8899 002U1000
8899 002U1000
    BELDEN
    HOOK-UP 18AWG STR RED
8899 002U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8899 Hook-up/Lead - Test Prod Wire For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, rubber insulated. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 65x36 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Rubber 0.049 Overall Insulation Overall Cable Overall Nominal Diameter: 0.144 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +90°C Bulk Cable Weight: 15 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.500 Max. Recommended Current: Description Current 10C temperature rise 8 amps @ 25C ambient Breakdown Voltage: 20,000 V RMS Suggested Working Voltage: 5000 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 8899 002U1000 1,000 FT 16.000 LB RED 18 STR EPDM RED 8899 002U500 500 FT 8.500 LB RED 18 STR EPDM RED Page 1 of 2 Notes Item Desc 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8899 Hook-up/Lead - Test Prod Wire 8899 002100 100 FT 2.200 LB RED 8899 0021000 1,000 FT 17.000 LB RED #18 STR EPDM RED 8899 00225 25 FT 0.600 LB RED #18 STR EPDM RED 8899 002500 500 FT 8.500 LB RED #18 STR EPDM RED 8899 004100 100 FT 2.200 LB YELLOW #18 STR EPDM YEL 8899 004500 500 FT 8.000 LB YELLOW #18 STR EPDM YEL 8899 005100 100 FT 2.200 LB GREEN, DARK #18 STR EPDM DGRN 8899 005500 500 FT 8.500 LB GREEN, DARK #18 STR EPDM DGRN 8899 006100 100 FT 2.200 LB BLUE, LIGHT #18 STR EPDM LBLU 8899 006500 500 FT 8.500 LB BLUE, LIGHT #18 STR EPDM LBLU 8899 009100 100 FT 2.300 LB WHITE #18 STR EPDM WHT 8899 009500 500 FT 8.500 LB WHITE #18 STR EPDM WHT 8899 010U1000 1,000 FT 16.000 LB BLACK #18 STR EPDM BLK 8899 010U500 500 FT 8.500 LB BLACK 18 STR EPDM BLK 8899 010100 100 FT 2.300 LB BLACK 8899 0101000 1,000 FT 17.000 LB BLACK 8899 01025 25 FT 0.600 LB BLACK 18 STR EPDM BLK 8899 010500 500 FT 8.500 LB BLACK #18 STR EPDM BLK C #18 STR EPDM RED 18 STR EPDM BLK C #18 STR EPDM BLK Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 09-03-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 08-26-2016
8899 002U1000 价格&库存
很抱歉,暂时无法提供与“8899 002U1000”相匹配的价格&库存,您可以联系我们找货
8899 002U1000
  • 1000+20.884861000+2.70980
