83654 002100
83654 002100
    BELDEN
    CBL 4COND 18AWG SHLD
83654 002100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83654 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (19x30) TC conductors, conductors cabled, plenum, FEP insulation, overall Beldfoil® (100% coverage) + TC braid shield (85% coverage), FEP jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 18 19x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene .007 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Braid TC - Tinned Copper 85 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene .014 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 White 3 Red 4 Green Overall Nominal Diameter: 0.195 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 42 lbs/1000 ft. Max. Recommended Pulling Tension: 96 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP NEC Articles: 800 CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83654 Multi-Conductor - Audio, Control and Instrumentation Cable EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .128 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 33 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 60 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.8 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature Rise 4.3 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 83654 002100 100 FT 6.100 LB RED Notes Item Desc 83654 0021000 1,000 FT 45.000 LB RED C 4#18 FEP SH FEP 83654 002500 500 FT 22.500 LB RED C 4#18 FEP SH FEP 83654 0025000 5,000 FT 215.000 LB RED 4#18 FEP SH FEP 4#18 FEP SH FEP Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 08-05-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
83654 002100 价格&库存
很抱歉,暂时无法提供与“83654 002100”相匹配的价格&库存,您可以联系我们找货
  • 30+206.0928530+25.85440
库存:30
83654 002100
  • 100+167.07424100+20.95951
  • 200+158.67263200+19.90552
  • 300+153.91480300+19.30865
  • 500+148.07857500+18.57650
库存:100
