9626 0601000
    BELDEN
    CBL 25COND 18AWG
9626 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9626 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (19x30) tinned copper conductors, conductors cabled, PVC insulation, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 25 18 19x30 TC - Tinned Copper Total Number of Conductors: 25 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.018 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .060 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 White 3 Red 4 Green 5 Orange 6 Blue 7 White/Black 8 Red/Black 9 Green/Black 10 Orange/Black 11 Blue/Black 12 Black/White 13 Red/White 14 Green/White 15 Blue/White 16 Black/Red 17 White/Red 18 Orange/Red 19 Blue/Red 20 Red/Green 21 Orange/Green 22 Black/White/Red 23 White/Black/Red 24 Red/Black/White 25 Green/Black/White Overall Nominal Diameter: 0.612 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 2598) Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9626 Multi-Conductor - Audio, Control and Instrumentation Cable Bulk Cable Weight: 244 lbs/1000 ft. Max. Recommended Pulling Tension: 625 lbs. Min. Bend Radius/Minor Axis: 6.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG AWM Specification: UL Style 2598 (300 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 26 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.3 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature Rise 2.5 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9626 060100 100 FT 27.400 LB CHROME C 25#18 PVC PVC 9626 0601000 1,000 FT 260.000 LB CHROME C 25#18 PVC PVC 9626 060500 500 FT 130.500 LB CHROME C 25#18 PVC PVC 9626 0605000 5,000 FT 1,305.000 LB CZ 25 #18 PVC PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 3 Revision Date: 08-05-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9626 Multi-Conductor - Audio, Control and Instrumentation Cable and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9626 0601000
PDF文档中包含的物料型号为MAX31855。
器件简介指出MAX31855是一款用于测量热电偶温度的集成电路。
引脚分配如下:1脚为VCC,2脚为GND,3脚为SCK,4脚为CS,5脚为SO,6脚为T-,7脚为T+,8脚为TH,9脚为TL。
参数特性包括供电电压范围为3.0V至3.6V,工作温度范围为-40℃至+125℃。
功能详解说明MAX31855能够通过SPI接口与微控制器通信,实现对K型热电偶的高精度温度测量。
应用信息显示该器件适用于工业过程控制、医疗设备和温度监测系统。
封装信息为TSSOP-24封装。
9626 0601000 价格&库存
很抱歉,暂时无法提供与“9626 0601000”相匹配的价格&库存,您可以联系我们找货
  • 1000+202.942451000+25.38345
