9207NH.00305
9207NH.00305
    BELDEN
    BELDEN - 9207NH.00305 - Twinaxial Cable, 20 AWG, 100 ohm, Transparent, 1000 ft, 305 m
9207NH.00305 数据手册
TECHNICAL DATA SHEET 9207NH code version date page 9207NH 3 2005-12-20 1/2 APPLICATION Twinaxial instrumentation and computer cable for data transmission applications. CONSTRUCTION 1 2 1. 2. 3. 4. 5. 6. 7. 8. 6 3 7 4 8 5 Conductor Insulation Material Diameter over insulation Colour of insulation Conductor Insulation Material Diameter over insulation Colour of insulation Dielectric Material Diameter over dielectric Colour of dielectric Foil (Duofoil®) Material Thickness Braiding Material Coverage Sheath Material Colour Thickness of sheath Diameter over sheath AWG20 (7xAWG28) bare Cu Polyethylene 2.11 ± 0.08 mm Clear AWG20 (7xAWG28) tinned Cu Polyethylene 2.11 ± 0.08 mm Clear Polyethylene 5.99 ± 0.15 mm Clear Aluminium/ Polyester/ Aluminium 9 / 23 / 9 µm AWG34 tinned Cu 85 % FRNC Black 0.89 ± 0.05 mm 8.60 ± 0.20 mm REQUIREMENTS AND TEST METHODS Electrical: Nominal resistance conductor @ 20 °C Nominal resistance shield @ 20 °C Nominal capacitance conductor to conductor Nominal capacitance conductor to shield Nominal impedance Nominal velocity of propagation Nominal delay 31.2 Ω/km 6.6 Ω/km 47.6 pF/m 75.5 pF/m 100 Ω 66 % 5.1 ns/m  Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner TECHNICAL DATA SHEET 9207NH Nominal inductance Nominal attenuation @ 1 MHz Nominal attenuation @ 10 MHz Nominal attenuation @ 50 MHz Nominal attenuation @ 100 MHz Nominal attenuation @ 200 MHz Nominal attenuation @ 400 MHz Testvoltage conductor-screen Voltage rating code version date page 9207NH 3 2005-12-20 2/2 0.51 µH/m 0.98 dB/100m 3.94 dB/100m 9.19 dB/100m 13.45 dB/100m 21.00 dB/100m 33.46 dB/100m 2500 VDC, 3 seconds 300 V RMS Mechanical and physical: Flame resistance Oil resistance Radiation resistance Application specification Halogen content according to IEC754-1 Corrosivity of fire gasses according to IEC754-2 Conductivity pH value Temperature range installing Temperature range operating (moving installation) Temperature range operating (fixed installation) Temperature range storage Minimum bending radius MARKING Colour code 2559: black sheath with text IEC 60332-3C ASTMD741 IEC544 (CERN) BS 7655 section 6.1 table 1, LTS 3 zero ≤ 100 µS/cm ≥ 3.5 -15 to +80 ˚C -15 to +80 ˚C -45 to +80 ˚C -45 to +80 ˚C 10 x cable diameter ‘BELDEN V 9207NH 1PR 20AWG SHIELDED LSNH IEC 332 PART 1’ PACKAGING On non-returnable reels (E 500) with a nominal length of 305m (-0, +10%) or on nonreturnable reels (E 600) with a nominal length of 500m (-0, +10%) or on non-returnable reels (E 630) with a nominal length of 1000m (-0, +10%). Each reel is labelled with the following data: Belden Logo. Belden code number. Item description. Length on the reel. Date of manufacture. CE-marking.  Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner TECHNICAL DATA SHEET 9207NH code version date page 9207NH 3 2005-12-20 3/2 Belden CDT believes this product to be in compliance with the environmental regulations EU RoHS (Directive 2002/95/EC, 27 January 2003); this is valid for all material produced after the RoHS compliant date for this product.  Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
9207NH.00305 价格&库存
很抱歉,暂时无法提供与“9207NH.00305”相匹配的价格&库存,您可以联系我们找货
