Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
AX101436 Faceplates and Panels - Interface Plates 4 Port Single Gang Flush
For more Information
please call
1-800-Belden1
General Description:
Usage (Overall)
Suitable Applications:
- Compatible with a variety of modules that are suitable for use with Belden IBDN Systems 10GX,
4800,3600, 2400 and 1200.
Related Parts:
- Compatible with 10GX, CAT6+ and CAT5E MDVO-style Modular Jacks and MDVO Multimedia Modules
Physical Characteristics (Connectivity)
Capacity
Max. Capacity:
4 ports
Access
Front Connection:
Flush
Dimensions
Dimensions:
Height (in.) Width (in.) Depth (in.)
4.490
3.000
0.460
Materials
Materials:
Description Material
Plate
Plastic - UL94V-0
Color
Color:
Almond
Weight
Weight:
0.110 lbs.
Included Parts
Included Parts:
blank, 6-32 screw, carton label, clear window, installation sheet
Packaging
Packaging:
Individually packaged in a plastic bag.
Mechanical Characteristics (Connectivity)
Connector/Hardware Retention:
20 lbs.
Storage Temperature Range:
-40°C To +70°C
Installation Temperature Range:
-10°C To +60°C
Operating Temperature Range:
-10°C To +60°C
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
07/01/2006
MII Order #39 (China RoHS):
EUP 50
Safety Listing:
ACA, Bi-national Standard Listed
Suitability
Suitability - Indoor:
Yes
Transmission Characteristics (Connectivity)
Notes (Overall)
Notes: For proper installation refer to Installation Guide PX101806 included with the product or visit our web site at http://www.belden.com
Page 1 of 2
02-27-2017
Product Family
Part Numbers:
Description
Gray
Interface Plate Flush 2-port Single Gang
AX101431 AX101432 AX101433 AX101434 AX102582
Almond
White
Black
Ivory
Interface Plate Flush 4-port Single Gang
AX101435 AX101436 AX101437 AX101438 AX102583
Interface Plate Flush 6-port Single Gang
AX101439 AX101440 AX101441 AX101442 AX102584
Interface Surface Adapter Box Single gang AX101474 AX101475 AX101476 AX101477 AX102589
Put Ups and Colors:
Item #
Putup
Ship Weight
AX101436
1 EA
0.038 KG
Revision Number: 0
Color
Notes
Item Desc
INTERFACE PLATE 4-PORT, ALM
Revision Date: 06-02-2009
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 2 of 2
02-27-2017
很抱歉,暂时无法提供与“AX101436”相匹配的价格&库存,您可以联系我们找货
