88232 010500
88232 010500
    BELDEN
    #20 TRIAX FFEP RG59/U TYPE
88232 010500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 88232 Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032" bare copper conductor, plenum, foam FEP insulation, bare copper braid shields (95% coverage), FEP jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 20 Solid BC - Bare Copper 0.8128 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) FFEP - Foam Fluorinated Ethylene Propylene 3.556 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Braid BC - Bare Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (mm) FEP - Fluorinated Ethylene Propylene 4.7752 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material FEP - Fluorinated Ethylene Propylene Overall Cable Overall Nominal Diameter: 6.223 mm Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +200°C UL Temperature Rating: 200°C Non-UL Temperature Rating: 200°C Bulk Cable Weight: 86.316 Kg/Km Max. Recommended Pulling Tension: 622.748 N Min. Bend Radius/Minor Axis: 63.500 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 01-09-2015 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 88232 Coax - RG-59/U Type EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Flame Test UL Flame Test: NFPA 262 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Aerial: Yes - When supported by a messenger wire Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 8232A Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.318257 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 55.4489 Nominal Velocity of Propagation: VP (%) 80 Nominal Delay: Delay (ns/m) 4.2653 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 32.81 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/km) 8.5306 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 8.5306 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 1.3124 3.6 1.9686 10 2.6248 71.5 7.2182 135 10.1711 270 14.7645 360 17.3893 540 21.6546 720 25.2637 750 25.9199 1000 30.8414 1500 39.7001 2250 51.1836 3000 61.3547 Max. Operating Voltage - UL: Voltage 300 V RMS Page 2 of 3 01-09-2015 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 88232 Coax - RG-59/U Type Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 850 21 851 3000 15 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 3 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 88232 0101000 1,000 FT 62.000 LB BLACK C #20 TRIAX FFEP RG59/U TYPE 88232 010500 500 FT 30.500 LB BLACK C #20 TRIAX FFEP RG59/U TYPE Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 04-06-2009 © 2015 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-09-2015
88232 010500 价格&库存
很抱歉,暂时无法提供与“88232 010500”相匹配的价格&库存,您可以联系我们找货
