Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8916 Hook-up/Lead - UL AWM Style 1015
For more Information
please call
1-800-Belden1
General Description:
14 AWG stranded (41x30) tinned copper conductor, PVC insulation. Rated 105ºC, 600V. Rated 2500V
peak for electronic circuits, and internal wiring of electronic and electrical equipment.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
14
41x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.) Min. Avg. Wall (in.)
PVC - Polyvinyl Chloride 0.033
0.030
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.138 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-30°C To +105°C
Bulk Cable Weight:
19 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
600 V, 105°C
UL Type:
MTW or TW
CSA Rating:
600 V, 105°C
CSA Type:
AWM I A/B or TEW
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
07/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
CSA Flame Test:
FT1
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
2.400
Max. Operating Voltage - UL:
Voltage
600 VRMS
Page 1 of 2
08-26-2016
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30C ambient. 39 amps
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
8916 001100
100 FT
2.700 LB
BROWN
Notes
Item Desc
8916 0014000
4,000 FT
80.000 LB
BROWN
8916 001500
500 FT
10.500 LB
BROWN
8916 002100
100 FT
2.700 LB
RED
8916 0024000
4,000 FT
80.000 LB
RED
8916 002500
500 FT
10.500 LB
RED
14 STR PVC RED
8916 003100
100 FT
2.700 LB
ORANGE
14 STR PVC ORG
8916 003500
500 FT
10.500 LB
ORANGE
14 STR PVC ORG
8916 004100
100 FT
2.700 LB
YELLOW
14 STR PVC YEL
8916 004500
500 FT
10.500 LB
YELLOW
14 STR PVC YEL
8916 005100
100 FT
2.700 LB
GREEN, DARK
8916 0054000
4,000 FT
80.000 LB
GREEN, DARK
8916 005500
500 FT
10.500 LB
GREEN, DARK
8916 007500
500 FT
10.500 LB
VIOLET
P
'14 STR PVC VIO
8916 008500
500 FT
10.500 LB
GRAY
P
#14 STR PVC GRY
8916 009100
100 FT
2.700 LB
WHITE
14 STR PVC WHT
8916 009500
500 FT
10.500 LB
WHITE
14 STR PVC WHT
8916 010100
100 FT
2.700 LB
BLACK
8916 0104000
4,000 FT
80.000 LB
BLACK
8916 010500
500 FT
10.500 LB
BLACK
14 STR PVC BLK
8916 013100
100 FT
2.700 LB
BLUE, DARK
14 STR PVC D BLU
8916 013500
500 FT
10.500 LB
BLUE, DARK
8916 189100
100 FT
2.700 LB
GREEN/YELLOW
A
14 STR PVC GRN/YEL
8916 189500
500 FT
10.500 LB
GREEN/YELLOW
A
14 STR PVC GRN/YEL
14 STR PVC BRN
CP
14 STR PVC BRN
14 STR PVC BRN
14 STR PVC RED
CP
14 STR PVC RED
14 STR PVC D GRN
CP
14 STR PVC DGRN
14 STR PVC D GRN
14 STR PVC BLK
C
#14 STR PVC BLK
14 STR PVC D BLU
Notes:
A = STOCKED STRIPE COLORS.
C = CRATE REEL PUT-UP.
P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE
SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL
Revision Number: 1
Revision Date: 04-23-2013
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“8916 002500”相匹配的价格&库存,您可以联系我们找货
