DB58BNC
DB58BNC
    BELDEN
    CONN, 50 OHM, BNC, DB STYLE
DB58BNC 数据手册
Part Number: DB58BNC Double Bubble RG-58 BNC Coax Compression Connector Product Description Double Bubble RG58 BNC connector, fits standard RG58 50 Ohm coaxial cable. Compression design that molds the metal completely around the cable. Technical Specifications Product Overview Suitable Applications: Antenna, 50 Ohm Physical Characteristics (Overall) Packaging: 25 Pack Number of Pieces: 1 Connectors Materials Material Nickel plated Brass Gold Plated Electrical Characteristics Impedance Nominal Characteristic Impedance 50 Ohms Mechanical Characteristics Footprint/Type: Coax Connector Interface Type: BNC Gender: Male - plug Connector Series Name: Double Bubble Locking: No Tool Compatibility: CPLCRBC-BR (compression) Termination Type: Compression Cable Center Conductor Diameter Limits: .0317 - .0339 inch Cable Dielectric Diameter Limits: .0111 - .121 inch Cable Outer Jacket Diameter Limits: .185 - .201 inch Standards RG Type: 58/U Type Series Type: Series 58 Applicable Environmental and Other Programs EU CE Mark: Part Number Yes Variants Item # Color UPC Footnote DB58BNC No Color 845671002140 Q Footnote: Q - STANDARD PACKAGES CANNOT BE BROKEN. Patent: https://www.belden.com/resources/patents History Update and Revision: Revision Number: 0.31 Revision Date: 07-11-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
DB58BNC 价格&库存
很抱歉,暂时无法提供与“DB58BNC”相匹配的价格&库存,您可以联系我们找货
DB58BNC
  • 1+100.892571+13.06912
