9918 0031000
9918 0031000
    BELDEN
    HOOK-UP 18AWG STR ORG
9918 0031000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9918 Hook-up/Lead - UL AWM Styles 1007 and 1569 For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) tinned copper conductor, PVC insulation. Rated 105ºC, 300V. Rated 600V peak for electronic circuits, and wiring of electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 16x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Min. Avg. Wall (in.) PVC - Polyvinyl Chloride 0.017 0.015 Overall Insulation Overall Cable Overall Nominal Diameter: 0.079 in. Mechanical Characteristics (Overall) Bulk Cable Weight: 6 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 1007 (300 V 80°C), UL Style 1569 (300 V 105°C) UL Rating: 300 V RMS, 80°C and 300 V, 105°C CSA Rating: 300 V RMS, 105°C CSA Type: TRSR-64 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.900 Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient 20 amps Put Ups and Colors: Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9918 Hook-up/Lead - UL AWM Styles 1007 and 1569 Item # Putup Ship Weight Color 9918 001100 100 FT 0.800 LB BROWN Notes Item Desc 9918 0011000 1,000 FT 9.000 LB BROWN P 18 STR PVC BRN 9918 0015000 5,000 FT 40.000 LB BROWN CP 18 STR PVC BRN 9918 002100 100 FT 0.800 LB RED 9918 0021000 1,000 FT 9.000 LB RED P 18 STR PVC RED 9918 0025000 5,000 FT 40.000 LB RED C 18 STR PVC RED 9918 003100 100 FT 0.800 LB ORANGE 9918 0031000 1,000 FT 9.000 LB ORANGE 9918 004100 100 FT 0.800 LB YELLOW 9918 0041000 1,000 FT 9.000 LB YELLOW 9918 005100 100 FT 0.800 LB GREEN, DARK 9918 0051000 1,000 FT 9.000 LB GREEN, DARK P 18 STR PVC DGRN 9918 0055000 5,000 FT 40.000 LB GREEN, DARK C 18 STR PVC DGRN 9918 006100 100 FT 0.800 LB BLUE, LIGHT 18 STR PVC LBLU 9918 0061000 1,000 FT 9.000 LB BLUE, LIGHT 18 STR PVC LBLU 9918 007100 100 FT 0.800 LB VIOLET 9918 0071000 1,000 FT 9.000 LB VIOLET 9918 008100 100 FT 0.800 LB GRAY 9918 0081000 1,000 FT 9.000 LB GRAY 9918 009100 100 FT 0.800 LB WHITE 9918 0091000 1,000 FT 9.000 LB WHITE P 18 STR PVC WHT 9918 0095000 5,000 FT 40.000 LB WHITE C 18 STR PVC WHT 9918 010100 100 FT 0.800 LB BLACK 9918 0101000 1,000 FT 9.000 LB BLACK P 18 STR PVC BLK 9918 0105000 5,000 FT 40.000 LB BLACK CKZ 18 STR PVC BLK 9918 013100 100 FT 0.800 LB BLUE, DARK 9918 0131000 1,000 FT 9.000 LB BLUE, DARK P 18 STR PVC DBLU 9918 0135000 5,000 FT 40.000 LB BLUE, DARK CP #18 STR PVC DBLU 18 STR PVC BRN 18 STR PVC RED 18 STR PVC ORG P 18 STR PVC ORG 18 STR PVC YEL P 18 STR PVC YEL 18 STR PVC DGRN 18 STR PVC VIO P 18 STR PVC VIO 18 STR PVC GRY P 18 STR PVC GRY 18 STR PVC WHT 18 STR PVC BLK 18 STR PVC DBLU Notes: C = CRATE REEL PUT-UP. K = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 500' P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 4 Revision Date: 03-20-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
9918 0031000 价格&库存
很抱歉,暂时无法提供与“9918 0031000”相匹配的价格&库存,您可以联系我们找货
  • 305+8.53279305+1.10740
  • 610+7.48796610+0.97180
