9843 Paired - Low Capacitance Computer Cables for EIA RS-485 Applications
For more information please
call
1-800-Belden1
See Put-ups and Colors
Color Code Chart : No. 5 for
Paired Cables (Western
Electric Standard).pdf
Description:
24 AWG stranded (7x32) TC conductors, polyethylene insulation, twisted pairs, overall Beldfoil® (100% coverage) + TC braid shield (90%
coverage), 24 AWG stranded TC drain wire, PVC jacket
PHYSICAL CHARACTERISTICS:
CONDUCTOR:
Number of Pairs
3
Total Number of Conductors
6
AWG
24
Stranding
7x32
Conductor Material
TC - Tinned Copper
INSULATION:
Insulation Material
PE - Polyethylene
Lay Length :
Lay Length (in.)
1.0
Direction
Left Hand Lay
Twists/ft.
Twists/ft (twist/ft)
12
12
Pair Color Code Chart :
Number
1
2
Color
White/Blue & Blue/White
White/Orange & Orange/White
Number
3
Color
White/Green & Green/White
OUTER SHIELD:
Outer Shield Material Trade Name
Beldfoil®
Outer Shield Type
Tape/Braid
Outer Shield Material :
Layer Number
1
2
Material Trade Name
Beldfoil®
Type
Tape
Material
Aluminum Foil-Polyester
Tape
TC - Tinned Copper
Braid
Page 1 of 3
% Coverage (%)
100
90
OUTER SHIELD DRAIN WIRE :
Outer Shield Drain Wire AWG
24
Outer Shield Drain Wire Stranding
7x32
Outer Shield Drain Wire Conductor Material
TC - Tinned Copper
OUTER JACKET:
Outer Jacket Material
PVC - Polyvinyl Chloride
OVERALL NOMINAL DIAMETER:
Overall Nominal Diameter
.360 in.
MECHANICAL CHARACTERISTICS:
Operating Temperature Range
-30°C To +80°C
UL Temperature Rating
80°C (UL AWM Style 2919)
Bulk Cable Weight
73 lbs/1000 ft.
Max. Recommended Pulling Tension
105.5 lbs.
Min. Bend Radius (Install)
3.75 in.
APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE:
APPLICABLE STANDARDS:
NEC/(UL) Specification
CM
CEC/C(UL) Specification
CM
AWM Specification
UL Style 2919 (300 V 80°C)
EU CE Mark (Y/N)
Yes
EU RoHS Compliant (Y/N)
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
FLAME TEST:
UL Flame Test
UL1685 UL Loading
PLENUM/NON-PLENUM:
Plenum (Y/N)
N
ELECTRICAL CHARACTERISTICS:
Nom. Characteristic Impedance
120 Ohms
Nom. Capacitance Conductor to Conductor @ 1 KHz
23 pF/ft
Nom. Cap. Cond. to Other Cond. & Shield @ 1 KHz
12.8 pF/ft
Nominal Velocity of Propagation
66 %
Nominal Delay
1.6 ns/ft
Nom. Conductor DC Resistance @ 20 Deg. C
24 Ohms/1000 ft
Nominal Outer Shield DC Resistance @ 20 Deg. C
2.3 Ohms/1000 ft
Nom. Attenuation (dB/100 ft)
0.6 (@ 1 MHz) dB/100 ft.
Page 2 of 3
Max. Operating Voltage - UL
300 V RMS (UL AWM Style 2919)
Max. Recommended Current
1.54 Amps per conductor @ 25°C
PUT-UPS AND COLORS:
Item
Description
Put-Up (ft.)
9843 060100
3 PR #24 PE SH PVC 100
Ship Weight (lbs.)
7.1
Jacket Color
CHROME
Notes
9843 0601000
3 PR #24 PE SH PVC 1000
67
CHROME
C
9843 060500
3 PR #24 PE SH PVC 500
34.5
CHROME
C
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 07-21-2005
© 2005 Belden Wire & Cable Company
All Rights Reserved.
Although Belden Electronics Division ("Belden") makes every reasonable effort to ensure their accuracy at the time of this publication,
information and specifications described herein are subject to error or omission and to change without notice, and the listing of such
information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described
herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden CDT Electronics Division believes this product to be in compliance with the following environmental regulations: California
Proposition 65 Consent Judgment For Wire & Cable Mfgs.(San Francisco Superior Court Nos. 312962 And 320342); EU RoHS
(Directive 2002/95/EC, 27-Jan-2003); EU ELV (Directive 2000/53/EC, 18-Sept-2000); EU WEEE (Directive 2002/96/EC, 27-Jan-2003);
And EU BFR (Directive 2003/11/EC, 6-Feb-2003). The information provided in this Product Disclosure, and the identification of materials
listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information and belief at the date
of its publication. The information provided in the Product Disclosure is designed only as a general guide for the safe handling, storage, and
any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or
quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability
of legislation and regulations based on their individual usage of the product.
Belden CDT Electronics Division declares this product to be in complaince with EU LVD (Low Voltage Directive 73/23/EEC), as amended
by directive 93/68/EEC.
Page 3 of 3
很抱歉,暂时无法提供与“9843 060500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+65.43170500+8.50453
- 国内价格 香港价格
- 1+160.229291+20.82590
- 50+127.4531450+16.56580
- 100+113.54284100+14.75780
- 152+100.06724152+13.00630
