C601109010
C601109010
    BELDEN
    BELDEN - C601109010 - PATCH CORD, RJ45 PLUG-PLUG, CAT6, 10FT
C601109010 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION C601106007 Cable Assemblies - CAT6+ Modular Cord For more Information please call 1-800-Belden1 General Description: CAT6+ Patch Cord, Bonded-Pair, 4 Pair, 24 AWG Solid, CMR, T568A/B-T568A/B, Blue, 7 ft. (2.1 m). Usage (Overall) Suitable Applications: IBDN System 4800, IBDN System 2400,TIA Category 6, ISO Class E, 1000BASE-T Related Parts: CAT6+ Modular Jacks, CAT6+ Patch Panels Multi Conductor Physical Characteristics Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Color Code Chart: Color Blue Overall Cabling Overall Cabling Fillers: Cross Web Overall Diameter Overall Nominal Diameter: 0.225 in. Physical Characteristics (Connectivity) Materials Materials: Description Type Material Plug RJ45 Polycarbonate Boot Elastomer Front Connection Blades Phosphor Bronze with 50u inch Gold over Nickel Plating Color Boot Color: Translucent Wiring Scheme Wiring Scheme: T568A/B-T568A/B Weight Weight: 0.060 lbs. Packaging Packaging: Individually packaged in a clear plastic bag. Mechanical Characteristics (Connectivity) Plug / Jack Compatibility: RJ45 Termination Interface: Termination Connection RJ45 Durabilities Mated Connection 750 Cycles Storage Temperature Range: -40°C To +70°C Page 1 of 3 07-31-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION C601106007 Cable Assemblies - CAT6+ Modular Cord Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Max. Recommended Pull Tension: 25 lbs. Min. Bend Radius (Overall Cable): 1.040 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: Riser Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2006 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 6 - TIA 568.C.2, ISO/IEC 11801:2002 Ed.2 Safety Listing: ACA, Bi-national Standard Listed Other Specification: UL 1863 Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Performance Table 1: Max. Min. Min Min. Min. Frequency Max. Insertion Loss Insertion Loss PSNEXT PSNEXT PSACRF PSACRF (MHz) TIA* (dB) Belden (dB) TIA* (dB) Belden (dB) TIA* (dB) Belden (dB) 1.000 2.400 2.000 72.300 73.300 64.800 67.800 4.000 4.500 3.700 63.300 64.300 52.800 55.800 8.000 6.400 5.200 58.800 61.300 46.700 49.700 10.000 7.100 5.900 57.300 59.800 44.800 47.800 16.000 9.100 7.400 54.200 56.600 40.700 43.700 20.000 10.200 8.300 52.800 55.100 38.800 41.800 25.000 11.400 9.300 51.300 53.500 36.800 39.800 31.250 12.800 10.400 49.900 52.000 34.900 37.900 62.500 18.500 14.900 45.400 47.100 28.900 31.900 100.000 23.800 19.000 42.300 43.800 24.800 27.800 200.000 34.800 27.500 37.800 38.900 18.800 21.800 250.000 39.400 31.000 36.300 37.300 16.800 19.800 300.000 34.200 36.100 18.300 Performance Table - Footnote: 100 Meter Cable Specifications - * TIA-EIA-568-C.2 Category 6 Standard -------- PSACRF is formally PSELFEXT Performance Table 2: Min. Min. Min. Min. Frequency (MHz) Return Loss Return Loss Balanced TCL Balanced TCL TIA* (dB) Belden (dB) TIA* (dB) Belden (dB) 1.000 20.000 20.000 40.000 40.000 4.000 23.000 23.000 40.000 40.000 8.000 24.500 24.500 40.000 40.000 10.000 25.000 25.000 40.000 40.000 16.000 25.000 25.000 38.000 38.000 20.000 25.000 25.000 37.000 37.000 25.000 24.200 24.300 36.000 36.000 31.250 23.300 23.600 35.100 35.100 62.500 20.700 21.500 32.000 32.000 100.000 19.000 20.800 30.000 30.000 200.000 16.400 18.700 27.000 27.000 250.000 15.600 18.000 26.000 26.000 300.000 17.500 Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Labeling Labeling: Labeling: Belden Part Number, Performance Acronym, Wiring Scheme and Cord Length. Page 2 of 3 07-31-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION C601106007 Cable Assemblies - CAT6+ Modular Cord Notes (Overall) Notes: C601106007 is subdivided as following C6-01-1-06-007 C6 stands for performance, 01 stands for cable type, 1 stands for termination type, 06 stands for color, 007 stands for length Use last 3 digits of the code to specify length in feet - 001-015 ft in increments of 1 ft than 20 ft or 25 ft Notes (Cont'd.): www.belden.com/p Product Family Product List: Length Yellow 2 ft. (0.6 m) C601104002 C601105002 C601106002 C601108002 C601109002 C601100002 C601107002 Green Blue Gray White Black Purple 4 ft. (1.2 m) C601104004 C601105004 C601106004 C601108004 C601109004 C601100004 C601107004 7 ft. (2.1 m) C601104007 C601105007 C601106007 C601108007 C601109007 C601100007 C601107007 10 ft. (3.0 m) C601104010 C601105010 C601106010 C601108010 C601109010 C601100010 C601107010 15 ft. (4.6 m) C601104015 C601105015 C601106015 C601108015 C601109015 C601100015 C601107015 25 ft. (7.6 m) C601104025 C601105025 C601106025 C601108025 C601109025 C601100025 C601107025 Put Ups and Colors: Item # Putup Ship Weight Color C601106007 1 EA 0.254 LB BLUE, LIGHT Revision Number: 1 Notes Item Desc PATCHCORD BCAT6+ CMR BLU 7FT Revision Date: 01-07-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 07-31-2017
C601109010 价格&库存
很抱歉,暂时无法提供与“C601109010”相匹配的价格&库存,您可以联系我们找货
