C12GB-B300
C12GB-B300
    BELDEN
    BELDEN - C12GB-B300 - Multicore Cable, MachFlex 375 YY Control, Unscreened, 12 Core, 0.75 mm², 984 f...
C12GB-B300 数据手册
      Technical Data Sheet – Unshielded (YY) PVC Control Cable  MachFlex 375 YY    Flexible Colour Coded PVC Control Cables  Applications  Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include  precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting  tools, auxiliary equipment, motor speed control, production machinery and many more.  General Reference Standards   DIN VDE 0295, IEC 60228, BS 6360  DIN EN 50290‐2‐22, DIN VDE 0207‐363‐4‐1  IEC 60227‐5, EN 50525‐2‐51, VDE 0281‐13  DIN VDE 0482‐332‐1‐2, DIN EN 60332‐1‐2, IEC 60332‐1‐2  RoHS, REACH & CE Directives Construction & Performance  1.  Conductor Material  Stranded bare copper (DIN VDE 0295 Class 5 / IEC 60228 class 5)  2.  Insulation Material & Colour  PVC (polyvinyl  chloride), VDE 0293‐308 (colour) up to  5 cores: colour‐coded according to VDE 0293‐308,  From 6 cores : Belden MachFlex colour code   A) G = with GN‐YE protective conductor   OR B) X = without protective earth conductor 3.  Jacket / Sheath Material  PVC (polyvinyl  chloride)  4.  Flame Retardancy  VDE 0482‐332‐1‐2, DIN EN 60332‐1‐2, IEC 60332‐1‐2  5.  Voltage Rating (Uo/U)  Up to 1.5 mm²: 300 / 500 V  From 2.5 mm²: 450 / 750 V  6.  Oil Resistant  DIN EN 50290‐2‐22 (TM54)  7.  Temperature Range ‐5°C TO +70°C (Occasional movement)  ‐40°C TO +80°C (Fixed installation)  8.  Bending Radius  15 x OD (Occasional movement)  4 x OD (Fixed installation)  9.  Other Properties  Good UV resistance, chemical resistance & flexibility  1 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Unshielded (YY) PVC Control Cable        Part Code  C2X0.5  C3X0.5  C3G0.5  C4X0.5  C4G0.5  C5X0.5  C5G0.5  C7X0.5  C7G0.5  C9X0.5  C9G0.5  C10X0.5  C10G0.5  C12X0.5  C12G0.5  C14X0.5  C14G0.5  C16X0.5  C16G0.5  C18X0.5  C18G0.5  C20X0.5  C20G0.5  C2X0.75  C3X0.75  C3G0.75  C4X0.75  C4G0.75  C5X0.75  C5G0.75  C7X0.75  C7G0.75  C9X0.75  C9G0.75  C10X0.75  C10G0.75  C12X0.75  C12G0.75  C14X0.75  C14G0.75  C16X0.75  C16G0.75  C18X0.75  C18G0.75  C20X0.75  C20G0.75        Cable  Description  2 X0.5  3 X0.5  3 G0.5  4 X0.5  4 G0.5  5 X0.5  5 G0.5  7 X0.5  7 G0.5  9 X0.5  9 G0.5  10 X0.5  10 G0.5  12 X0.5  12 G0.5  14 X0.5  14 G0.5  16 X0.5  16 G0.5  18 X0.5  18 G0.5  20 X0.5  20 G0.5  2 X0.75  3 X0.75  3 G0.75  4 X0.75  4 G0.75  5 X0.75  5 G0.75  7 X0.75  7 G0.75  9 X0.75  9 G0.75  10 X0.75  10 G0.75  12 X0.75  12 G0.75  14 X0.75  14 G0.75  16 X0.75  16 G0.75  18 X0.75  18 G0.75  20 X0.75  20 G0.75    TABLE A    No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  4.8  5.1  5.1  5.6  5.6  6.2  6.2  6.8  6.8  8.4  8.4  8.8  8.8  9.1  9.1  9.6  9.6  10.2  10.2  10.8  10.8  11.4  11.4  5.3  5.6  5.6  6.2  6.2  6.8  6.8  7.5  7.5  9.3  9.3  9.8  9.8  10.1  10.1  10.7  10.7  11.3  11.3  12.0  12.0  12.7  12.7  30  38  38  48  48  59  59  74  74  99  99  109  109  125  125  143  143  162  162  183  183  203  203  39  49  49  62  62  77  77  98  98  131  131  144  144  165  165  190  190  216  216  243  243  270  270  2 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Unshielded (YY) PVC Control Cable    Part Code  Cable  Description  No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  C2X1.0  C3X1.0  C3G1.0  C4X1.0  C4G1.0  C5X1.0  C5G1.0  C7X1.0  C7G1.0  C9X1.0  C9G1.0  C10X1.0  C10G1.0  C12X1.0  C12G1.0  C14X1.0  C14G1.0  C16X1.0  C16G1.0  C18X1.0  C18G1.0  C20X1.0  C20G1.0  C2X1.5  C3X1.5  C3G1.5  C4X1.5  C4G1.5  C5X1.5  C5G1.5  C7X1.5  C7G1.5  C9X1.5  C9G1.5  C10X1.5  C10G1.5  C12X1.5  C12G1.5  C14X1.5  C14G1.5  C16X1.5  C16G1.5  C18X1.5  C18G1.5  C20X1.5  C20G1.5  C2X2.5  2 X1.0  3 X1.0  3 G1.0  4 X1.0  4 G1.0  5 X1.0  5 G1.0  7 X1.0  7 G1.0  9 X1.0  9 G1.0  10 X1.0  10 G1.0  12 X1.0  12 G1.0  14 X1.0  14 G1.0  16 X1.0  16 G1.0  18 X1.0  18 G1.0  20 X1.0  20 G1.0  2 X1.5  3 X1.5  3 G1.5  4 X1.5  4 G1.5  5 X1.5  5 G1.5  7 X1.5  7 G1.5  9 X1.5  9 G1.5  10 X1.5  10 G1.5  12 X1.5  12 G1.5  14 X1.5  14 G1.5  16 X1.5  16 G1.5  18 X1.5  18 G1.5  20 X1.5  20 G1.5  2 X2.5  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  2.5  5.7  6.1  6.1  6.7  6.7  7.4  7.4  8.1  8.1  10.1  10.1  10.5  10.5  10.9  10.9  11.5  11.5  12.3  12.3  13.0  13.0  13.8  13.8  6.2  6.6  6.6  7.3  7.3  8.1  8.1  8.9  8.9  11.0  11.0  11.6  11.6  12.0  12.0  12.7  12.7  13.4  13.4  14.3  14.3  15.1  15.1  9.1  47  60  60  77  77  95  95  122  122  163  163  180  180  208  208  239  239  271  271  306  306  340  340  58  75  75  96  96  119  119  154  154  204  204  226  226  261  261  300  300  342  342  385  385  429  429  114  3 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Unshielded (YY) PVC Control Cable    Part Code  Cable  Description  No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  C3X2.5  C3G2.5  C4X2.5  C4G2.5  C5X2.5  C5G2.5  C7X2.5  C7G2.5  C9X2.5  C9G2.5  C10X2.5  C10G2.5  C12X2.5  C12G2.5  C14X2.5  C14G2.5  C16X2.5  C16G2.5  C18X2.5  C18G2.5  C20X2.5  C20G2.5  C2X4  C3X4  C3G4  C4X4  C4G4  C5X4  C5G4  C7X4  C7G4  C9X4  C9G4  C10X4  C10G4  C12X4  C12G4  C2X6  C3X6  C3G6  C4X6  C4G6  C5X6  C5G6  C7X6  C7G6  C9X6  3 X2.5  3 G2.5  4 X2.5  4 G2.5  5 X2.5  5 G2.5  7 X2.5  7 G2.5  9 X2.5  9 G2.5  10 X2.5  10 G2.5  12 X2.5  12 G2.5  14 X2.5  14 G2.5  16 X2.5  16 G2.5  18 X2.5  18 G2.5  20 X2.5  20 G2.5  2 X4  3 X4  3 G4  4 X4  4 G4  5 X4  5 G4  7 X4  7 G4  9 X4  9 G4  10 X4  10 G4  12 X4  12 G4  2 X6  3 X6  3 G6  4 X6  4 G6  5 X6  5 G6  7 X6  7 G6  9 X6  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  2  3  3  4  4  5  5  7  7  9  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  6  6  6  6  6  6  6  6  6  6  9.8  9.8  10.9  10.9  12.0  12.0  13.3  13.3  16.6  16.6  17.4  17.4  18.1  18.1  19.1  19.1  20.3  20.3  21.6  21.6  22.9  22.9  10.5  11.3  11.3  12.6  12.6  13.9  13.9  15.4  15.4  19.3  19.3  20.2  20.2  21.0  21.0  11.9  12.8  12.8  14.2  14.2  15.8  15.8  17.4  17.4  21.9  147  147  189  189  234  234  301  301  401  401  447  447  516  516  594  594  677  677  764  764  852  852  165  216  216  278  278  346  346  450  450  597  597  667  667  772  772  224  297  297  384  384  478  478  625  625  828  4 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Unshielded (YY) PVC Control Cable    Part Code  Cable  Description  No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  C9G6  C2X10  C3X10  C3G10  C4X10  C4G10  C5X10  C5G10  C7X10  C7G10  C9X10  C9G10  C2X16  C3X16  C3G16  C4X16  C4G16  C5X16  C5G16  C7X16  C7G16  C2X25  C3X25  C3G25  C4X25  C4G25  C5X25  C5G25  C2X35  C3X35  C3G35  9 G6  2 X10  3 X10  3 G10  4 X10  4 G10  5 X10  5 G10  7 X10  7 G10  9 X10  9 G10  2 X16  3 X16  3 G16  4 X16  4 G16  5 X16  5 G16  7 X16  7 G16  2 X25  3 X25  3 G25  4 X25  4 G25  5 X25  5 G25  2 X35  3 X35  3 G35  9  2  3  3  4  4  5  5  7  7  9  9  2  3  3  4  4  5  5  7  7  2  3  3  4  4  5  5  2  3  3  6  10  10  10  10  10  10  10  10  10  10  10  16  16  16  16  16  16  16  16  16  25  25  25  25  25  25  25  35  35  35  21.9  14.3  15.3  15.3  17.1  17.1  19.0  19.0  21.0  21.0  26.4  26.4  18.2  19.6  19.6  21.9  21.9  24.3  24.3  26.9  26.9  20.8  22.3  22.3  24.9  24.9  27.7  27.7  24.0  25.9  25.9  828  335  447  447  580  580  723  723  950  950  1256  1256  547  730  730  949  949  1186  1186  1559  1559  776  1048  1048  1367  1367  1709  1709  1022  1378  1378      Sheath / Jacket Colour      Colour     1) Grey (RAL 7001)  2) Black      3) Blue      4) Orange     5) Violet        Colour Code    G8U    010    006    003    007  Packaging    *Belden can offer these cables with various packing options like coiled, plastic or wooden reels. This  will be decided at the discretion of Belden based on the cable design and structure.   5 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Unshielded (YY) PVC Control Cable        Put‐up Length    Putup Length    1) 100 Meters  2) 200 Meters*  3) 300 Meters*        Putup Length Code    100M    200M      300M  *Applicable only for certain part codes, please check with Belden for more information.        Stock Code Selection Procedure:        C 5   G 1 . 5 G 5 G 1 U 1 Select the sheath / jacket color code Select the part code from Table A C 8 . 5 G 8 0 0 M Select the putup length code U 1 0 0 M Cable Stock Code = C5G1.5 G8U100M 6 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.
C12GB-B300 价格&库存
很抱歉,暂时无法提供与“C12GB-B300”相匹配的价格&库存,您可以联系我们找货
