83269 0091000
83269 0091000
    BELDEN
    #26 COAX RG-188A/U
83269 0091000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83269 Coax - RG-188A/U Type For more Information please call 1-800-Belden1 General Description: RG-188A/U type, 26 AWG stranded (7x34) .0205" silver-plated copper-covered steel conductor, TFE Teflon® insulation, SPC braid shield (95% coverage), TFE tape jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 26 7x34 Dia. (in.) SPCCS - Silver Plated Copper Covered Steel .0205 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Dia. (in.) TFE - Tetrafluoroethylene .058 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid SPC - Silver Plated Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Teflon® TFE - Tetrafluoroethylene Overall Cable Overall Nominal Diameter: 0.098 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C UL Temperature Rating: 200°C Bulk Cable Weight: 11 lbs/1000 ft. Max. Recommended Pulling Tension: 21 lbs. Min. Bend Radius/Minor Axis: 1 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-C-17D RG Type: 188A/U Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83269 Coax - RG-188A/U Type Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) 0.067 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 29.0 Nominal Velocity of Propagation: VP (%) 69.5 Nominal Delay: Delay (ns/ft) 1.47 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 91.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 8.5 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 1.2 10 2.7 50 5.6 100 8.3 200 12.0 400 17.5 700 23.7 900 27.3 1000 29.0 Max. Operating Voltage - Non-UL: Voltage 900 V RMS Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 83269 009100 100 FT 1.400 LB WHITE E #26 COAX RG-188A/U 83269 0091000 1,000 FT 11.000 LB WHITE E #26 COAX RG-188A/U 83269 009500 500 FT 5.500 LB WHITE E #26 COAX RG-188A/U Notes: E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25' Revision Number: 2 Revision Date: 04-25-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
83269 0091000 价格&库存
很抱歉,暂时无法提供与“83269 0091000”相匹配的价格&库存,您可以联系我们找货
