C Cold Bend per UL 1581. Limits below 4 MHz are for information only. Notes (Cont'd.): T568A Plug Compatible Part Number: R301601 T568B Plug Compatible Part Number: R301602 Put Ups and Colors: Item # Putup Ship Weight Color 7960A 1SW1000 1,000 FT 44.000 LB GREEN, RAL 6018 PROFINET TYPE A CAT 5/5E 7960A 1SW2000 2,000 FT 88.000 LB GREEN, RAL 6018 PROFINET TYPE A CAT 5/5E Revision Number: 0 Notes Item Desc Revision Date: 07-19-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-01-2017
7960A 1SW2000 价格&库存
很抱歉,暂时无法提供与“7960A 1SW2000”相匹配的价格&库存,您可以联系我们找货
