8241 002U1000
8241 002U1000
    BELDEN
    RG59/U TYPE COAX RED
8241 002U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8241 Coax - 75 Ohm Coax For more Information please call 1-800-Belden1 General Description: 23 AWG Solid .023" bare copper or bare copper-covered steel conductor, polyethylene insulation, bare copper braid shield (95% cverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 23 Solid Dia. (in.) BCCS - Bare Copper Covered Steel 0.023 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene .146 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.240 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C UL Temperature Rating: 75°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 37 lbs/1000 ft. Max. Recommended Pulling Tension: 62 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM AWM Specification: UL Style 1354 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8241 Coax - 75 Ohm Coax RG Type: 59/U Flame Test UL Flame Test: UL1685 UL Loading Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88241, 82241 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .131 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 20.5 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 49.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.6 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .6 10 1.1 50 2.4 100 3.4 200 4.9 400 7.0 700 9.7 900 11.1 1000 12.0 Nom. Power Rating: Freq. (MHz) Rating (W) 50 470 100 310 300 160 500 115 1000 76 Max. Operating Voltage - UL: Voltage 300 V RMS 30 V RMS Max. Operating Voltage - Non-UL: Voltage 1700 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 8241 002U1000 1,000 FT 38.000 LB RED Notes RG59/U TYPE COAX RED 8241 003U1000 1,000 FT 38.000 LB ORANGE RG59/U TYPE COAX ORG 8241 004U1000 1,000 FT 38.000 LB YELLOW RG59/U TYPE COAX YEL Page 2 of 3 Item Desc 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8241 Coax - 75 Ohm Coax 8241 005U1000 1,000 FT 38.000 LB GREEN, DARK RG59/U TYPE COAX DGRN 8241 006U1000 1,000 FT 38.000 LB BLUE, LIGHT RG59/U TYPE COAX LBLU 8241 009U1000 1,000 FT 38.000 LB WHITE RG59/U TYPE COAX WHT 8241 010U1000 1,000 FT 38.000 LB BLACK RG59/U TYPE COAX BLK 8241 010U500 500 FT 19.500 LB BLACK RG59/U TYPE COAX BLK 8241 010100 100 FT 4.400 LB BLACK 8241 0101000 1,000 FT 40.000 LB BLACK C RG59/U TYPE COAX BLK 8241 0102000 2,000 FT 80.000 LB BLACK C RG59/U TYPE COAX BLK 8241 010500 500 FT 20.000 LB BLACK C RG59/U TYPE COAX BLK 8241 0105000 5,000 FT 200.000 LB BLACK C RG59/U TYPE COAX BLK RG59/U TYPE COAX BLK Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 08-27-2011 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
8241 002U1000
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端控制发光二极管发光,输出端光电晶体管导通。
6. 应用信息:EL817广泛应用于数字电路隔离、信号传输等领域。
7. 封装信息:EL817采用DIP-6封装形式。
8241 002U1000 价格&库存
很抱歉,暂时无法提供与“8241 002U1000”相匹配的价格&库存,您可以联系我们找货
8241 002U1000
  • 1000+7.908981000+1.02582
