FP3LDLD001M
FP3LDLD001M
    BELDEN
    FXPC OM3 LC_DX LC_DX 1M
FP3LDLD001M 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION FP3LDLD001M Cable Assemblies - FP - FX PATCH CORD For more Information please call 1-800-Belden1 General Description: FX PATCH CORD, OM3, LC DUPLEX - LC DUPLEX, 1 M, OFNR, DUPLEX ZIP 2.0 MM, A-TO-B, AQUA JACKET Usage (Overall) Suitable Applications: Data Centers, Main Equipment Rooms,Telecommunications Rooms and Work Area Related Parts: FiberExpress Adapter Strips, FiberExpress Manager Modules and FiberExpress Ultra Frames and Cassettes. Workstation Oultlets Multi Conductor Physical Characteristics Overall Cabling Overall Cabling Fillers: Refer to cable Technical Specifications Overall Diameter Overall Nominal Diameter: 1.981 x 3.962 mm Physical Characteristics (Connectivity) Fiber Type Fiber Type: 50 Micron (OM3) Materials Materials: Description Type Material Color Connectors for both ends LC-DUPLEX Plastic Aqua Boots for both ends Aqua Rubber Ferrules for both ends 1.25mm Zirconia-Ceramic Jacket 2.0 mm Zip OFNR Aqua Wiring Scheme Wiring Scheme: TIA/EIA 568-C.3 Weight Weight: 0.051 kg Packaging Packaging: Individually packaged in a clear plastic bag. Mechanical Characteristics (Connectivity) Storage Temperature Range: -40°C To +75°C Operating Temperature Range: -40°C To +75°C Environmental/Mechanical Characteristics: Test (Method) TIA 568-D.3 Belden Thermal Cycling (FOTP-3) n/a -40 to 75°C cycling for 7 days Temperature Life (FOTP-4) 60°C for 4 days 85°C for 7 days Humidity (FOTP-5) 90-95% at 40°C for 4 days 95% @ 75°C for 7 days Durability (FOTP-21) 500 cycles 6 x 200 cycles (3 Elevations) Cable Retention (FOTP-6) 5.0 kg @ 0 deg. 1.94 kg @90 deg. Flex (FOTP-1) 0.5 kg @ 90° to -90° for 100 cycles 0.9 kg @ 90° to -90° for 100 cycles Twist (FOTP-36) 1.5 kg for 10 cycles 1.5 kg for 10 cycles Overall Length Tolerances: Range Tolerance Range Sx & Dx Patchcord Sx & Dx Patchcord MPO Trunk Tolerance Range MPO Trunk Multi-Fiber Cable Assembly Multi-Fiber Cable Assembly Tolerance Page 1 of 2 07-31-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION FP3LDLD001M Cable Assemblies - FP - FX PATCH CORD 0 to 2 meters +0.2 / -0 meter 0 to 2 meters 2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters +0.2 / -0 meter 0 to 2 meters +0.2 / -0 meter +0.3 / -0 meter 5.1 to 40 meters +0.4 / -0 meter 5.1 to 20 meters +0.4 / -0 meter Over 40.1 meters + 1.0% / -0% Over 20.1 meters + 1.0% / -0% +0.4 / -0 meter 5.1 to 20 meters Over 20.1 meters + 1.3 / -0 meter Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: Riser EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2006 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: TIA 568.C.3 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Optical Connector Performance: Description OM1 (62.5 µm) OM2 (50 µm) OM3 (50 µm) OM4 (50 µm) OS2 (Singlemode) UPC OS2 (Singlemode) APC Maximum IL (dB) SingleFiber Connector LC - SC - ST 0.25 dB 0.25 dB 0.25 dB 0.15 dB 0.35 dB 0.35 dB Typical RL (dB) SingleFiber connector LC - SC - ST -30 dB -30 dB -30 dB -30 dB -55 dB -65 dB Maximum IL (dB) MultiFiber Connector MPO 0.5 dB 0.5 dB 0.35 dB 0.2 dB - 0.75 dB Typical RL (dB) MultiFiber Connector MPO -30 dB -30 dB -30 dB -30 dB - -60 dB Electrical Characteristics (Overall) Notes (Overall) Product Family Put Ups and Colors: Item # Putup Ship Weight FP3LDLD001M 1 EA 0.044 KG Revision Number: 0 Color Notes Item Desc FXPC OM3 LC_DX LC_DX 1M Revision Date: 03-17-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 07-31-2017
FP3LDLD001M 价格&库存
很抱歉,暂时无法提供与“FP3LDLD001M”相匹配的价格&库存,您可以联系我们找货
