Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
83317E Multi-Conductor - MIL-W-16878/4 (Type E), 2 Conductors Cabled
For more Information
please call
1-800-Belden1
General Description:
26 AWG stranded (7x34) silver-plated copper conductors, cabled and color-coded, extruded TFE Teflon®
insulation, silver plated copper braid shield (85% coverage), TFE teflon tape-wrapped jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
2
26
7x34
SPC - Silver Plated Copper
Total Number of Conductors:
2
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Teflon®
Wall Thickness (in.)
TFE - Tetrafluoroethylene .010
Insulation Resistance:
100,000 Megaohms/1000 ft. @ 500 V DC
Outer Shield
Outer Shield Material:
Type Outer Shield Material
Coverage (%)
Braid SPC - Silver Plated Copper 85
Outer Jacket
Outer Jacket Material:
Outer Jacket Trade Name Outer Jacket Material
Teflon®
Nom. Wall Thickness (in.)
TFE - Tetrafluoroethylene .011
Overall Cable
Overall Cabling Color Code Chart:
Number Color
1
White
2
Black
Overall Nominal Diameter:
0.121 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-65°C To +200°C
Bulk Cable Weight:
12 lbs/1000 ft.
Max. Recommended Pulling Tension:
26.800 lbs.
Min. Bend Radius/Minor Axis:
1.250 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Military Specification:
MIL-W-16878/4 (Type E insulated conductors)
Other Specification:
NEMA HP3
Page 1 of 2
08-26-2016
NEMA HP3
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/ft)
.14
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
20.8
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
35.5
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
39
Nominal Outer Shield DC Resistance:
7
Max. Operating Voltage - UL:
Voltage
600 V RMS
Max. Recommended Current:
Current
3 Amps per conductor @ 25°C
Notes (Overall)
Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
83317E 009100
100 FT
1.300 LB
WHITE
E
2 #26 TFE BRD TFE TAPE
83317E 0091000
1,000 FT
13.000 LB
WHITE
E
83317E 009500
500 FT
6.500 LB
WHITE
E
Notes:
E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25'
Revision Number: 5
Revision Date: 09-04-2012
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“83317E 009500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 152+159.50882152+20.00100
- 304+141.57535304+17.75230
