Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
8762MN Multi-Conductor - SpaceMaker Audio, Control and Instrumentation Cable
For more Information
please call
1-800-Belden1
General Description:
20 AWG stranded (26x34) TC conductors, polypropylene insulation, twisted pair, overall Beldfoil® shield
(100% coverage), 22 AWG stranded TC drain wire, PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material
1
26x34
TC - Tinned Copper
Total Number of Conductors:
2
Insulation
Insulation Material:
Insulation Material Wall Thickness (mm)
PP - Polypropylene 0.254
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100.000
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
22
19x34
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (mm)
PVC - Polyvinyl Chloride 0.406
Overall Cable
Overall Nominal Diameter:
3.785 mm
Pair
Pair Color Code Chart:
Number Color
1
Black & White
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +80°C
Bulk Cable Weight:
20.835 Kg/Km
Max. Recommended Pulling Tension:
204.617 N
Min. Bend Radius/Minor Axis:
57.150 mm
Min. Bend/Installation:
15.240 mm
Min. Bend Radius (Continuous Flexing):
37.846 mm
Flex Cycle Rating:
1 Million Flexes
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
Page 1 of 2
10-17-2016
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Other Specification:
UL Style AWM 2937 (300V 80C), NFPA 79
Flame Test
CSA Flame Test:
FT2
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/m)
0.085
Nom. Capacitance Conductor to Shield:
Capacitance (pF/m)
203.422
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/m)
106.961
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/km)
34.122
Max. Operating Voltage - UL:
Voltage
300 V RMS
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
8762MN 004100
100 FT
2.900 LB
YELLOW
1 FS PR #20 PO PVC
8762MN 0041000
1,000 FT
15.000 LB
YELLOW
1 FS PR #20 PO PVC
8762MN 006100
100 FT
2.900 LB
BLUE, LIGHT
1 FS PR #20 PO PVC
8762MN 0061000
1,000 FT
15.000 LB
BLUE, LIGHT
1 FS PR #20 PO PVC
8762MN 008100
100 FT
2.900 LB
GRAY
1 FS PR #20 PO PVC
8762MN 0081000
1,000 FT
15.000 LB
GRAY
1 FS PR #20 PO PVC
Revision Number: 0
Notes
Item Desc
Revision Date: 09-22-2016
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
10-17-2016
很抱歉,暂时无法提供与“8762MN 006100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30+24.2571730+3.15270
- 60+21.8227660+2.83630
- 90+19.1275290+2.48600
