Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
9923 Hook-up/Lead - UL AWM Style 1007 and 1569
For more Information
please call
1-800-Belden1
General Description:
Tinned copper conductor, PVC insulation. Rated 105ºC, 300V. Rated 600V peak for electronic circuits, and
internal wiring of electronic and electrical equipment.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
24
7x32
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.) Min. Avg. Wall (in.)
PVC - Polyvinyl Chloride 0.016
0.015
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.056 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +105°C
Bulk Cable Weight:
2.600 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL AWM Style:
UL Style 1007 (300 V 80°C), UL Style 1569 (300 V 105°C)
UL Rating:
300 V RMS, 80°C and 300 V, 105°C
CSA Rating:
300 V RMS, 105°C
CSA Type:
TRSR-64
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
10/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
CSA Flame Test:
FT1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
23.250
Max. Operating Voltage - UL:
Page 1 of 2
08-26-2016
Voltage
300 V
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30C ambient 7 A
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
9923 0011000
1,000 FT
3.000 LB
BROWN
P
24 STR PVC BRN
9923 002100
100 FT
0.300 LB
RED
9923 0021000
1,000 FT
3.000 LB
RED
P
24 STR PVC RED
9923 0025000
5,000 FT
15.000 LB
RED
P
#24 STR PVC RED
9923 0031000
1,000 FT
3.000 LB
ORANGE
P
24 STR PVC ORG
9923 0041000
1,000 FT
3.000 LB
YELLOW
P
24 STR PVC YEL
9923 0051000
1,000 FT
3.000 LB
GREEN, DARK
P
24 STR PVC GRN
9923 0071000
1,000 FT
3.000 LB
VIOLET
P
24 STR PVC VIO
9923 0081000
1,000 FT
3.000 LB
GRAY
P
24 STR PVC GRY
9923 009100
100 FT
0.300 LB
WHITE
9923 0091000
1,000 FT
3.000 LB
WHITE
9923 010100
100 FT
0.300 LB
BLACK
9923 0101000
1,000 FT
3.000 LB
BLACK
P
24 STR PVC BLK
9923 0105000
5,000 FT
15.000 LB
BLACK
C
#24 STR PVC BLK
9923 0131000
1,000 FT
3.000 LB
BLUE, DARK
P
24 STR PVC D BLU
24 STR PVC RED
24 STR PVC WHT
P
24 STR PVC WHT
24 STR PVC BLK
Notes:
C = CRATE REEL PUT-UP.
P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE
SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL
Revision Number: 4
Revision Date: 05-13-2013
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“9923 0081000”相匹配的价格&库存,您可以联系我们找货
