FPSLDST002M
FPSLDST002M
    BELDEN
    FXPC OS2 LC_DX ST 2M
FPSLDST002M 数据手册
® Belden Optical Fiber Catalog Ourr En nd-to--En nd Experrtise e You ur End-to o-En nd Soluttion Belden FiberExpress® Systems Belden FiberExpress® Systems Reduce Complexity and Increase Flexibility Involved in the development of optical fiber components for over 40 years, Belden is a leading supplier of high-quality, costeffective optical fiber cabling systems. The FiberExpress (FX) Systems are the culmination of Belden’s experience and expertise in a variety of applications, including data centers, premise and campus network backbone infrastructures, fiber-tothe-desk (FTTD) applications, and horizontal and centralized cabling systems. Guaranteed to meet or exceed all applicable TIA/EIA, ISO/IEC and IEEE standards, each end-toend FX System is designed to offer reduced complexity, increased flexibility, and rapid installation. LEED Point documents are available on several products, see specific product pages for LEED document retrieval instructions. Introduction 2-3 FiberExpress Field Termination 4-8 FX Brilliance Universal Connectors FX Brilliance Universal Installation Kits and Accessories FX Pigtails FiberExpress Patch Panel Systems FX FX FX FX FX FX FX FiberExpress Pre-Terminated Assemblies FX FX FX FX 9 - 17 UHD Housing and Shelves UHD and FX Ultra Cassettes UHD and FX Ultra Frames UHD and FX Ultra Splitter Cassettes and TAP Cassettes UHD and FX Ultra Adapters and Accessories UHD and FX Ultra Wall Mount and Accessories Patch Rack Mount, Wall Mount Patch Panels, Adapter Strips and Accessories Patch Cords Hydra Patch Cords MPO Trunk Assemblies Multi-Fiber Cable Assemblies FiberExpress Workstation Connectivity FX Multi Box (M-Box) and MDVO Multimedia Outlet Box Multi-User Outlet Box, MDVO Fiber Adapter Modules, KeyConnect Fiber Adapter Modules and Standard Duplex Fiber Adapters FiberExpress Secure/Keyed LC System FiberExpress Optical Fiber Cables Fiber Cable Reference FX Interconnect Cables FX Breakout Cables FX Distribution Cables FX Armored Distribution Cables FX Hybrid Distribution Cables FX Reel-In-A-Box Packaging FX uMini Distribution Cables Single-Jacket, All Dielectric Loose Tube Cables Double-Jacket, Armored Loose Tube Cables Double-Jacket, Heavy-Duty Loose Tube Cables Central Tube Cables FX Drop Cables Part Number Index SmartPart Number Configurator Customer Service and Other Belden Contacts 2 4 5 6-8 1.800.BELDEN.1 (800.235.3361) 9 10-12 13 14 15 16 17 18-27 18-20 21-22 23-25 26-27 28-29 28 29 30 31-53 31 32 33 34-37 38-41 42 43 44-46 47-48 49-50 51 52 53 54-58 59 Back Cover www.belden.com Faster. Easier. Better. A Complete Approach to Fiber Optic Cabling Belden FX Systems are available in a variety of performance levels to meet the value and price point for a wide variety of applications. Each system is uniquely color-coded for easy identification in the field. The following is a recap of the five Belden FX Systems that are offered today: Belden System Standard FX OM1 FX OM2 FX OM3 FX OM4 FX SM A1 OM1 - 62.5 μm Multimode Non-Bend Insensitive TIA-492AAAA ANSI/TIA-568-D.3 ISO/IEC 11801 OM2 - 50 μm Multimode Bend Insensitive TIA-492AAAB ANSI/TIA-568-D.3 ISO/IEC 11801 OM3 - 50 μm Multimode Bend Insensitive TIA-492AAAC ANSI/TIA-568-D.3 ISO/IEC 11801 OM4 - 50 μm Multimode Bend Insensitive TIA-492AAAD ANSI/TIA-568-D.3 ISO/IEC 11801 OS2 - 9 μm Singlemode Bend Insensitive TIA-492CAAB ANSI/TIA-568-D.3 ISO/IEC 11801 ITU G.657.A1 Legacy 1G up to 275 m Not Recommended for New Designs 10G up to 300m 1G up to 550 m Ethernet Applications 40G/100G up to 100m 10G up to 400 m 10G up to 30/40 km 40G/100G up to 150 m 40G/100G up to 10/40 km 16G up to 125 m 4/8/16G up to 10 km 4G up to 380 m Fibre Channel Applications Legacy 1G up to 300 m Not Recommended for New Designs 8G up to 300 m 16G up to 100 m Fiber Cable Assemblies Jacket Color Orange Orange Aqua Erika Violet Aqua (optional)* Yellow Connector and Adaptor Color Beige Black Aqua Erika Violet Aqua (optional)* Blue Green (APC) MPO-12 0.5 dB LC/SC/ST 0.25dB MPO-12 0.5 dB LC/SC/ST 0.25dB MPO-12 0.35 dB LC/SC/ST 0.25dB MPO-12 0.2 dB LC/SC/ST 0.15dB MPO-12 0.75 dB LC/SC/ST 0.35dB Pre-Term Connector Loss Fiber Cable Loss Min. EMB (MHz∙km) Min. OFL Bandwidth (MHz∙km) Tight Buffer (900 μm) Tight Buffer (900 μm) Tight Buffer (900 μm) Tight Buffer (900 μm) Tight Buffer (900 μm) 0.5 dB @ 1310nm 3.0 dB @ 850 nm 3.25 dB @ 850 nm 3.5 dB @ 850 nm 3.5 dB @ 850 nm 0.5 dB @ 1550 nm 1.0 dB @ 1300 nm 1.2 dB @ 1300 nm 1.2 dB @ 1300 nm 1.2 dB @ 1300 nm Enterprise Loose Tube (250 μm) Enterprise Loose Tube (250 μm) Enterprise Loose Tube (250 μm) Enterprise Loose Tube (250 μm) Enterprise Loose Tube (250 μm) 0.5 dB @ 1310nm 3.0 dB @ 850 nm 3.25 dB @ 850 nm 3.5 dB @ 850 nm 3.5 dB @ 850 nm 0.5 dB @ 1550 nm 1.0 dB @ 1300nm 1.0 dB @ 1300nm 1.2 dB @ 1300nm 1.2 dB @ 1300nm N/A N/A 2000 @ 850 nm 4700 @ 850 nm N/A 200 @ 850 nm 500 @ 1300 nm 500 @ 850 nm 500 @1300 nm 1500 @ 850 nm 500 @1300 nm 3500 @ 850 nm 500 @1300 nm N/A * Belden Standard OM4 products use Erika Violet cable with Erika Violet connectors. Aqua OM4 cable and connectors are available as Tailored products by selecting OM4 fiber with the Aqua color code. Other combinations of fiber type and color will continue to use the default connector colors with the specified cable jacket color. www.belden.com 1.800.BELDEN.1 (800.235.3361) 3 FiberExpress Field Termination FX Brilliance Universal Connectors Brilliant in design and universal in implementation, FX Brilliance Universal no-epoxy, no-polish, no-crimp field-installable connectors make fiber field termination faster, easier and better with our industry-leading design. FASTER • Faster fiber termination in as few as 5 seconds • Faster installation proficiency through simple termination technique • Faster 250 μm direct installation eliminating break-out kits EASIER • Easier with no epoxy or polishing • Easier no-crimp design • Easier with duplex clips to hold TX/RX pairs together FX Brilliance Universal Connectors BETTER Three Simple Steps • Better termination yield with integrated VFL feedback • Better universal cable support for 250 μm, 900 μm, 2 mm Jacketed, 3 mm Jacketed 1 Insert Fiber • Better universal fiber support for OM1, OM2, OM3, OM4 as well as OS2 Connector Performance Maximum Insertion Loss Multimode Singlemode UPC Singlemode APC Typical Insertion Loss 0.5 dB 0.5 dB 0.5 dB Return Loss 0.2 dB 0.3 dB 0.3 dB 25 dB 50 dB 60 dB Belden Part Number 2 Description Multimode, OM1 Activate Tab LC with 900 μm Boot, 25 per package SC with 900 μm Boot, 25 per package ST with 900 μm Boot, 25 per package AX105200-B25 AX105205-B25 AX105210-B25 Multimode, OM3/OM4 Aqua AX105202-B25 AX105207-B25 AX105212-B25 Multimode, OM4 Erika Violet AX105252-B25 AX105253-B25 AX105254-B25 Replace -B25 with -S1 for sample 1 per package. Belden Part Number Description 3 Install Boot LC with 900 μm Boot SC with 900 μm Boot ST with 900 μm Boot Singlemode, OS2 Singlemode, OS2/APC 1 per package 25 per package 1 per package 25 per package AX105203-S1 AX105208-S1 AX105213-S1 AX105203-B25 AX105208-B25 AX105213-B25 – AX105209-S1 – – AX105209-B25 – FX Brilliance Universal includes a boot for 900 μm Tight Buffered fiber. Boots for 2 mm/3 mm Jacketed fiber are sold separately. Description 250 μm Boot, 25 per package 2 mm Jacketed Boot, 25 per package 3 mm Jacketed Boot, 25 per package Description LC Duplex Clip (Black), 25 per package SC Duplex Clip (Black), 25 per package 4 1.800.BELDEN.1 (800.235.3361) Belden Part Number FXBUBO250B25N AX105214-B25 AX105215-B25 Belden Part Number FXBUCLLDB25N FXBUCLSDB25N www.belden.com Faster. Easier. Better. FiberExpress Field Termination (continued) FX Brilliance Universal Installation Kits and Accessories Improve Installer Comfort, Repeatability and Performance Although termination of the FX Brilliance Universal connector can be done with no specialized tools, installation kits are available with all the tools necessary to prepare the fiber as well as to provide a stable work platform to achieve optimal installation results. FX Brilliance Installation Kit Description Belden Part Number Precision Installation Kit (Basic Kit, Fiber Preparation Tools, Precision Cleaver and Visual Fault Locator) AX104271 FX Brilliance Accessories AX104271, Precision Installation Kit Description Precision Cleaver Precision Cleaver Replacement Blade (for FC-7 cleaver) Precision Cleaver Replacement Blade (for FC-7R cleaver) Support Handle with Adapters Support Handle LC Adapter Support Handle SC Adapter Support Handle ST Adapter Visual Fault Locator (VFL-250) with Adapter Cords Visual Fault Locator (VFL-125) LC-LC Adapter Cord Visual Fault Locator (VFL-125/250) LC-SC Adapter Cord (valid for ST also) Visual Fault Locator (VFL-250) SC-SC Adapter Cord (valid for ST also) Visual Fault Locator (VFL-125) LC-SC/APC Adapter Cord & Support Handle SC/APC Adapter Visual Fault Locator (VFL-250) SC-SC/APC Adapter Cord & Support Handle SC/APC Adapter Fiber/Cable Stripper Pen Marker Refurbishing Materials (80 alcohol wipes and a black pen marker) Safety Glasses Scissors Tweezers Waste Bottle Belden Part Number AX104286 AX104293 AX104593 AX104276 AX104289 AX104290 AX104291 AX104283 AX203567 AX203568 AX203569 AX203895 AX203930 AX103151 AX104279 AX100951 AX104282 AX104280 AX104278 AX104281 AX104286, Precision Cleaver Ensure Durable Rugged Installation on 250 μm Fiber Field Breakout kits are available to provide a durable 900 μm coating for 250 μm fibers to ensure optimal retention, flex and twist support without sacrificing the outdoor performance of loose-tube cables or the small diameter of mini-distribution cables. AX104276, Support Handle with Adapters FX Breakout Kits Description Breakout Kit for 2.0 mm Subunits, 6-fiber, 1-Pack Breakout Kit for 3.0 mm Subunits, 12-fiber, 1-Pack Breakout kit for 5.2 mm Subunits (Central Tube), 6-fiber, 1-Pack Breakout kit for 5.2 mm Subunits (Central Tube), 12-fiber, 1-Pack Belden Part Number AX101100 AX101101 AX104695 AX104696 When used with the VFL, a light can be seen through the clear window on the connector body until a fiber has been properly terminated You can use the FX UHD Splice Cassette (see page 4) with the 250 μm Boot to eliminate the need to install a Break-out kit. www.belden.com 1.800.BELDEN.1 (800.235.3361) 5 FiberExpress Field Termination (continued) FX Pigtails Established technology with a pedigree of resilience. Traditional fusion splice-on connectors with pigtails provide factory-polished performance with field-termination convenience within harsh environments. FASTER • Faster connector identification with color-coded pigtail kits • Faster delivery with standard LC, SC or ST 2 meter pigtail kits • Faster installation with Mass-Fusion pigtail kits EASIER • Easier field-termination with factory pre-terminated connectors • Easier ordering with intuitive SmartPart numbers FT4LC250PR12, FX Mass-fusion Pigtail, OM4 Erika Violet, LC Simplex, 2 m BETTER • Better quality with precision factory-polished connectors • Better insertion loss at 0.2 dB MPO-12 and 0.15 dB Max IL OM4 Standard Performance Description FX OM1 FX OM3 FX OM4 FX SM FX SM/APC 3.5/1.2 – 3.25/1.2 – 0.25 PC - 30 0.25 PC - 30 0.15 PC - 30 0.35 UPC - 55 0.35 APC - 65 FX OM1 FX OM3 FX OM4 FX SM FX SM/APC 3.5/1.2 – 3.25/1.0 – 3.0/1.0 – Cable Performance - LC/SC/ST IL Max. 850 nm/1300 nm (dB/Km) IL Max. 1310 nm/1550 nm (dB/Km) Fire Rating FT4LCRIBPS019ME, FX Mass-fusion Pigtail, OM4 Erika Violet, LC Simplex, 9 m Cable Style Standard Length Connector Performance - LC/SC/ST IL Max. (dB) Polish - RL Typ. (dB) Description 3.0/1.2 – – 0.5/0.5 OFN ( 3 m) OFNR for all other cables (> 3 m) 900 μm Color-coded fiber kit (6 or 12 colors from TIA-598) 900 μm single fiber OM1-Gray, OM3/OM4-Aqua, OS2-White 250 μm Bare ribbon fiber Interconnect Simplex/Duplex, 2 mm/3 mm cords Interconnect Ribbon 12-fiber cable 2 meters Cable Performance - MPO IL Max. 850 nm/1300 nm (dB/Km) IL Max. 1310 nm/1550 nm (dB/Km) FTSLC900PR12, FX LC Color-coded Pigtail Kit, Singlemode – 0.5/0.5 Fire Rating OFN ( 3 m) Cable Style 250 μm Bare ribbon fiber Interconnect Ribbon 12-fiber cable Interconnect Mini-Round 2 mm Standard Length Connector Performance - MPO IL Max. (dB) Polish - RL Typ. (dB) 2 meters 0.5 PC - 30 0.35 PC - 30 0.2 PC - 30 – – 0.75 APC - 60 The default fan-out is 0.5 m when there is a transition in a pigtail kit: 900 μm Color-coded fiber kit or 250 μm Bare Ribbon fiber (R06 or R12). 6 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Field Termination (continued) FX Pigtails Standard Mass-Fusion Pigtail Kits (Connector on 250 μm Ribbon) Mass fusion splicing can fuse up to all 12 fibers in one ribbon at once. Mass fusion pigtails come with all 12 fibers terminated and a ribbonized open end. Splicers splice entire ribbons simultaneously. Belden Part Number Description MPO-12 (m) LC SC OM1 OM3 OM4 OS2 OS2/APC – – FT1SC250PR12 FT3MM250PS01 FT3LC250PR12 FT3SC250PR12 FT4MM250PS01 FT4LC250PR12 – – FTSLC250PR12 FTSSC250PR12 FTSMM250PS01 FTSLB250PR12 FTSSB250PR12 FT3MM250PS01, FX MPO Bare Ribbon Pigtail, OM3 Aqua, MPO(m), 2 m Standard Mass-Fusion Color-coded Pigtail Kits contain a 12-fiber ribbon with a 0.5 m 900 μm fanout with 12 connectors, 2 m in total length. Standard Pigtail Kits (Connector on 900 μm Fiber) Belden Part Number Description LC SC ST OM1 OM3 OM4 OS2 OS2/APC – FT1SC900PR12 FT1ST900PR12 FT3LC900PR12 FT3SC900PR12 FT3ST900PR12 FT4LC900PR12 FT4SC900PR12 – FTSLC900PR12 FTSSC900PR12 FTSST900PR12 FTSLB900PR12 FTSSB900PR12 – Standard Color-coded Pigtail Kits contain 12 color-coded 900 μm fibers, 2 m in length. Standard Single Pigtails (Connector on Tight buffer Fiber) LC SC ST FT4MMRIBPS019ME, FX MPO Jacketed Ribbon Pigtail, OM4 Erika Violet, MPO(m), 9 m Belden Part Number Description OM1 OM3 OM4 OS2 OS2/APC – FT1SC900PS01 FT1ST900PS01 FT3LC900PS01 FT3SC900PS01 FT3ST900PS01 FT4LC900PS01 FT4SC900PS01 – FTSLC900PS01 FTSSC900PS01 FTSST900PS01 FTSLB900PS01 FTSSB900PS01 – Standard Single 900 μm Tight Buffer Pigtails contain 1 unit, 2 m in length. Standard Single Pigtails (Connector on Jacketed Fiber) Belden Part Number Description MPO-12(m) LC LC Duplex SC SC Duplex ST Simplex OM1 – – – FT1SC3MMPS01 FT1SD3MMPS01 FT1ST3MMPS01 OM3 OM4 FT3MM3MMPS01 FT4MM3MMPS01 FT3LC2MMPS01 FT4LC2MMPS01 FT3LD2MMPS01 FT4LD2MMPS01 FT3SC3MMPS01 FT4SC3MMPS01 FT3SD3MMPS01 FT4SD3MMPS01 FT3ST3MMPS01 – OS2 – FTSLC2MMPS01 FTSLD2MMPS01 FTSSC3MMPS01 FTSSD3MMPS01 FTSST3MMPS01 OS2/APC FTSMM3MMPS01 FTSLB2MMPS01 FTSLA2MMPS01 FTSSB3MMPS01 FTSSA3MMPS01 – FTSSB3MMPS01, FX Pigtail, Jacketed Simplex 3.0 mm Cord, OS2 Yellow, SC/APC Simplex Standard Single-Jacketed Pigtails contain 1 unit, 2 m in length. Fusion Splice Heat Shrink Protector Sleeves Description Belden Part Number Heat Shrink Splice Protector Sleeves, 900 μm to 900 μm, 2.5 mm round x 60 mm long, 25/package Heat Shrink Splice Protector Sleeves, 900 μm to 250 μm, 2.0 mm round x 40 mm long, 25/package Heat Shrink Splice Protector Sleeves, 250 μm to 250 μm, 1.5 mm round x 40 mm long, 25/package Heat Shrink Splice Protector Sleeves, 250 μm 12-fiber Ribbon, oval x 40 mm long, 12/package FXFUHS900AB25 FXFUHS9T2CB25 FXFUHS250DB25 FXFUHSRIBEB12 FT4LD2MMPS01, FX Pigtail, Jacketed Duplex 2.0 mm Cord, OM4 Erika Violet, LC Duplex See page 8, Tailored Pigtails - Building a SmartPart Number table, for more options. Mass-fusion pigtails drastically reduce the amount of labor time spent on fiber terminations (up to 50%) and increase maximum of fiber terminations per day (around 3.5 times more than traditional single splicing). www.belden.com 1.800.BELDEN.1 (800.235.3361) 7 FiberExpress Field Termination (continued) FX Pigtails Tailored Pigtails - Building a SmartPart Number FX Feild Termination 1. Choose Fiber Type 2. Choose Connectors 3. Choose Cable Type 4. Choose Product Family 5. Choose Packaging 6. Choose Length FT 3 LC 900 P R12 3M Fiber Type 1 3 4 S OM1 OM3 OM4 OS2 Connectors LD LC LA LB SD SC SA SB ST MM MF LC Duplex LC Simplex LC/APC Duplex LC/APC Simplex SC Duplex SC Simplex SC/APC Duplex SC/APC Simplex ST MPO-12 (m) MPO-12 (f ) Product Family Packaging Bare Ribbon 250 μm Fiber RIB Jacketed Ribbon 900 900 μm Tight Buffer 2MM 2 mm Jacketed 3MM 3 mm Jacketed P S01 Single Pack R06 Rainbow 6 Pk R12 Rainbow 12 Pk Pigtails D Length Cable Type 250 7. Choose Jacket/ Buffer Color Buffer Color 2M 3M 4M 5M 6M 7M 8M 9M O S W Y A E D Orange Gray White Yellow Aqua Erika V. Default Color Use of Tailored part numbers: Examples: Color - Default color (D) is only used with cable type (250 μm or 900 μm) and Packaging (R06 or R12) FT3LC900PR123MD - FX Field-Termination Pigtail, OM3, LC Simplex, Tight Buffer 900 μm, Color-Coded 12-Fiber, 3 m FTSST900PR125MY - FX Field-Termination Pigtail, OS2, ST, Tight Buffer 900 μm, Color-Coded 12-Fiber, 5 m, Yellow Jacket FT3MMRIBPS014MA - FX Field-Termination Pigtail, OM3, MPO-12 (M), Jacketed Ribbon, Single-Ended, 4 m, Aqua Jacket Mass Fusion Pigtail Kits Pigtail Assembly Length (≤3 m) Long Pigtail Assembly Length (≥4 m) Long Pigtail Assembly Length (≥4 m) 0.5 m (19.7") Fanout Length 0.5 m (19.7") Fanout Length Ribbon Length Connector 1 Connector 2 Connector 2 Connector 3 Connector 3 Connector 4 Connector 4 Connector 5 1 2 3 4 5 6 7 8 9 10 11 12 PULL Ribbon Length Connector 1 12-fiber Jacketed Ribbon (250 μm Ribbon Fiber) Connector 5 Connector 6 Connector 6 Transion Transion Connector 7 Connector 7 Pigtail Assembly Length (≤3 m) 12-fiber Ribbon (250 μm Ribbon Fiber) Connector 9 Connector 8 Connector 10 Connector 10 Connector 11 Connector 11 Connector 12 12-fiber Jacketed Ribbon (250 μm Ribbon Fiber) Connector 9 1 2 3 4 5 6 7 8 9 10 11 12 PULL Connector 8 Connector 12 900 μm Legs 12-fiber Ribbon (250 μm Ribbon Fiber) 900 μm Legs Pigtail Kits Single Pigtails Long Pigtail Assembly Length (≥4 m) Pigtail Assembly Length (≤3 m) Pigtail Assembly Length 0.5 m (19.7") Fanout Length Jacketed Length Connector 1 Connector 1 Connector 2 Connector 2 Connector 3 Connector 3 Connector 4 Connector 4 Connector 5 Connector 5 Connector 6 Connector 6 Connector 1 Simplex Connector Types 900 μm Tight Buffered Fiber Simplex Connector Types Simplex Zip Interconnect Cable 2 mm/3 mm (900 μm Tight Buffered Fiber) Connector 1 Connector 8 Connector 9 Connector 9 Connector 10 Connector 10 Connector 11 Connector 11 Connector 1 12-fiber Distribuon Cable (900 μm Tight Buffered Fiber) Duplex Connector Types Connector 12 Connector 12 900 μm Legs Connector 2 B Connector 7 Connector 8 Connector 1 900 μm Legs PULL Connector 7 A Transion MPO Connector Types Duplex Zip Interconnect Cable 2 mm/3 mm (900 μm Tight Buffered Fiber) 1 2 3 4 5 6 7 8 9 10 11 12 12-fiber uMini-Distribuon Cable (250 μm Loose Fiber) Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions 8 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Patch Panel Systems FX UHD Housings and Shelves Elegantly simple yet uncompromisingly flexible. Ultra high-density rack-mount fiber connectivity system, crafted for effortless installation and maintenance. FASTER • Faster field-termination with high-accessibility sliding and tilting drawers • Faster pre-term installation with simple fixed shelves and cassettes EASIER Top: AX104681, FX Ultra HD 1U Patch Panel Housing Bottom: AX104683, FX UHD 4U Patch Panel Housing (shown loaded) • Easier installation with tool-less removable drawers and lightweight housings • Easier port identification with clear visible labeling • Easier to configure with flexible port count LC, SC, ST and MPO modules BETTER • Better fiber protection with covered patch cord tray • Better high density offering with 18-port modules for up to 72 LC Duplex ports per 1U • Better visibility with light colored Titanium finish FX UHD Housings Feature-rich housings are fully enclosed to provide protection for exposed 250 μm and 900 μm fibers coupled with sliding and tilting drawers to speed up and simplify installation and maintenance. Total LC Duplex/ Total LC Duplex/ Number of MPO Ports using MPO Ports using Module Bays FX Ultra Frames FX UHD Frames and Cassettes and Cassettes Description Black 72 AX104681 AX105563 96 144 AX104682 AX105564 16 192 288 AX104683 AX105565 20 240 360 AX105379 – N/A N/A N/A AX104684 AX105678 N/A N/A N/A AX105162 AX105672 4 48 2U Housing with Front and Rear Cable Tray 8 4U Housing with Front and Rear Cable Tray 4U 23” Housing with Front and Rear Cable Tray Optional 1U Splice Housing Kit, 144 splices (add up to 4 on the 4U Housing)1 Optional Patch Cord Tray Cover, 19”2 Belden Part Number Titanium 1U Housing with Front and Rear Cable Tray AX104681, FX UHD Patch Panel 1U with Mounted Splice Housing Kit (AX104684) Top: AX105164, FX UHD 1U Patch Panel Standard Shelf Bottom: AX105167, FX UHD 4U Patch Panel Recessed Shelf (shown loaded) 1. Up to 4 splice housing kits can be added to 4U housings. Splice housing kits are only compatible with standard 19” rack mount housings. 2. Use with 1U or 4U housings to protect the contents of the topmost patch cord tray. Patch cord tray cover is included with 23” housings. FX UHD Shelves, Single Cassette Holder Entry-level cost effective solutions for pre-terminated systems. Description 1U FX UHD Bezel 1U Standard Fixed Shelf 1U Recessed Fixed Shelf 4U Standard Fixed Shelf 4U Recessed Fixed Shelf Total LC Duplex/ Number of MPO Ports using Module FX Ultra Frames Bays and Cassettes 4 4 4 10 10 48 48 48 120 120 Total LC Duplex/ MPO Ports using FX UHD Frames and Cassettes 72 72 72 180 180 FX UHD Single & Double Cassette Holders Single Cassette Holder (Black Finish) Double Cassette Holder (Black Finish) 1 1 18 36 12 24 AX105813 FX UHD 1U Bezel Belden Part Number Titanium Black AX105813 AX105164 AX105165 AX105166 AX105167 AX105812 AX105673 AX105674 AX105675 AX105676 Magnetic Non-Magnetic FXFUBRSHM FXFUBRDHM FXFUBRSHM FXFUBRDHS Top: FXFUBRSHM, FX UHD Single Cassette Holder with Magnetic Attachment Bottom: FXFUBRDHM FX UHD Double Cassette Holder with Magnetic Attachment (Bottom) See the FX UHD System Product Bulletin (PB500) for further options www.belden.com 1.800.BELDEN.1 (800.235.3361) 9 FiberExpress Patch Panel Systems (continued) FX UHD and FX Ultra Cassettes FX UHD and FX Ultra Cassettes Featuring the highest density at 72 LC Duplex or MPO ports per 19” rack unit FX UHD family is the ideal choice for high-port count applications such as in the data center. Unique 1” pull-out feature of the FX Ultra family provides a medium density solution with a superior ease of use for day-to-day MAC (moves, adds and changes) within the Enterprise or cross-connect within the data center. FCSH18LDMF, FX UHD Cassette, OS2, 18 Ports, MPO-12 (female), LC Duplex, Type-A, Blue Adapters Standard Type-A Cassettes (Base12) Description Belden Part Number Patch Ports Trunk Ports (fibers) FC3U12LDMF1A, FX Ultra Cassette, OM3, 12 Ports, MPO-12 (female), LC Duplex, Type-A ALT, Aqua Adapters Family OM1 Beige Adapters LC Duplex to MPO-12(12f) Female 18 (36) 3 FX UHD* – 12 (24) 2 FX Ultra FC1U12LDMF SC Duplex to MPO-12(12f) Female 6 (12) 1 FX Ultra FC1U06SDMF SC Simplex to MPO-12(12f) Female 12 (12) 1 FX Ultra – OM3 Aqua Adapters OM4 Erika Violet Adapters OS2 Blue Adapters OS2/APC Green Adapters FC3H18LDMF FC3U12LDMF FC4H18LDMF FC4U12LDMF FCSH18LDMF FCSU12LDMF FCSH18LAMF FCSU12LAMF FC3U06SDMF FC4U06SDMF FCSU06SDMF FCSU06SAMF – – FCSU12SCMF FCSU12SBMF OS2 Blue Adapters OS2/APC Green Adapters *Optional HD Patch cord release tool AX104685 Standard Type-A-Alternate Cassettes (Base12) Description Belden Part Number Patch Ports Trunk Ports Family (fibers) FC3H12LDFS, FX UHD Splice Cassette, OM3, 12 Ports, LC duplex, Aqua Adapters OM1 Beige Adapters LC Duplex to MPO-12(12f) Female 18 (36) 3 FX UHD – 12 (24) 2 FX Ultra FC1U12LDMF1T SC Duplex to MPO-12(12f) Female 6(12) 1 FX Ultra FC1U06SDMF1T SC Simplex to MPO-12(12f) Female 12(12) 1 FX Ultra – OM3 Aqua Adapters OM4 Erika Violet Adapters FC3H18LDMF1A FC3U12LDMF1A FC4H18LDMF1E FC4U12LDMF1E FC3U06SDMF1A FC4U06SDMF1E FCSU06SDMF1B FCSU06SAMF1G – – FCSH18LDMF1B FCSH18LAMF1G FCSU12LDMF1B FCSU12LAMF1G FCSU12SCMF1B FCSU12SBMF1G Standard Splice Cassettes Belden Part Number Description Patch Ports (fibers) FCZH00BBFS, FX UHD Empty Splice Cassette OM1 Beige Adapters OM3 Aqua Adapters MPO Type-A (Key-Up/Key-Down) 12 (144) FC1H12MPFS FC3H12MPFS LC Duplex 12 (24) FC1H12LDFS FC3H12LDFS SC Duplex 6 (12) FC1H06SDFS FC3H06SDFS SC Simplex 12 (12) – – ST (Metal Adapters) 12 (12) Splice Only (No Adapters) N/A (144) OM4 Erika Violet Adapters SM Blue Adapters OS2/APC Green Adapters FC4H12MPFS – FCSH12MPFS FC4H12LDFS FCSH12LDFS FCSH12LAFS FC4H06SDFS FCSH06SDFS – – – FCSH12SBFS FCSH12STFS FCZ00BBFS FX Brilliance Universal (page 4) or FX Pigtails (page 6) and Heat Shrink Splice Protector Sleeves (page 7) sold separately. 10 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Patch Panel Systems (continued) FX UHD and FX Ultra Cassettes Standard FX UHD Angled Cassettes (Base12) Left Description Patch Ports (fibers) OM3 Aqua Adapters OM4 Erika Violet Adapters Right SM Blue Adapters OM3 Aqua Adapters OM4 Erika Violet Adapters OS2 Blue Adapters LC Duplex to MPO-12(12f) Female Type-A FC3R12LDMF FC4R12LDMF FCSR12LDMF 12(24) FC3L12LDMF FC4L12LDMF FCSL12LDMF LC Duplex to MPO-12 (12f) Female Type-A Alternate 12(24) FC3L12LDMF1A FC4L12LDMF1E FCSL12LDMF1B FC3R12lDMF1A FC4R12LDMF1E FCSR12LDMF1B SC Duplex to MPO-12(12f) Female Type-A 6 (12) FC3L06SDMF FC4L06SDMF FCSL06SDMF FC3R06SDMF FC4R06SDMF FCSR06SDMF SC Duplex to MPO-12(12f) Female Type-A Alternate 6 (12) FC3L06SDMF1A FC4L06SDMF1E FCSL06SDMF1B FC3R06SDMF1A FC4R06SDMF1E FCSR06SDMF1B FX UHD Angled Cassettes, 12 Ports, LC Duplex and 6 Ports, SC Duplex. See Tailored SmartPart numbers for Details. FX UHD Angled Cassettes (shown installed in FX UHD 1U Housing with Belden Angleflex Copper Patch Patch) Tailored FX UHD and FX Ultra Cassettes (Base12) Building a SmartPart Number Fixed Letter Series 1. Choose Fiber Type 2. Choose Product Family 3. Choose Port Count (Patch Side) 4. Choose Connector (Patch Side) 5. Choose Connector (Trunk Side) 6. Choose Polarity (Trunk) 7. Choose Adapter Color FC 3 U 03 LD MM A A Connector (Patch Side) Connector (Trunk Side) Polarity (Trunk) Adapter Color LD LA SD SC SA SB ST MM MPO-12 (m) MF MPO-12 (f) Fiber Type Product Family 1 3 4 S H U L R OM1 OM3 OM4 OS2 FX UHD FX Ultra (1” Pull) FX U Angled Left FX U Angled Right Port Count (Patch Side) 03 06 12 18 LC Duplex LC/APC Duplex SC Duplex SC Simplex SC/APC Duplex SC/APC Simplex ST A 1 Type-A Type-A ALT. T N A E B G Beige Black Aqua Erika V. Blue Green For further options contact Belden for custom Engineered solutions. www.belden.com 1.800.BELDEN.1 (800.235.3361) 11 FiberExpress Patch Panel Systems (continued) FX UHD and FX Ultra Cassettes Belden FX UHD Base8 Cassettes Optimized for SR4 and PSM4 based architectures like 40G and 100G Ethernet as well as Compute, Switch and Storage equipment with groupings of 4, 8 and 12 ports. Belden Base8 Cassettes optimize costs when used with Base8 MPO Trunks and Patch cords by eliminating dark fiber associated with SR4 & PSM4 architectures. Standard SR4 Optimizer Cassettes (Base8) Belden Part Number Description Patch Ports (fibers) Trunk Ports Family OM3 Aqua Adapters OM4 Erika Violet Adapters OS2/APC Green Adapters FC3U034MMF, FX UHD Optimizer Cassette, OM3, Aqua Adapters MPO-12(8f) Male to MPO-12(12f) Female 6 x MPO-12 (8f) 4 x MPO-12 (12f) FX Ultra FC3U064MMF FC4U064MMF FCSU064MMF 3 x MPO-12 (8f) 2 x MPO-12 (12f) FX Ultra FC3U034MMF FC4U034MMF FCSU034MMF Standard SR4 Cassettes (Base8) Belden Part Number Description Patch Ports (fibers) Trunk Ports Family OM3 Aqua Adapters OM4 Erika Violet Adapters OS2 Blue Adapters LC Duplex to MPO-12(8f) Female FCSU12LD4F, FX Ultra Cassette, OM3, 12 Ports, MPO-12 (female), LC Duplex, Type SR4 (Base8), Aqua Adapters 16 (32) 4 FX UHD FC3H16LD4F FC4H16LD4F FCSH16LD4F 12 (24) 3 FX Ultra FC3U12LD4F FC4U12LD4F FCSU12LD4F 8 (16) 2 FX Ultra FC3U08LD4F FC4U08LD4F FCSU08LD4F 4 (8) 1 FX Ultra FC3U04LD4F FC4U04LD4F FCSU04LD4F Standard SR4 Angled Cassettes (Base8) Left Description Patch Ports (fibers) OM3 Aqua Adapters OM4 Erika Violet Adapters Right OS2 Blue Adapters OM3 Aqua Adapters OM4 Erika Violet Adapters OS2 Blue Adapters FCSL12LD4F FC3L12LD4F FC4L12LD4F FCSL12LD4F LC Duplex to MPO-12(8f) Female 12 (24) FC3L12LD4F FC4L12LD4F Tailored FX UHD and FX Ultra Cassettes (Base8) Building a SmartPart Number Fixed Letter Series 1. Choose Fiber Type 2. Choose Product Family 3. Choose Port Count (Patch Side) 4. Choose Connector (Patch Side) 5. Choose Connector (Trunk Side) 6. Choose Polarity (Trunk) 7. Choose Adapter Color FC 3 U 04 LD 4M 4 A Connector (Patch Side) Connector (Trunk Side) Polarity (Trunk) Adapter Color LD LC Duplex 4M MPO-12 (8f) Male 4F MPO-12 (8f) Female Fiber Type Product Family 3 4 S H U L R OM3 OM4 OS2 FX UHD FX Ultra FX U Angled Left FX U Angled Right Port Count (Patch Side) 04 08 12 16 4 Ports 8 Ports 12 Ports 16 Ports 4 SR4 (Base8) A E B Aqua Erika V. Blue For further options contact Belden for custom Engineered solutions. 12 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Patch Panel Systems (continued) FX UHD and FX Ultra Frames Standard FX UHD and FX Ultra Frames Description Patch Ports (fibers) Belden Part Number OM3 Aqua Adapters OM4 Erika Violet Adapters SM Blue Adapters SM/APC Green Adapters MPO Type-A (Key-Up/Key-Down) 18 FX UHD – 12 FX Ultra – FF3H18MP FF3U12MP FF4H18MP FF4U12MP – – FFSH18MP FFSU12MP LC Duplex 18 (36) 12 (24) – FF1U12LD FF3H18LD FF3U12LD FF4H18LD FF4U12LD FFSH18LD FFSU12LD FFSH18LA FFSU12LA FF1U06SD FF3U06SD FF4U06SD FFSU06SD FFSU06SA – – – FFSU12SC FFSU12SB Family FX UHD FX Ultra SC Duplex 6 (12) FX Ultra SC Simplex 12 (12) FX Ultra ST 12 (12), Metal OM1 Beige Adapters FX Ultra FFSU12ST FF3H18LD, FX UHD Frame, OM3, 18 Ports, LC Duplex, Aqua Adapters – Tailored FX UHD and FX Ultra Frames Building a SmartPart Number Fixed Letter Series 1. Choose Fiber Type 2. Choose Product Family 3. Choose Port Count 4. Choose Connector for Patch Side 5. Choose Adapter Color FF 3 H 18 LD A Fiber Type Product Family 1 3 4 S H U OM1 OM3 OM4 OS2 FX UHD FX Ultra (1” Pull) Port Count (Patch Side) 03 06 12 18 Connector (Patch Side) LD LC Duplex LA LC/APC Duplex Duplex LS LC w/Shutters SD SC Duplex SC SC Simplex SA SC/APC Duplex SB SC/APC Simplex Duplex SS SC w/ Shutters SC Simplex SR w/ Shutters FF3U12LD, FX Ultra Frame, OM3, 12 Ports, LC Duplex, Aqua Adapters Adapter Color T N A E B G Beige Black Aqua Erika V. Blue Green ST ST MP MPO Up/Down MR MPO Up/Up FX UHD is a fixed bezel FX Ultra has a 1” pull-out www.belden.com 1.800.BELDEN.1 (800.235.3361) 13 FiberExpress Patch Panel Systems (continued) FX UHD and FX Ultra Splitter Cassettes and TAP Cassettes Splitter Cassette Description (Upstream/Downstream) AX104681, FX UHD Housing (shown loaded from left to right with, FCSH12SBFS, FX UHD Splice Cassette, SCSH2116SLF, FX UHD Splitter Cassette, 2 x FCSH12LAFS, FX UHD Splice Cassettes) Splitter Belden Part Number SC/APC to LC/APC Single 2x8 SCSU1208SLF SC/APC to LC/APC Single 2x16 SCSU1216SLF SC/APC to LC/APC Dual 2x8 SCSU2208SLF MPO/APC to LC/APC Quad 2x8 SCSH4208MLF LC/APC to LC/APC Quad 1x8 SCSH4108LLF LC/APC to LC/APC Dual 2x16 SCSH2216LLF SC/APC to LC/APC Dual 1x16 SCSH2116SLF SC/APC to LC/APC Single 2x32 SCSH1232SLF FX UHD and FX Ultra TAP (Traffic Analysis Port) Belden’s TAP cassettes allows for monitoring of communication over Fiber cables to ensure quality of service, and provide security/troubleshooting capabilities. TAP Cassette Belden Part Number OM4 SCSH2116SLF, FX UHD Splitter Cassette, OS2, Dual 1x16 Splitter, SC/APC Upstream Ports, LC/APC Downstream Ports OM4 (Aqua) OM3 Number TAP of Live A-Ports Ratio Live A-Port Live B-Port TAP Port TC4H06LDMFLD TC4H06LDMFLD7A TC3H06LDMFLD 6 70/30 LC Duplex MPO Female (12f) LC Duplex TC4H02LDLDLD TC4H02LDLDLD7A TC3H02LDLDLD 2 70/30 LC Duplex LC Duplex LC Duplex TC4H06LDMFMM TC4H06LDMFMM7A TC3H06LDMFMM 6 70/30 LC Duplex MPO Female (12f) MPO Male (12f) TC4H044F4F4M TC4H044F4F4M7A TC3H044F4F4M 4 Female MPO Female 70/30 MPO(8f) (8f) MPO Male (8f) SCSU1208SLF, FX Ultra Splitter Cassette, OS2, Single 2x8 Splitter, SC/APC Upstream Ports, LC/APC Downstream Ports TC4H044F4F4M, OM4 TAP Cassette, 4 Live A MPO (8f) Ports, 4 MPO (8f) TAP Ports Splitters beginning with the prefix ”SCSU” represent Belden's FX Ultra cassette family. These cassettes feature our unique 1” pull-out feature that delivers superior ease of use for day-to-day MAC (moves, adds, and changes). 14 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Patch Panel Systems (continued) FX UHD and FX Ultra Adapters and Accessories Standard FX Ultra KeyConnect Frames Patch Ports 6 8 Description Belden Part Number FX Ultra KeyConnect Frame 6-Port FX Ultra KeyConnect Frame 8-Port FFZH06KC FFZH08KC KeyConnect Fiber Modules Belden Part Number Description LC Duplex - OM3 (Aqua Adapter) LC Duplex - OM4 (Erika Violet Adapter) SC Simplex OM1 (Beige Adapter) SC Simplex - OM3 (Aqua Adapter) ST- Metal Almond AX104937 AX105641-AL AX102683 AX105643-AL AX102242 Elec. White AX104938 AX105641-EW AX102684 AX105643-EW AX102243 Black AX104939 AX105641-BK AX102685 AX105643-BK AX102244 FFZH06KC, FX Ultra KeyConnect Frame, 6-Port Standard Copper KeyConnect Adapters Belden Part Number Description Black AX104024 AX102283 AX104215 AX101321 10GX RJ45 Coupler 10GX RJ45 Modular Jack CAT6+ RJ45 Coupler CAT6+ RJ45 Modular Jack Blue AX104019 AX102288 AX104210 AX101326 White AX104023 AX102282 AX104214 AX101320 Above adapters are for Black Bezels. Contact your local Belden representative for a complete listing of KeyConnect adapters in other colors. AX104572, FX Color-coded Icon Kit, (shown on frame) Standard FX UHD Accessories Description FX UHD Blank Plate FX UHD Patch Cord Release Tool FX Ultra LC Duplex Color-coded Icon Kit FX UHD Fiber Management Spool kit, includes base plates and eight spool segments 1U Rackmount Enclosure for Cable Tray Mounting 1U 19” to 23” Extender Bracket 2U 19” to 23” Extender Bracket 4U 19” to 23” Extender Bracket Belden Part Number FFZH00BB AX104685 AX104572 AX105700 XPE-S0003 9810-0100 9811-0200 9813-0400 AX104024, 10GX RJ45 Coupler AX105700, FX UHD Fiber Management Spool Kit XPE-S0003, FX UHD Basket Hanger for 1U FX UHD Patch Panel Housings and Shelves. www.belden.com 1.800.BELDEN.1 (800.235.3361) 15 FiberExpress Patch Panel Systems (continued) FX UHD Wall Mount Clean, simple, lightweight wall mount unit that accepts all cassettes and frames from the FX UHD ecosystem. The FX UHD wall mount is a modular platform; A vertically stacked configuration creates an interconnect, while the patching spaces can be combined in a horizontal configuration to make a proper cross-connect. There are two separate compartments, one for the main service area (lockable) and one for the patching space. Ideal for MDUs and Passive Optical LAN applications.  FX UHD Wall Mount AX106818, FX UHD Stackable Wall Mount Patch Panel Description Belden Part Number FX UHD Wall Mount Patch Panel, Black FX UHD Wall Mount Patch Panel, Gray AX106817 AX106818 4 cassettes; 4 frames; 48 fibers (SC, SCD, ST, LCD); 4 FXU Fusion Trays, 8-inch (AX103912) FX Ultra Wall Mount and Accessories AX103928, FX Ultra Stackable Wall Mount Patch Panel Resolute protection while maintaining the utmost adaptability. Complete selection of fiber enclosures provides effortless security and protection while leveraging both the flexibility and density of the FX UHD frames and cassettes. FASTER • Faster installation with easy access and lightweight housing • Faster installation with pre-terminated cassettes EASIER • Easier configuration with FX UHD and FX Ultra modules in LC, SC and ST • Easier security with optical door lock AX103930, FX Ultra Wall Mount Splice Enclosure • Easier expansion with stackable design BETTER • Better with support for Pre-Term and Field-Term including splicing • Better management with independent doors for trunk and patching sides • Better density with up to 36 LC Duplex ports FX Ultra Wall Mount Description AX103928 and AX103932, FX Ultra Wall Mount Patch Panel with Spacer Number of Module Bays Splice Trays Belden Part Number 2 0 2 x 8” (Up to 48-Splices) 4 x 10” (Up to 144-Splices) AX103928 AX103930 Stackable Wall Mount Patch Panel, Black Stackable Wall Mount Splice Enclosure Splice trays sold separately FX Ultra Splice Trays Description 8” Splice Tray 10” Splice Tray Splices per Tray Belden Part Number 24 36 AX103912 AX103913 All splice trays accommodate 2.5 mm OD single fiber splice protectors up to 80 mm in length or part number FXFUHS900AB25 FX Ultra Wall Mount Accessories Description FX Ultra Splice Trays 16 2-inch Spacer, Black Door Lock Kit 1.800.BELDEN.1 (800.235.3361) Belden Part Number AX103932 AX103934 www.belden.com Faster. Easier. Better. FiberExpress Patch Panel Systems (continued) FX Patch Rack Mount, Wall Mount Patch Panels, Adapter Strips and Accessories Economical yet effective. Low to medium density rack mount fiber panels with simple adapter strips are the mainstay for fiber field termination. FASTER • Faster access to rear side (trunk) connectivity without removing patch cords EASIER • Easier on the budget with economical adapter strips AX100041, FX 12/24 Port (1U) Rack Mount Patch Panel • Easier access to the trunk side connectivity with swing out faceplate BETTER • Better support for mixed field-term connectivity including splicing • Better use of valuable space through a compact footprint Rack Mount Patch Panels Maximum Number of Adapter Strips 2 4 4 8 Description 1U Rack Mount 2U Rack Mount 3U Rack Mount (Rear Access) 4U Rack Mount Splice Trays Belden Part Number 1 x 8” (Up to 24-Splices) 2 x 8” (Up to 48-Splices) 2 x 8” (Up to 48-Splices) 4 x 8” (Up to 96-Splices) AX100041 AX100068 AX104934 AX100116 Splice Trays Belden Part Number 1 x 8” (Up to 24-Splices) 2 x 8” (Up to 48-Splices) 4 x 8” (Up to 96-Splices) AX100495 AX100540 AX100542 AX100068, FX 24/48 Port (2U) Rack Mount Patch Panel (shown loaded) Wall Mount Patch Panels Maximum Number of Adapter Strips 2 4 8 Description Small Wall-Mount Medium Wall-Mount Large Wall-Mount AX104934, FX (3U) Rack Mount Patch Panel (Rear Access) (shown loaded) Standard Optical Fiber Adapter Strips Belden Part Number Patch Ports (fibers) OM1 Beige Adapters OM3 Aqua Adapters SM Blue Adapters SM/APC Green Adapters LC Duplex 12 (24) FX Patch 6 (12) FX Patch AX101741 AX101729 – – AX101743 AX101731 AX105561 AX105537 SC Duplex 6 (12) FX Patch 3 (6) FX Patch AX100098 AX100094 – – AX101409 AX101407 AC301420 – SC Simplex 12 (12) FX Patch – – AX100532 AC302349 ST 12 (12) 6 (6) Family FX Patch FX Patch AX100528 AX100534 AX100116, FX 48/96 Port (4U) Rack Mount Patch Panel (shown loaded) – – Standard Optical Fiber Accessories Description FX Patch Blank Strip 1U Front Cover, Smoked Plexiglas 8” Splice Kit (Tray, Holders, Wiremarkers & Cover) Belden Part Number AX100066 AX100045 A0649869 AX100495, Small Wall Mount www.belden.com 1.800.BELDEN.1 (800.235.3361) 17 FiberExpress Pre-Terminated Assemblies FX Patch Cords Uncomplicated, robust, versatile and conveniently available. Superior quality and performance FX patch cords deliver a robust design to withstand the rigours of daily use in both off- the-shelf standard configurations and rapid custom tailored installations. FASTER • Faster delivery with off-the shelf availability of standard items • Faster identification of fiber type with Erika Violet for OM4 cable and connectors EASIER • Easier installation in dense cable trays with small diameter cord options FX MPO-12(f) Patch Cords, Assortment • Easier ordering with simple intelligent SmartPart Numbers • Easier polarity management with industry leading easy-to-use duplex clips BETTER • Better architectural flexibility with low-loss OM4 0.2 dB MPO and 0.15 dB LC connectors • Better ruggedization with larger diameter cord options • Better flexibility with multiple connector options including LC, SC, ST and MPO • Better quality through exhaustive design validation against TIA standards FX LC Duplex Patch Cords, Assortment FX Patch Cords - Standard Performance Description FX OM1 FX OM3 3.5/1.2 – 3.25/1.2 – FX OM4 FX SM FX SM/APC Cable Performance - LC/SC/ST IL Max. 850 nm/1300 nm (dB/Km) IL Max. 1310 nm/1550 nm (dB/Km) Fire Rating Cable Style FX LC Duplex UHD Uniboot Patch Cords, Assortment FX SC Duplex Patch Cords, Assortment 3.0/1.2 – – 0.5/0.5 LC/SC/ST: Riser LC: Interconnect Duplex Zip 2 mm LC Uniboot: Interconnect Mini-Round 2 mm SC/ST/Hybrid: Interconnect Duplex Zip 3 mm Connector Performance - LC/SC/ST IL Max. (dB) Polish - RL Typ. (dB) Polarity Cable Performance - MPO IL Max. 850 nm/1300 nm (dB/Km) IL Max. 1310 nm/1550 nm (dB/Km) Fire Rating Cable Style Connector Performance - MPO IL Max. (dB) Polish - RL Typ. (dB) Polarity 0.25 PC - 30 0.25 PC - 30 3.5/1.2 – 3.25/1.0 – 0.5 PC - 30 0.35 PC - 30 0.15 PC - 30 A-TO-B / B-TO-A 0.35 UPC - 55 0.35 APC - 65 3.0/1.0 – – 0.5/0.5 Plenum MPO-12: Interconnect Mini-Round 2 mm 0.2 PC - 30 Type-B – – 0.75 APC - 60 FX Accessory Duplex Clips Belden Part Number Description LC Duplex Mini-LC Duplex OM1 OM3 OM4 OS2 OS2 Beige Aqua Erika Violet Blue Green FXFACLLDB25T FXFACLLDB25A FXFACLLDB25E FXFACLLDB25B FXFACLLDB25G FXFACLLMB25N (Black) FX ST Patch Cords, Assortment 18 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Pre-Terminated Assemblies (continued) FX Patch Cords Standard FX Patch Cords Length (m) OM1 Beige/Orange OM3 Aqua OM4 Erika Violet MPO-12(8f) Female to MPO-12(8f) Female - Base8 2 – FP34F4F002M FP44F4F002M 3 – FP34F4F003M FP44F4F003M 5 – FP34F4F005M FP44F4F005M MPO-12(12f) Female to MPO-12(12f) Female - Base12 2 – FP3MFMF002M FP4MFMF002M 3 – FP3MFMF003M FP4MFMF003M 5 – FP3MFMF005M FP4MFMF005M MPO-24 Female to MPO-24 Female 2 3 5 – – – FP3NFNF002M FP3NFNF003M FP3NFNF005M FP4NFNF002M FP4NFNF003M FP4NFNF005M LC Duplex UHD Uniboot to LC Duplex UHD Uniboot 2 – FP3LULU002M FP4LULU002M 3 – FP3LULU003M FP4LULU003M 5 – FP3LULU005M FP4LULU005M LC Duplex to LC Duplex 2 FP1LDLD002M FP3LDLD002M FP4LDLD002M 3 FP1LDLD003M FP3LDLD003M FP4LDLD003M 5 FP1LDLD005M FP3LDLD005M FP4LDLD005M SC Duplex to SC Duplex 2 FP1SDSD002M FP3SDSD002M FP4SDSD002M 3 FP1SDSD003M FP3SDSD003M FP4SDSD003M 5 FP1SDSD005M FP3SDSD005M FP4SDSD005M ST to ST (Duplex Cord) 2 FP1STST002M FP3STST002M FP4STST002M 3 FP1STST003M FP3STST003M FP4STST003M 5 FP1STST005M FP3STST005M FP4STST005M Hybrid: LC Duplex to SC Duplex 2 FP1LDSD002M FP3LDSD002M FP4LDSD002M 3 FP1LDSD003M FP3LDSD003M FP4LDSD003M 5 FP1LDSD005M FP3LDSD005M FP4LDSD005M Hybrid: SC Duplex to ST 2 FP1LDST002M FP3LDST002M – 3 FP1LDST003M FP3LDST003M – 5 FP1LDST005M FP3LDST005M – LC Simplex UHD to LC Simplex UHD, Simplex cord 2 – – – 3 – – – 5 – – – OS2 Blue/Yellow OS2/APC Green/Yellow – – – FPS4F4F002M FPS4F4F003M FPS4F4F005M – – – FPSMFMF002M FPSMFMF003M FPSMFMF005M – – – FPSNFNF002M FPSNFNF003M FPSNFNF005M FPSLULU002M FPSLULU003M FPSLULU005M – – – FPSLDLD002M FPSLDLD003M FPSLDLD005M FPSLALA002M FPSLALA003M FPSLALA005M FPSSDSD002M FPSSDSD003M FPSSDSD005M FPSSASA002M FPSSASA003M FPSSASA005M FPSSTST002M FPSSTST003M FPSSTST005M – – – FPSLDSD002M FPSLDSD003M FPSLDSD005M FPSLASA002M FPSLASA003M FPSLASA005M FPSLDST002M FPSLDST003M FPSLDST005M – – – FPSLILI002M FPSLILI003M FPSLILI005M FPSLFLF002M FPSLFLF003M FPSLFLF005M FP4LULU003M, LC Duplex UHD Uniboot to LC Duplex UHD Uniboot, OM4 Erika Violet FP4LDLD003M, LC Duplex to LC Duplex, Duplex Zip Cord, OM4 Erika Violet FP3LDSD003M, Hybrid LC Duplex to SC Duplex, OM3 Aqua FPSSDST003M, Hybrid SC Duplex to ST, OS2 Blue FPSLILI00M5, LC Simplex UHD to LC Simplex UHD, OS2 Yellow LC Duplex UHD Uniboot: Easy tool-free removal, flexible Pull-tab, better airflow, high density applications (FX UHD 18-port modules). www.belden.com 1.800.BELDEN.1 (800.235.3361) 19 FiberExpress Pre-Terminated Assemblies (continued) FX Patch Cords Standard FX Patch Cords FX Patch Cord 1. Choose Fiber Type 3 FP 3. Choose Connector 2 2. Choose Connector 1 LD LD Fiber Type Connector 1 Connector 2 1 3 4 S LD LC LH LI LU LE LF SD SA ST 4F MF NF LD LA LH LI LU LE LF SD SA ST 4F MF NF OM1 OM3 OM4 OS2 4. Choose Length* LC Duplex LC/APC Duplex LC Duplex UHD LC Duplex UHD LC Duplex UHD Uniboot LC/APC Duplex UHD LC/APC Simplex UHD SC Duplex SC/APC Duplex ST MPO-12 (F) Base 8 MPO-12 (F) MPO-24 (f) 003M Length* LC Duplex LC/APC Duplex LC Duplex UHD LC Simplex UHD LC Duplex UHD Uniboot LC/APC Duplex UHD LC/APC Simplex UHD SC Duplex SC/APC Duplex ST MPO-12 (F) Base 8 MPO-12 (F) MPO-24 (f) 00M3 to 015M *use M as decimal Tailored FX Patch Cords FX Patch Cord 1. Choose Fiber Type 2. Choose Connector 1 3. Choose Connector 2 4. Choose Length* 5. Choose Fire Rating 6. Choose Cable Construction 7. Choose Polarity 8. Choose Jacket Color FP 3 LD LD 003M R 3 X A Fiber Type Connector 1 1 2 3 4 S OM1 OM2 OM3 OM4 OS2 LD LC LM LA LB LH LI LU LE LF SD SC SA SB ST 4M 4F MM MF NM NF LC Duplex LC Simplex Mini-LC Duplex LC/APC Duplex LC/APC Simplex LC Duplex UHD LC Simplex UHD LC Duplex UHD Uniboot LC/APC Duplex UHD LC/APC Simplex UHD SC Duplex SC Simplex SC/APC Duplex SC/APC Simplex ST MPO-12 (M) Base 8 MPO-12 (F) Base 8 MPO-12 (M) MPO-12 (F) MPO-24 (m) MPO-24 (f) Connector 2 LD LC LM LA LB LH LI LU LE LF SD SC SA SB ST 4M 4F MM MF NM NF ZZ LC Duplex LC Simplex Mini-LC Duplex LC/APC Duplex LC/APC Simplex LC Duplex UHD LC Simplex UHD LC Duplex UHD Uniboot LC/APC Duplex UHD LC/APC Simplex UHD SC Duplex SC Simplex SC/APC Duplex SC/APC Simplex ST MPO-12 (M) Base 8 MPO-12 (F) Base 8 MPO-12 (M) MPO-12 (F) MPO-24 (m) MPO-24 (f) OPEN Length* Fire Rating 00M3 to 300M M Meters R P L use M as decimal Riser Plenum LSZH Cable Construction 2 3 4 5 6 7 Duplex ZipCord 2.0 mm Duplex ZipCord 3.0 mm Simplex Cord 2.0 mm Simplex Cord 3.0 mm Round 2.0 mm Round 3.0 mm Jacket Color Polarity X S A B C A/B (Cross) A/A (Straight) Type-A Type-B Type-C O Y A E Orange Yellow Aqua Erika V. Examples: FP3LULU020MR6XA - FX Patch Cord, 0M3, LC Duplex UHD Uniboot - LC Duplex UHD Uniboot, 20 m, OFNR, Round 2.0 mm, A-to-B, Aqua Jacket FP4LDLD030MR2XE - FX Patch Cord, 0M4, LC Duplex - LC Duplex, 30 m, OFNR, Duplex Zip 2.0 mm, A-to-B, Erika Violet Jacket FP4LDLD030MR2XE - FX Patch Cord, 0S2, SC Duplex - SC Duplex, 5 m, OFNP, Duplex Zip 3.0 mm, A-to-B, Yellow Jacket FP3LDLH010MR2XA - FX Patch Cord, 0M3, LC Duplex - LC Duplex UHD, 10 m, OFNR, Duplex Zip 2.0 mm, A-to-B, Aqua Jacket FP4MFMF005MP6AE - FX Patch Cord, 0M4, MPO-12 (F) - MPO-12 (F), 5 m, OFNP, Round 2.0 mm, Type-A, Erika Violet Jacket Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions 20 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Pre-Terminated Assemblies (continued) FX Hydra Patch Cords Uniquely suited within dense fixed environments. Compact alternative for statically configured patch cords and pre-term cassettes eliminates connection points to improve performance and alleviate space constraints. FASTER • Faster deployment at the switch with MPO to LC fanout construction EASIER • Easier upgradability from 10G to 40G or 100G with MPO connectivity BETTER • Better identification of fiber type with Erika Violet for OM4 cable and connectors • Better airflow with small transition point construction FP4LUMF002M, FX Hydra Patch Cord, OM4, MPO-12F (F) to 6 x LC Duplex UHD Uniboot, 2 m FX Hydra Assemblies - Standard Performance Description Cable Performance - LC/SC/ST IL Max. 850 nm/1300 nm (dB/Km) IL Max. 1310 nm/1550 nm (dB/Km) Fire Rating FX OM3 FX OM4 3.25/1.0 – 3.0/1.0 – FX SM FX SM/APC – 0.5/0.5 Plenum MPO: Interconnect Mini-Round 3.0 mm LC Uniboot: Interconnect Mini-Round 2.0 mm LC: Interconnect Simplex Zip 2.0 mm Cable Style Connector Performance - LC IL Max. (dB) Polish - RL Typ. (dB) Fanout Length 0.25 PC - 30 0.15 0.35 PC - 30 UPC - 55 0.5 m, In-Line 0.35 APC - 65 Connector Performance - MPO IL Max. (dB) Polish - RL Typ. (dB) Polarity 0.35 PC - 30 0.2 PC - 30 0.75 APC - 60 – – FP4LDMF002M, FX Hydra Patch Cord, OM4, MPO-12F (F) to 6 x LC Duplex, 2 m Type-A See duplex clips on page 18 Standard FX Hydra Assemblies OM3 Aqua OM4 Erika Violet OS2 Blue/Yellow MPO-12(12f) Female to 6 x LC Duplex UHD Uniboot, 0.5 m In-Line Fanout, 2 m in length FP3LUMF002M FP4LUMF002M FPSLUMF002M MPO-12(12f) Female to 6 x LC Duplex UHD Uniboot, 0.5 m In-Line Fanout, 3 m in length FP3LUMF003M FP4LUMF003M FPSLUMF003M MPO-12(12f) Female to 6 x LC Duplex UHD Uniboot, 0.5 m In-Line Fanout, 5 m in length FP3LUMF005M FP4LUMF005M FPSLUMF005M FP4LU4F002M FPSLU4F002M Description Base12 Duplex Base8 Duplex for SR4 (QSFP+/QSFP28) Transceivers MPO-12(8f) Female to 4 x LC Duplex UHD Uniboot, FP3LU4F002M 0.5 m In-Line Fanout, 2 m in length MPO-12(8f) Female to 4 x LC Duplex UHD Uniboot, 0.5 m In-Line Fanout, 3 m in length FP3LU4F003M FP4LU4F003M FPSLU4F003M MPO-12(8f) Female to 4 x LC Duplex UHD Uniboot, 0.5 m In-Line Fanout, 5 m in length FP3LU4F005M FP4LU4F005M FPSLU4F005M www.belden.com 1.800.BELDEN.1 (800.235.3361) FP3LDMF002M, FX Hydra Patch Cord, OM3, MPO-12F (F) to 6 x LC Duplex, 2 m 21 FiberExpress Pre-Terminated Assemblies (continued) FX Hydra Patch Cords Standard FX Hydra Patch Cords FX Patch Cord 1. Choose Fiber Type 2. Choose Connector 1 3. Choose Connector 2 4. Choose Length* FP 3 LD MF 003M Fiber Type Connector 1 3 OM3 4 OM4 S OS2 LD LM LA LH LU LE Connector 2 LC Duplex Mini-LC Duplex LC/APC Duplex LC Duplex UHD LC Duplex UHD Uni LC/APC Duplex UHD MM MF 4M 4F Length* MPO-12 (m) MPO-12 (f) MPO-12 (M) Base 8 MPO-12 (F) Base 8 001M to 015M *use M as decimal Tailored FX Hydra Patch Cords FX Patch Cord 1. Choose Fiber Type 2. Choose Connector 1 3. Choose Connector 2 4. Choose Length 5. Choose Fire Rating 6. Choose Cable Construction 7. Choose Polarity 8. Choose Jacket Color FP 3 LD MF 003M P 7 A A Length Fire Rating Cable Construction 001M to 300M P L Fiber Type Connector 1 1 2 3 4 S LD LC LM LA LB LH LI LU LE LF SD SC SA SB ST OM1 OM2 OM3 OS4 OS2 LC Duplex LC Simplex Mini-LC Duplex LC/APC Duplex LC/APC Simplex LC-Duplex UHD LC-Simplex UHD LC-Duplex UHD Uni LC/APC Duplex UHD LC/APC Simplex UHD SC Duplex SC Simplex SC/APC Duplex SC/APC Simplex ST Connector 2 MM MPO-12 (m) (f) MF MPO-12 Female MPO-12 4M Base 8 (M) (F) 4F MPO-12 Base 8 *use M as decimal Plenum LSZH 7 Jacket Color Polarity Round 3.0 mm A B 4 O Y A E Type-A (Straight Polarity) Type-B (Reversed Polarity) SR4 Orange Yellow Aqua Erika V. Examples: FP3LDMF020MP7AA - FX Patch Cord, 0M3, 6 x LC Duplex -MPO-12 (F), 20 m, OFNP, Round 3.0 mm, Type-A, Aqua Jacket FP4LUMM010MP7AA - FX Patch Cord, 0M4, 6 x LC Duplex UHD Uniboot - MPO-12 (M), 10 m, OFNP, Round 3.0 mm, Type-A, Aqua Jacket FPSLHMF005MP7BY - FX Patch Cord, 0M2, 6 x LC Duplex UHD - MPO-12 (F), 5 m, OFNP, Round 3.0 mm, Type-B, Yellow Jacket FP3LDMM005MP7BA - FX Patch Cord, 0M3, 6 x LC Duplex - MPO-12 (M), 5 m, OFNP, Round 3.0 mm, Type-B, Aqua Jacket FP4LDMF025MP7AE - FX Patch Cord, 0M4, 6 x LC Duplex - MPO-12 (F), 25 m, OFNP, Round 3.0 mm, Type-A, Erika Violet Jacket Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions FX Hydra Assembly SR4 Polarity MPO-12 8 Fiber (Base8) FX Hydra Assembly Type A Polarity MPO-12 12 Fiber (Base12) PULL 1 2 3 4 5 6 7 8 9 10 11 12 A B A B A B A B A B A 1.800.BELDEN.1 (800.235.3361) B 22 www.belden.com Faster. Easier. Better. FiberExpress Pre-Terminated Assemblies (continued) FX MPO Trunk Assemblies Innovative performance with ingrained simplicity. Industry-leading low-loss MPO Trunks are the foundation of Easier, Faster and Better pre-terminated fiber connectivity solutions revolutionizing the data center. FASTER • Faster identification of fiber type with Erika Violet for OM4 Cable, Connectors and Adapters • Faster installation with pre-terminated solutions FM4MMB20025M, FX MPO Trunk, OM4, MPO-12 (Male to Male), Type-B, 2 x MPO-12 (24 fibers), 15 m, OFNP, uMini- Distribution, Fanout: 0.5 m x In-Line, Erika Violet Jacket EASIER • Easier installation with 3-flange real and default pulling eye • Easier ordering with simple intelligent SmartPart Numbers • Easier upgradability to 40G and 100G with MPO pre-term solutions BETTER • Better architectural flexibility with high-performance 0.2 dB OM4 MPO connectors • Better quality through exhaustive design validation against TIA standards • Better contamination control with Data Center ready packaging FX MPO Trunk Assemblies - Standard Performance Description Cable Performance IL Max. 850 nm/1300 nm (dB/Km) IL Max. 1310 nm/1550 nm (dB/Km) Fire Rating Cable Style Connector Performance - MPO-12 IL Max. (dB) Polish - RL Typ. (dB) Fanout Length Connector Performance - MPO-24 IL Max. (dB) Polish - RL Typ. (dB) FX OM1 FX OM3 FX OM4 FX SM 3.5/1.2 – 3.25/1.0 – 3.0/1.0 – – 0.35/0.25 FM4MMB1010M, FX MPO Trunk, OM4, MPO-12 (Male to Male), Type-B, 1 x MPO-12 (12 fibers), 10 m, OFNP, Mini- Distribution 4.8 mm (Double-Jacket), Erika Violet Jacket Plenum uMini-Distributon and Mini-Distribution cables 0.5 PC - 30 0.35 0.2 PC - 30 PC - 30 0.5 m, In-Line 0.75 APC - 60 0.5 PC - 30 0.35 PC - 30 0.75 APC - 60 0.35 PC - 30 Pulling Eye Diameter Description Installation Diameter MPO-12 (Total Connectors) 1 Connector per Bundle, 8 cm Bundle Stagger 2 Connectors per Bundle, 8 cm Bundle Stagger 3 Connectors per Bundle, 8 cm Bundle Stagger 4 Connectors per Bundle, 8 cm Bundle Stagger 6 Connectors per Bundle, 8 cm Bundle Stagger One Bundle, No Stagger (in-line) www.belden.com 12-Fiber 24-Fiber 36-Fiber 48-Fiber 72-Fiber 96-Fiber 144-Fiber 1 2 3 4 6 8 12 19.5 mm 19.5 mm 19.5 mm 19.5 mm 19.5 mm 19.5 mm 25.4 mm 25.4 mm 25.4 mm 25.4 mm 30.0 mm 30.0 mm 30.0 mm 31.7 mm 31.7 mm 38.1 mm 19.5 mm 25.4 mm 30.0 mm 31.7 mm 38.1 mm 41.9 mm 50.8 mm 1.800.BELDEN.1 (800.235.3361) Standard FX MPO Trunks 12F (Indoor) have a more robust cable construction using a MiniDistribution cable (Double jacket 4.8 mm). They are designed for safe pulling, and to withstand the rigors of installation while providing sufficient support (wire basket support). 23 FiberExpress Pre-Terminated Assemblies (continued) FX MPO Trunk Assemblies Standard FX MPO Trunks - Base 12 FX MPO 1. Choose Trunk Fiber Type 3 FM 2. Choose Connectors 3. Connector Gender 4. Choose Polarity 5. Choose Connector Count 6. Choose Length M M B 3 010M Fiber Type Connectors Connector Gender 3 4 S M MPO-12(12F) M F E P R OM3 OM4 OS2 Examples: Male to Male Female to Female Extension (M to F) Male to Open Female to Open Polarity (outside) A B C Type-A Type-B Type-C FM3MMB1010M - FX MP0 Trunk 0M3, MP0-12 (Male to Male), Type-B, 1 MP0 (12 Fibers), 10 m, 0FNP, Mini-Distribution 4.8 mm (Double-Jacket), Aqua Jacket. Connector Count 1 2 3 4 6 8 D Length 005M to 500M 12 Fibers 24 Fibers 36 Fibers 48 fibers 72 Fibers 96 Fibers 144 Fibers M Meters *use M as decimal FM4MMB4030M - FX MP0 Trunk 0M4, MP0-12 (Male to Male), Type-B, 4 MP0 (48 Fibers), 30 m, 0FNP, Mini-Distribution (2.0 mm Sub-Units) Fan-Out: 0.5 m In-Line, Erika Violet Jacket. FMSMFAD025M - FX MP0 Trunk 0S2, MP0-12 (Female to Female), Type-A, 12 MP0 (144 Fibers), 25 m, 0FNP, Mini-Distribution (2.0 mm Sub-Units) Fan-Out: 0.5 m In-Line, Yellow Jacket. Tailored FX MPO Trunks - Base12 FX MPO Trunk 1. Choose Fiber Type 2. Choose Connectors 3. Choose Connector Gender 4. Choose Polarity (outside) 5. Choose Connector Count (per side) 6. Choose Length 7. Choose Fire Rating 8. Choose Cable Construction 9. Choose Fan-Out Length & Geometry 10. Choose Jacket Color FM 3 M M B 4 010M P M E A Fiber Type Connectors 1 2 3 4 S MPO-12 M (12F) OM1 OM2 OM3 OM4 OS2 Connector Gender to M Male Male to F Female Female Extension E (M to F) to P Male Open Female R Open to Polarity (outside) A B C Type-A Type-B Type-C Connector Count 1 2 3 4 6 8 D 12 Fibers 24 Fibers 36 Fibers 48 Fibers 72 Fibers 96 Fibers 144 Fibers Length Fire Rating Cable Construction Fan-Out Geometry 005M to 500M P Plenum U D M Meters I I/O Plenum Plenum Armored (AIA) Plenum I/O Armored (AIA) *use M as decimal A B L uMini-D M Mini-D E None (1 Conn.) 0.5 m x In-Line (>2 Conn.) 1.0 m x In-Line F 1.5 m x In-Line G 4 2.0 m x In-Line 0.5 m x Stag 80 mm/1 conn. 0.5 m x Stag 80 mm/2 conn. 0.5 m x Stag 80 mm/3 conn. 0.5 m x Stag 80 mm/4 conn. N No Pulling Eye D 1 LSZH 2 3 Use of Tailored part numbers: Jacket Color O N Y A Orange Black Yellow Aqua E Erika Violet • Fiber Type: For any OM1 and OM2 trunk. Eye at B Pulling • Fire Rating: For any Plenum Armored, I/0 Plenum, I/0 Plenum Armored, LSZH trunks. both ends • Cable Construction: ”M” Mini-Distribution cable used for indoor Plenum 2F (1 conn.), for I/0 Plenum, for Plenum Armored, for I/0 Plenum Armored and LSZH. ”U” uMini-Distribution cable used for indoor Plenum>=24F (>=2 conn.). • Fan-Out Length & Geometry: Different fan-out lengths and stagger options, No Pulling Eye, Pulling eye at both ends. Examples: FM3MMB1010MPMNA - FX MP0 Trunk 0M3, MP0-12 (Male to Male), Type-B, 1 MP0 (12 Fibers), 10 m, 0FNP, Mini-Distribution 4.8 mm (Double-Jacket), No Pulling Eye, Aqua Jacket. FM4MMB4020MAMDE - FX MP0 Trunk 0M4, MP0-12 (Male to Male), Type-B, 4 MP0 (48 Fibers), 20 m, 0FCP, (Plenum Armored), Mini-Distribution (3.0 mm Sub-Units) Fan-Out: 0.5 m In-Line, Erika Violet Jacket. FMSMFA2030MPM1Y - FX MP0 Trunk 0S2, MP0-12 (Female to Female), Type-A, 2 MP0 (24 Fibers), 30 m, 0FNP, Mini-Distribution (3.0 mm Sub-Units) Fan-Out: 0.5 m Staggered 80 mm/ 1 CONN, Yellow Jacket. Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions 24 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Pre-Terminated Assemblies (continued) FX MPO Trunk Assemblies Standard FX MPO Trunks - Base 8 FX MPO 1. Choose Trunk Fiber Type 2. Choose Connectors 3. Connector Gender 4. Choose Polarity 5. Choose Connector Count 6. Choose Length M M B 3 010M 3 FM Fiber Type Connectors Connector Gender 3 4 S 4 MPO-12 (8F) M F E P R OM3 OM4 OS2 Connector Count Polarity (outside) Male to Male Female to Female Extension (M to F) Male to Open Female to Open A B C 1 2 3 4 6 8 D Type-A Type-B Type-C Length 005M to 500M 8 Fibers 16 Fibers 24 Fibers 32 fibers 48 Fibers 64 Fibers 96 Fibers M Meters *use M as decimal Examples: FM3MMB1010M - FX MP0 Trunk 0M3, MP0-12 Base 8 (Male to Male), Type-B, 1 MP0 (8 Fibers), 10 m, 0FNP, Mini-Distribution 4.8 mm (Double-Jacket), Aqua Jacket. FMS4FAD025M - FX MP0 Trunk 0S2, MP0-12 Base 8 (Female to Female), Type-A, 12 MP0 (96 Fibers), 25 m, 0FNP, Mini-Distribution (2.0 mm Sub-Units) Fan-Out: 0.5 m In-Line, Yellow Jacket. Tailored FX MPO Trunks - Base 8 2. Choose Connectors 3. Choose Connector Gender 4. Choose Polarity (outside) 5. Choose Connector Count (per side) 6. Choose Length 7. Choose Fire Rating 8. Choose Cable Construction 9. Choose Fan-Out Length & Geometry 10. Choose Jacket Color 3 M M B 3 010M P M E A Fiber Type Connectors FX MPO 1. Choose Trunk Fiber Type FM 3 OM3 4 OM4 S OS2 Connector Gender Polarity (outside) Connector Count Length Fire Rating 005M to 500M P I Cable Construction Fan-Out Geometry FM34MB1010MPMNA - FX MP0 Trunk 0M3, MP0-12 Base 8 (Male to Male), Type-B, 1 MP0 (8 Fibers), 10 m, 0FNP, Mini-Distribution 4.8 mm (Double-Jacket), No Pulling Eye, Aqua Jacket. 4 None (1 Conn.) 0.5 m x In-Line (>2 Conn.) 1.0 m x In-Line 1.5 m x In-Line 2.0 m x In-Line 0.5 m x Stag 80 mm/1 conn. 0.5 m x Stag 80 mm/2 conn. 0.5 m x Stag 80mm/3 conn. 0.5 m x Stag 80 mm/4 conn. FM44MB4020MAMDE - FX MP0 Trunk 0M4, MP0-12 Base 8 (Male to Male), Type-B, 4 MP0 (32 Fibers), 20 m, 0FCP, (Plenum Armored), Mini-Distribution (3.0 mm Sub-Units) Fan-Out: 0.5 m In-Line, Erika Violet Jacket. N No Pulling Eye B Pulling Eye at both ends 4 MPO-12 (8F) to M Male Male Female F Female to E Extension (M to F) to P Male Open Female R Open to A B C Type-A Type-B Type-C 1 2 3 4 6 8 D 8 Fibers 16 Fibers 24 Fibers 32 Fibers 48 Fibers 64 Fibers 96 Fibers M Meters *use M as decimal A B L Plenum U uMini-D I/O Plenum M Mini-D Plenum Armored (AIA) Plenum I/O Armored (AIA) LSZH D D E F G 1 2 3 Examples: Jacket Color O N Y A E Orange Black Yellow Aqua Erika Violet Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions www.belden.com 1.800.BELDEN.1 (800.235.3361) 25 FiberExpress Pre-Terminated Assemblies (continued) FX Multi-Fiber Cable Assemblies Superior consistent craftsmanship culminating in near instantaneous installation. Highly configurable multi-fiber pre-terminated cable assemblies are engineering for maximum performance and crafted ensuring superior quality. FASTER • Faster identification of fiber type with Erika Violet for OM4 cable, connectors and adapters • Faster installation with pre-terminated solutions EASIER FX Multi-Fiber Cable Assembly • Easier installation with 3-flange real and default pulling eye • Easier ordering with simple intelligent SmartPart Numbers BETTER • Better quality through exhaustive design validation against TIA standards • Better flexibility through absolute customizability Length Inside End Outside End Fan-Out In-Line Fan-Out Staggered Product Engineering Code (PEC) - GUIDELINE Use the following options to determine the Product Engineering code (PEC) and order custom combination of cable type, connectors and length required. 1 2 NXC - 3 C R T - N XX Cable Type 4 Y L B G - XX 5 Y L B G - Outside End1 Inside End 6 E - LLLL Length (Connectors) 1 NXC identifies the product family for all fiber cable assemblies 2 Select Cable Type 26 C Cable Construction R Fire Rating T Fiber Type N Fiber Count M P U X R P B D E M F K G S 6 L X C V T M Z Distribution cable Breakout 2.0 mm units Mini-distribution2 uMini-distribution2 OFNR - Riser OFNP - Plenum Plenum Indoor Armored Outdoor Indoor / Outdoor Plenum 1.800.BELDEN.1 (800.235.3361) OM1 - 62.5 μm Multimode OM3 - 50 μm Multimode OM4 (EV) - 50 μm Multimode OM4 (Aqua) - 50 μm Multimode OS2 - Singlemode 6 Fibers 12 Fibers 24 Fibers Sub-units 24 Fibers Non-unitized3 48 Fibers 72 Fibers 96 Fibers 144 Fibers www.belden.com Faster. Easier. Better. FiberExpress Pre-Terminated Assemblies (continued) FX Multi-Fiber Cable Assemblies 3 and 4 Inside End and Outside End (Connectors) XX Connectors Y Polish / Performance Level LC LD LU LI LH SC SD ST PH PG LM ZZ P U A Z LC Simplex LC Duplex LC Duplex UHD Uniboot LC Simplex UHD LC Duplex UHD SC Simplex SC Duplex ST 12-fiber MPO female 12-fiber MPO male mSFP (Mini LC) OPEN4 PC - Physical Contact Multimode UPC - Ultra Physical Contact Singlemode APC - Angled Polish Contact Singlemode Not applicable4 Fan-out 5 Pulling Eye L Fan-Out Length B Fan-Out Construction G Fan-Out Geometry E Pulling Eye C F G N B E G N N In line or None A Staggered 25 mm B Staggered 50 mm O At Outside end5 N None 0.5 m 1m 2m None4 900 μm Tight buffer 2.0 mm jacket 3.0 mm jacket None4 6 Length LLLL is the length from tip to tip in meters: 0001, 0005, 0015, 0100, etc. Examples: PEC Code Description NXC-MRFL-LCPFBN-LCPFBN-O-0015 Multi-Fiber cable assembly, Distribution cable, Riser, OM3(50 μm), 12 fibers, LC/PC - LC/PC, Fan-out: 1 m - 900 μm - In line, with pulling eye, 15 m NXC-UPFV-LDPFEN-PGPFGN-N-0020 Multi-Fiber cable assembly, Mini-distribution cable, Plenum, OM3 (50 μm), 48 fibers, LC Duplex/PC - MPO (m)/PC, Fan-out: 1 m - 2.0 mm(LC) & 3.0 mm (MPO) - In Line, No pulling eye, 20 m Please contact Belden to validate your PEC Code and for any other fiber cable assembly combinations not available in this guideline. Notes: 1. Outside end refers to the pulling side. 2. uMini-distribution cable is a round cable with 2 mm sub-units of 12 loose fibers each. Mini-distribution cable is a round cable with 3 mm sub-units of 12 loose fibers each. They are mainly used for MPO assemblies. 3. Single-Jacket design. It’s only used for Distribution cable. 4. Only for Outside End. It’s used for pigtails. 5. Pulling eye is strongly recommended for assemblies longer than 10 m. Fanout Options Stagger Options 900 μm Fiber 1 x LC Simplex Duplex Stagger 1 x LC Duplex Jacketed Simplex Cord 2 x LC Simplex www.belden.com Simplex Stagger 1.800.BELDEN.1 (800.235.3361) 27 FiberExpress Workstation Connectivity FX Multi Box (M-Box) and MDVO Multimedia Outlet Box Strategically placed connectivity through overt design. Compact low-port count field-term or pre-term distributed consolidation points minimizing installation time by maximizing trunk capacity. FASTER • Faster installation with a variety of surface mount options EASIER • Easier distribution of low port count connectivity and breakouts with self-contained designs • Easier field-termination with easily accessible consolidation points BETTER FWSWBF04SB, FX W-Box, 4 x SC/APC Simplex • Better options for pre-term and field-term including splicing FX Wall Box (W-Box) Protect and manage field-terminated fiber within a compact easily mounted termination box supporting both Mechanical Splice and Fusion Splice termination techniques. Belden Part Number Description FX Wall-Box, 1x SC Simplex FX Wall-Box, 2x SC Simplex FX Wall-Box, 4x SC Simplex OM3 Aqua – – – OM4 Erika Violet – – – OS2 OS2/APC Blue Green FWSWBF01SC FWSWBF01SB FWSWBF02SC FWSWBF02SB FWSWBF04SC FWSWBF04SB FX Multi Box (M-Box) FW3MBP06LD, FX M-Box Pre-Term, 6 x LC Duplex, 1 MPO-12(f), OM3 Extremely compact, the feature rich M-Box is ideally suited for floor box and consolidation point applications. Supporting pre-terminated MPO-12(f) connectivity with an integrated fanout to LC, 1G and 10G Ethernet can be quickly deployed and re-deployed eliminating field termination. When the need arises additional versions of the M-Box are fully equipped to handle and protect field termination including both mechanical splice and pigtail fusion splicing techniques. Belden Part Number Description FX Multi-Box Pre-Term MPO-12(f) to 6 x LC Duplex FX Multi-Box Field-Term, (with Pigtails) FX Multi-Box Field-Term, (without Pigtails) A0643206, MDVO Multimedia Outlet Box (shown terminated) OM3 OM4 OS2 OS2/APC Aqua Erika Violet Blue Green FW3MBP06LD FW4MBP06LD FWSMBP06LD FWSMBP06LA FW3MBS06LD FW4MBS06LD FWSMBS06LD FWSMBS06LA FW3MBF06LD FW4MBF06LD FWSMBF06LD FWSMBF06LA MDVO Multimedia Outlet Box The MDVO Multimedia Outlet Box brings unique versatility for multimedia work area installations. The box design provides cable management and helps maintain cable bend radius. The low profile design and side-entry of the outlet box offers better protection for patch cords. The outlet box can accept up to six MDVO-style modules or three SC Duplex footprint adapters. The MDVO Multimedia Outlet Box can be mounted directly on the wall or attached to standard electrical boxes. Included with the MDVO Multimedia box are three 1-port SC Duplex footprint mounting bezels and three 2-port MDVO adapters. For MediaFlex Faceplates, Interface MDVO Faceplates and MDVO adapters, please refer to Belden Copper Catalog (Pages 54-59). Belden Part Number Description MDVO Multimedia Outlet Box, 6-Port Almond A0643206 White A0643207 *See the Belden copper catalog for a larger selection. 28 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Workstation Connectivity (continued) Multi-User Outlet Box, MDVO Fiber Adapter Modules, KeyConnect Fiber Adapter Modules and Standard Duplex Fiber Adapters Multi-User Outlet Box The Multi-User Outlet Box is a versatile box that can be used in many different applications. The outlet box can accommodate up to 24 connections of any type: UTP, fiber or coax. The outlet box is ideal for use as a multi-user telecommunications assembly, or simply as a high-density multimedia telecommunications outlet. The Multi-User Outlet Box can also be used as a wall mounted patch panel in confined areas, such as shallow rooms and cabinets. Belden Part Number Description Multi-User Outlet Box, 24-MDVO Ports (Empty) Multi-User KeyConnect 12-Port Adapter Strip Multi-User MDVO 12-Port Adapter Strip Almond AX100220 – – Elec. White AX100221 – – Black AX100222 AX104615 AX100223 AX100222, Multi-User Outlet Box (shown here with optional modules) MDVO Fiber Adapter Modules Belden Part Number Description LC Duplex - OM3 (Aqua Adapter) SC Simplex - OM3 (Aqua Adapter) Almond AX105505-AL AX105697-AL Elec. White AX105505-WH AX105697-WH Black AX105505-BK AX105697-BK All MDVO Adapter Modules listed above come in quantities of 25 per package Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions AX102101, OM4 MDVO Adapter Module with LC Keyed Red Adapter, White Holder KeyConnect Fiber Adapter Modules Belden Part Number Description LC Duplex - OM3 (Aqua Adapter) LC Duplex - OM4 (Erika Violet Adapter) SC Simplex OM1 (Beige Adapter) SC Simplex - OM3 (Aqua Adapter) ST- Metal Almond AX104937 AX105641-AL AX102683 AX105643-AL AX102242 Elec. White AX104938 AX105641-EW AX102684 AX105643-EW AX102243 Black AX104939 AX105641-BK AX102685 AX105643-BK AX102244 All KeyConnect Adapter Modules listed above come in quantities of 25 per package Please contact Belden for any help configuring/validating SmartPart Numbers or for any other custom Engineered solutions AX104939, KeyConnect Adapter, LC Duplex, OM3 (Aqua Adapter), Black Holder Standard Duplex Footprint Fiber Adapters Belden Part Number Description SC Duplex, Flangeless SC Duplex w/Shutters, Flangeless OM3 Aqua AX105691-B25 – OM4 Erika Violet AX105692-B25 – OS2 Blue AX105002-B25 AX105693-B25 OS2/APC Green AX105646-B25 AX105694-B25 Refer to the Belden copper catalog for a larger selection of workstation connectivity options. For MediaFlex Faceplates, KeyConnect Faceplates and KeyConnect adapters, please refer to Belden Copper Catalog (Pages 51-57). www.belden.com 1.800.BELDEN.1 (800.235.3361) 29 FiberExpress Secure/Keyed LC System FX Secure/Keyed LC System FX Secure/Keyed LC System FX Brilliance Connectors The FX Secure/Keyed LC System allows for physical segregation of network segments in secure fiber cabling infrastructures. All Secure/Keyed LC products are available with 12 different keying options each carrying a different color to facilitate network administration. The keying detail inside the connector is highly tamperresistant and cannot be reproduced inside a standard LC connector to violate the network security. All products comply with the FOCIS 10 standard and optical performance exceeds all industry standards for SFF connectors. The Secure/Keyed LC Adapter Modules, Frames, Cassettes and Adapter Strips can be used in all mounting hardware for workstation area, Consolidation Point or Telecom Room applications. The Secure/ Keyed LC FX Manager Modules can be used in 19- and 23-inch FX Manager Shelves to provide a high-density management system. The Secure/Keyed LC FX Ultra Frames and Cassettes can be used with the FX UHD Rack and FX Ultra Wall-mount Patch Panels to provide an Ultra high-density patching system that is easy to deploy, operate and maintain, while ensuring maximum uptime, uninterrupted availability and superior performance. The Secure/Keyed LC Patch Cords and Pigtails are offered in Multimode 62.5 μm (OM1), laser-optimized 50 μm (OM3 and OM4) and Singlemode (OS2) for the most demanding network performance. The Secure/Keyed LC Brilliance Universal Field Installable Connectors are available in Multimode 50 μm laser-optimized (OM4, OM3 compatable) and Singlemode (OS2) fiber versions. FX Secure/Keyed LC System Description FX Secured/Keyed LC Ultra Cassette LC Key1 LC Key2 LC Key3 LC Key4 LC Key5 LC Key6 LC Key7 LC Key8 LC Key9 LC KeyA LC KeyB LC KeyC Splices Red Green Yellow Black Orange Blue Violet Rose Aqua Brown Slate White For additional details, please refer to the Secure/Keyed LC System Product Bulletin PB275. FX Secure/Keyed LC Manager Module FX Secure/Keyed LC Adapter Strip 30 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Optic Cables Introduction The optical fiber cables featured in this section have been expanded to meet advances in technology and the demands of both commercial and industrial applications. Refer to page 3 for selecting a fiber type, color coding information, and optical specifications. Belden’s extensive line of indoor and outdoor cable products is offered in tight buffer and loose tube designs. Armored, burial, and ruggedized designs are suited to a host of industrial environments. For each product design, items for OM1, OM2, OM3, OM4, and OS2 (Singlemode) items have been developed. Belden fiber products are third party tested by either ETL or UL and approved for use according to the National Electric Code. Customer Service Many fiber designs are available from stock through our Distributors. For your new or custom application that you do not locate in this section, contact Customer Service at 1-800-Belden-1 (800.235.3361) for additional information or to request a quote. Further product and technical information is also available on our web site at www.belden.com. Jacket Color Chart Cable Type Jacket Color Indoor Cables: Interconnect, Breakout, Distribution, Mini-Distribution and Tray Optic OM1 & OM2 Orange OM3 Aqua OM4 Erika Violet (Standard) Aqua (Optional) OS2 Yellow Hybrid Indoor Cables: Breakout, Distribution & Mini-Distribution Primary Fiber Type Secondary Fiber Type Jacket Color OS2 OM1 Orange OS2 OM3 Aqua OS2 OM4 Erika Violet (Standard) OM3 OM1 Aqua OM4 OM1 Erika Violet (Standard) Aqua (Optional) Indoor/Outdoor & Outdoor Cables: Distribution, Loose Tube, OSP OM1, OM2, OM3, OM4, OS2 Specialty Cables: Tactical Black OM1, OM2, OM3, OM4, OS2 Black Documents contributing to LEED points are available at info.belden.com/leed-credits See page 3, FX Systems chart for technical performance. The part numbers in the following pages represent standard fiber cables, additional constructions are available, please contact your Belden representative for more information. www.belden.com 1.800.BELDEN.1 (800.235.3361) 31 FiberExpress Interconnect Cables Tight Buffer — Riser & Plenum Rated Supple and compact yet undoubtedly resilient. Small form factor FX interconnect cables provide the right combination of flexibility, small size and robustness needed to withstand the rigours of daily patching without sacrificing density. Applications: • Patching • Inside Cabinets • Workstation Equipment Connections Duplex Optical Fiber Interconnect Cable Zip Cord (900μm Fiber) Specifications Description Construction Bend Radius (vs. Cable OD) Fiber Count 1 Installation 15 x OD Operation 10 x OD Simplex 1 Temperature Range 2 Storage -40°C to 70°C (-40°F to 158°F) Installation 0°C to 50°C (32°F to 122°F) Operation -20°C to 70°C (-4°F to 158°F) Legend 250 μm Fiber Color Coded String Bound Sub Unit Aramid Yarn Outer Jacket Compliance • TIA/EIA-568-C.3 • ISO/IEC 11801, 2nd Edition • Telcordia GR-409-CORE Duplex Zip 2 Cable OD Fiber 900 μm TB 900 μm TB • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • IEC 60332-3-24, IEC 61034-2, IEC 60754-1&2 (LSZH - FRPE) • ICEA S-83-596 in. Kg/km lb/1000 ft. 2.0 0.08 4 3 3.0 0.11 7 5 2.0 x 0.08 x 4.0 0.16 7 5 3.0 x 5.8 16 11 66 15 220 50 66 15 220 50 Standard Configurations Belden Part Number Fiber Count OM3 Aqua OM4 Erika Violet OS2 Yellow FI3I001RB FI4I001RB FISI001RB 1 Duplex 2.0 mm - Riser FI3I001RC FI4I001RC FISI001RC 2 Duplex 3.0 mm - Riser 2 FI3I002RB FI4I002RB FISI002RB FI3I002RC FI4I002RC FISI002RC Simplex 2.0 mm - Riser 1 Simplex 3.0 mm - Riser For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. Mini Round (250 μm Fiber) Fiber Count Fiber Duplex Mini-Round 2 Mini-Round 8f Mini-Round 12f Description Construction Cable OD Tensile Strength Operation Installation N lbs-f N lbs-f Weight mm in. 250 μm 2.0 0.08 3.4 2.3 133 30 445 100 8 250 μm 2.0 0.08 3.4 2.3 133 30 445 100 12 250 μm 2.0 0.08 3.4 2.3 133 30 445 100 • RoHS II 2011/65/EU • REACH EC1907-2006 mm 0.11 x 0.22 Tensile Strength Operation Installation N lbs-f N lbs-f Weight Kg/km lb/1000 ft. Standard Configurations Belden Part Number Fiber Count Mini-Round 2.0 mm - Plenum 2 8 12 32 1.800.BELDEN.1 (800.235.3361) OM3 Aqua OM4 Erika Violet OS2 Yellow FI3I002P0 FI3I008P0 FI3I012P0 FI4I002P0 FI4I008P0 FI4I012P0 FISI002P0 FISI008P0 FISI012P0 www.belden.com Faster. Easier. Better. FiberExpress Breakout Cables Tight Buffer — Indoor Riser, Plenum & LSZH Rated Robust terminations in demanding environments. All the ease of 900 μm tight buffered termination with only one fiber per sub-unit enables the ultimate bond between the connector and the cables’ Aramid yarns resulting in unmatched strength and durability. Applications: • Horizontal distribution for Fiber-to-thedesk • In-building backbone • Factory floor automation • Broadcast and A/V in-building installations Additional Options Optical Fiber Breakout Cable • 2.5 mm and 2.9 mm Subunits • MSHA (Mining) Approvals Description Construction Fiber Count Fiber SubUnit OD mm 2 900 μm TB 2.0 Cable OD Specifications Tensile Strength Weight Operation mm 6.6 in. Kg/km lb/1000 ft. 0.26 36 N 24 400 Installation lbs-f 90 N 800 lbs-f 180 Bend Radius (vs. Cable OD) Installation 15 x OD Operation 10 x OD Temperature Range Storage 4 Color-coded Sub-Units 900 μm TB 2.0 6 8 10 900 μm TB 12 8.2 0.32 52 35 755 170 1535 345 9.1 0.36 80 54 1025 230 2070 465 10.3 0.41 103 69 11.6 0.46 128 86 1335 300 2670 600 13.1 0.51 164 110 2.0 -40°C to 70°C (-40°F to 158°F) Installation (Plenum/LSZH) 0°C to 60°C 32°F to 140°F Installation (Riser) -10°C to 60°C (14°F to 140°F) Operation (Plenum/LSZH) 0°C to 70°C (32°F to 158°F) Operation (Riser) -20°C to 70°C (-4°F to 158°F) Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Legend Belden Part Number Fiber Count OM1 Orange OM3 Aqua OM4 Erika Violet OS2 Yellow FI1B002PB FI1B004PB FI1B006PB FI1B012PB FI3B002PB FI3B004PB FI3B006PB FI3B012PB FI4B002PB FI4B004PB FI4B006PB FI4B012PB FISB002PB FISB004PB FISB006PB FISB012PB FI1B002LB FI1B004LB FI1B006LB FI1B012LB FI3B002LB FI3B004LB FI3B006LB FI3B012LB FI4B002LB FI4B004LB FI4B006LB FI4B012LB FISB002LB FISB004LB FISB006LB FISB012LB Rip Cord Color-coded Sub-Unit Plenum 2 4 6 12 Aramid Yarn Central Strength Member 900 μm Tight Buffered Fiber LSZH/Riser 2 4 6 12 For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. Outer Jacket Compliance er 6 fib • TIA/EIA-568-C.3 • ISO/IEC 11801, 2nd Edition • Telcordia GR-409-CORE • RoHS II 2011/65/EU • REACH EC1907-2006 • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • ICEA S-83-596 www.belden.com 1.800.BELDEN.1 (800.235.3361) 33 FiberExpress Distribution Cables Tight Buffer — Indoor Riser & Plenum Rated Applications: Fast installation, easy termination. Sub-unitized cables provide easy routing and 900 μm tight-buffered fiber supporter fast and robust field-termination. • Horizontal distribution for Fiber-to-the-desk • In-building backbone • Factory floor automation • Data Center EDA areas Additional Options • MSHA (Mining) Approvals Indoor Specifications Bend Radius (vs. Cable OD) Description Installation 15 x OD Operation 10 x OD Construction 2 Temperature Range Storage Installation (Plenum/LSZH) Installation (Riser) Fiber Count -40°C to 70°C (-40°C to 158°F) 0°C to 60°C (32°F to 140°F) Non-Unitized -10°C to 60°C (14°F to 140°F) Operation (Plenum/LSZH) 0°C to 70°C (32°F to 158°F) Operation (Riser) -20°C to 70°C (-4°F to 158°F) Legend Fiber 900 μm TB Sub-Unit Cable OD OD Operation mm mm in. Kg/km lb/1000 ft. N/A 4.8 0.19 4.8 0.19 5.8 0.23 8.8 0.35 13.1 Installation N lbs-f N lbs-f 222 50 556 125 22 15 25 31 36 39 43 64 80 17 21 24 26 29 43 54 222 50 556 125 334 75 667 150 556 125 1112 250 0.52 145 97 1001 225 2002 450 36 16.0 0.63 221 148 1668 375 3336 750 36 14.1 0.56 162 109 1001 225 2002 450 48 15.5 0.61 207 139 1423 320 2847 640 19.0 0.75 321 216 2002 450 4226 950 96 22.8 0.90 536 360 2780 625 5560 1250 144 25.4 602 404 4226 950 8452 1900 4 6 8 10 12 16 24 900 μm TB N/A 24 Unitized 6-Fiber Sub-Units Rip Cord Tensile Strength Weight 900 μm TB 4.5 Numbered Sub-Unit Aramid Yarn Central Strength Member 900 μm Tight Buffered Fiber Outer Jacket Compliance Unitized 12-Fiber Sub-Units • TIA/EIA-568-C.3 72 900 μm TB 5.5 • ISO/IEC 11801, 2nd Edition • Telcordia GR-409-CORE • RoHS II 2011/65/EU 1.00 • REACH EC1907-2006 • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • ICEA S-83-596 34 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Distribution Cables (continued) Tight Buffer — Indoor Riser & Plenum Rated Standard Indoor Configurations Belden Part Number Fiber Count OM1 Orange OM3 Aqua OM4 Erika Violet OS2 Yellow Non-Unitized - Riser 2 6 12 24 FI1D002R9 FI1D006R9 FI1D012R9 FI1D024R9 FI3D002R9 FI3D006R9 FI3D012R9 FI3D024R9 FI4D002R9 FI4D006R9 FI4D012R9 FI4D024R9 FISD002R9 FISD006R9 FISD012R9 FISD024R9 Non-Unitized - Plenum 2 6 12 24 FI1D002P9 FI1D006P9 FI1D012P9 FI1D024P9 FI3D002P9 FI3D006P9 FI3D012P9 FI3D024P9 FI4D002P9 FI4D006P9 FI4D012P9 FI4D024P9 FISD002P9 FISD006P9 FISD012P9 FISD024P9 Unitized 6 Fiber subunits riser 24 FI1D024RJ FI3D024RJ FI4D024RJ FISD024RJ Unitized 6 Fiber subunits plenum 24 FI1D024PJ FI3D024PJ FI4D024PJ FISD024PJ Unitized 12 Fiber subunits plenum 36 FI1D036PK 48 FI1D048PK 72 FI1D072PK 96 FI1D096PK 144 FI1D144PK FI3D036PK FI3D048PK FI3D072PK FI3D096PK FI3D144PK FI4D036PK FI4D048PK FI4D072PK FI4D096PK FI4D144PK FISD036PK FISD048PK FISD072PK FISD096PK FISD144PK Optical Fiber Distribution Cable For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. www.belden.com 1.800.BELDEN.1 (800.235.3361) 35 FiberExpress Distribution Cables (continued) Tight Buffer — Indoor/Outdoor Riser, Plenum & LSZH Rated Indoor/Outdoor Specifications Additional Options • MSHA (Mining) Approvals • Environmental Protection – – – – – UV Resistant Jacket Moisture Resistant Jacket Fungus Resistant Jacket Water Blocking Aramid Water Blocking Tape Indoor/Outdoor Specifications Bend Radius (vs. Cable OD) Description Installation 20 x OD Operation 10 x OD Construction -40°C to 70°C (-40 to 158°F) Installation -20 to 70°C (-4 to 158°F) Operation -40 to 70°C (-40 to 158°F) Non-Unitized Fiber Sub-Unit Cable OD OD Operation mm in. Kg/km lb/1000 ft. N/A 4.8 0.19 4.8 0.19 5.8 0.23 8.8 0.35 13.1 36 900 μm TB Tensile Strength Weight mm 2 Temperature Range Storage Fiber Count Installation N lbs-f N lbs-f 222 50 556 125 22 15 25 31 36 39 43 64 80 17 21 24 26 29 43 54 222 50 556 125 334 75 667 150 556 125 1112 250 0.52 145 97 1001 225 2002 450 16.0 0.63 221 148 1668 375 3336 36 14.1 0.56 162 109 1001 225 2002 450 48 15.5 0.61 207 139 1423 320 2847 640 19.0 0.75 321 216 2002 450 4226 950 96 22.8 0.90 536 360 2780 625 5560 1250 144 25.4 602 404 4226 950 8452 1900 4 6 8 10 12 16 24 900 μm TB N/A Legend 24 Rip Cord Numbered Sub-Unit Water Swellable Aramid Yarn Unitized 6-Fiber Sub-Units Central Strength Member 900 μm TB 4.5 750 900 μm Tight Buffered Fiber Water Blocking Tape Outer Jacket Compliance • TIA/EIA-568-C.3 • ISO/IEC 11801, 2nd Edition • Telcordia GR-20-CORE • RoHS II 2011/65/EU Unitized 12-Fiber Sub-Units 72 900 μm TB 5.5 • REACH EC1907-2006 • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) 1.00 • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • ICEA S-104-696 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. 36 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Distribution Cables (continued) Tight Buffer — Indoor/Outdoor Riser, Plenum & LSZH Rated Standard Indoor/Outdoor Configurations Belden Part Number Fiber Count OM1 Black OM3 Black OM4 Black OS2 Black Non-Unitized - Riser/LSZH 2 6 12 24 FD1D002L9 FD1D006L9 FD1D012L9 FD1D024L9 FD3D002L9 FD3D006L9 FD3D012L9 FD3D024L9 FD4D002L9 FD4D006L9 FD4D012L9 FD4D024L9 FDSD002L9 FDSD006L9 FDSD012L9 FDSD024L9 Non-Unitized - Riser 2 6 12 24 FD1D002R9 FD1D006R9 FD1D012R9 FD1D024R9 FD3D002R9 FD3D006R9 FD3D012R9 FD3D024R9 FD4D002R9 FD4D006R9 FD4D012R9 FD4D024R9 FDSD002R9 FDSD006R9 FDSD012R9 FDSD024R9 Non-Unitized Plenum 2 6 12 24 FD1D002P9 FD1D006P9 FD1D012P9 FD1D024P9 FD3D002P9 FD3D006P9 FD3D012P9 FD3D024P9 FD4D002P9 FD4D006P9 FD4D012P9 FD4D024P9 FDSD002P9 FDSD006P9 FDSD012P9 FDSD024P9 Unitized 6-Fiber Sub-Units - Riser 24 FD1D024RJ FD3D024RJ FD4D024RJ FDSD024RJ Unitized 6-Fiber Sub-Units - Plenum 24 FD1D024PJ FD3D024PJ FD4D024PJ FDSD024PJ Unitized 12-Fiber Sub-Units - Riser/LSZH 48 FD1D048LK 72 FD1D072LK 96 FD1D096LK 144 FD1D144LK FD3D048LK FD3D072LK FD3D096LK FD3D144LK FD4D048LK FD4D072LK FD4D096LK FD4D144LK FDSD048LK FDSD072LK FDSD096LK FDSD144LK Unitized 12-Fiber Sub-Units - Plenum 48 FD1D048PK 72 FD1D072PK 96 FD1D096PK 144 FD1D144PK FD3D048PK FD3D072PK FD3D096PK FD3D144PK FD4D048PK FD4D072PK FD4D096PK FD4D144PK FDSD048PK FDSD072PK FDSD096PK FDSD144PK Optical Fiber Distribution Cable, Indoor/Outdoor For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. www.belden.com 1.800.BELDEN.1 (800.235.3361) 37 FiberExpress Armored Distribution Cables Tight Buffer — Indoor, Riser and Plenum Rated Heightened Protection with simple termination. Augmenting the easy termination of Distribution cable with interlocking armor to provide an elevated resistance to cutting, crushing and the gnawing of rodents all while eliminating the additional expense of innerduct. Applications: • Campus/Inter Building • Telecom Trunks • Industrial • Rugged Environments Indoor Specifications Bend Radius (vs. Cable OD) Description Installation 20 x OD Operation 15 x OD Temperature Range Storage Construction Installation (Riser) -10°C to 60°C (14°F to 140°F) Operation (Plenum/LSZH) 0°C to 70°C (32°F to 158°F) Operation (Riser) -20°C to 70°C (-4°F to 158°F) Rip Cord Numbered Sub-Unit Central Strength Member Unitized 12-Fiber Sub-Units 900 μm Tight Buffered Fiber Operation in. Kg/km lb/1000 ft. 0.57 189 127 15.7 0.62 150 223 24 17.0 0.67 335 225 24 21.5 0.85 391 263 12 900 μm TB 900 μm TB N/A 4.5 36 25.3 1.00 548 368 48 24.6 0.97 540 363 72 27.8 1.09 716 481 32.5 1.28 930 625 96 144 Inner Jacket mm 900 μm TB Tensile Strength Weight 14.5 Unitized 6-Fiber Sub-Units Legend Aramid Yarn Sub-Unit Cable OD OD 6 -40°C to 70°C (-40°F to 158°F) 0°C to 60°C (32°F to 140°F) Fiber mm Non-Unitized Installation (Plenum/LSZH) Fiber Count 5.5 35.6 1.40 1005 Installation N lbs-f N lbs-f 360 81 1201 270 400 90 1334 300 890 200 2700 600 890 200 2700 600 675 Interlocking Armor Outer Jacket Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Compliance • TIA/EIA-568-C.3 • ISO/IEC 11801, 2nd Edition • Telcordia GR-409-CORE • RoHS II 2011/65/EU • REACH EC1907-2006 • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • ICEA S-83-596 38 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Armored Distribution Cables (continued) Tight Buffer — Indoor Riser & Plenum Rated Standard Indoor Armored Configurations Belden Part Number Fiber Count OM1 Orange OM3 Aqua OM4 Erika Violet OS2 Yellow Non-Unitized Riser 6 12 24 FI1D006F9 FI1D012F9 FI1D024F9 FI3D006F9 FI3D012F9 FI3D024F9 FI4D006F9 FI4D012F9 FI4D024F9 FISD006F9 FISD012F9 FISD024F9 Non-unitized Plenum 6 12 24 FI1D006A9 FI1D012A9 FI1D024A9 FI3D006A9 FI3D012A9 FI3D024A9 FI4D006A9 FI4D012A9 FI4D024A9 FISD006A9 FISD012A9 FISD024A9 Unitized 6 fiber sub-units plenum 24 FI1D024AJ FI3D024AJ FI4D024AJ FISD024AJ Unitized 12 fiber sub-units plenum 48 FI1D048AK 72 FI1D072AK 96 FI1D096AK 144 FI1D144AK FI3D048AK FI3D072AK FI3D096AK FI3D144AK FI4D048AK FI4D072AK FI4D096AK FI4D144AK FISD048AK FISD072AK FISD096AK FISD144AK Armored Optical Fiber Distribution Cable For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. www.belden.com 1.800.BELDEN.1 (800.235.3361) 39 FiberExpress Armored Distribution Cables (continued) Tight Buffer — Indoor/Outdoor, Riser and Plenum Rated Indoor/Outdoor Specifications Additional Options • Environmental Protection • MSHA (Mining) Approvals – – – – – UV Resistant Jacket Moisture Resistant Jacket Fungus Resistant Jacket Water Blocking Aramid Water Blocking Tape Indoor/Outdoor Specifications Bend Radius (vs. Cable OD) Description Installation 20 x OD Operation 15 x OD Temperature Range Storage Construction Operation -40°C to 70°C (-40°F to 158°F) Legend Sub-Unit Cable OD OD 6 -40°C to 70°C (-40°F to 158°F) -20°C to 70°C (-4°F to 158°F) Fiber mm Non-Unitized Installation Fiber Count mm Operation in. Kg/km lb/1000 ft. 14.5 0.57 189 127 15.7 0.62 150 223 24 17.0 0.67 335 225 24 21.5 0.85 391 263 12 Unitized 6-Fiber Sub-Units 900 μm TB 900 μm TB N/A 4.5 36 25.3 1.00 548 368 Water Swellable Aramid Yarn 48 24.6 0.97 540 363 Central Strength Member 72 27.8 1.09 716 481 32.5 1.28 930 625 Rip Cord Tensile Strength Weight Installation N lbs-f N lbs-f 360 81 1201 270 400 90 1334 300 890 200 2700 600 890 200 2700 600 Numbered Sub-Unit 900 μm Tight Buffered Fiber Water Blocking Tape Inner Jacket Unitized 12-Fiber Sub-Units 96 900 μm TB 5.5 Interlocking Armor 144 Outer Jacket 35.6 1.40 1005 675 Compliance • TIA/EIA-568-C.3 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. • ISO/IEC 11801, 2nd Edition • Telcordia GR-20-CORE • RoHS II 2011/65/EU • REACH EC1907-2006 • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • ICEA S-104-696 40 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Armored Distribution Cables (continued) Tight Buffer — Indoor/Outdoor, Riser & Plenum Rated Standard Indoor / Outdoor Armored Configurations Belden Part Number Fiber Count OM1 Black OM3 Black OM4 Black OS2 Black Non-Unitized Riser 6 12 24 FD1D006F9 FD1D012F9 FD1D024F9 FD3D006F9 FD3D012F9 FD3D024F9 FD4D006F9 FD4D012F9 FD4D024F9 FDSD006F9 FDSD012F9 FDSD024F9 Non-unitized Plenum 6 12 24 FD1D006A9 FD1D012A9 FD1D024A9 FD3D006A9 FD3D012A9 FD3D024A9 FD4D006A9 FD4D012A9 FD4D024A9 FDSD006A9 FDSD012A9 FDSD024A9 Unitized 6 fiber sub-units plenum 24 FD1D024AJ FD3D024AJ FD4D024AJ FDSD024AJ Unitized 12 fiber sub-units plenum 48 FD1D048AK 72 FD1D072AK 96 FD1D096AK 144 FD1D144AK FD3D048AK FD3D072AK FD3D096AK FD3D144AK FD4D048AK FD4D072AK FD4D096AK FD4D144AK FDSD048AK FDSD072AK FDSD096AK FDSD144AK For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. www.belden.com 1.800.BELDEN.1 (800.235.3361) 41 FiberExpress Hybrid Distribution Cables Tight Buffer — Indoor/Outdoor, Riser and Plenum Rated Hybrid cables combine multiple grades of fiber in a single unitized cable easily supporting various applications in a single cable which minimize installation labor. Applications Additional Options • In building backbones • Breakout Cable • Factory floor automation • uMini-Distribution Cable • Broadcast and A/V in-building installation • 2-fiber to 144-fiber constructions • Additional fiber grade combinations Standard Hybrid Cable Color OS2/OM1 OS2/OM4 OS2/OM4 OS2/OM3 OM4/OM3 OM4/OM3 OS2/OM3 OM3/OM1 OM4/OM1 OM4/OM1 OM3/OM1 OS2/OM1 Standard Hybrid Distribution Configurations Building a SmartPart Number 1. Choose FX Fiber Cable 2. Choose Fiber Grade (Primary/Secondary) 3. Choose Family 4. Choose Fiber Configuration 5. Choose Flammability Rating and Protection 6. Choose Subunit Type/ Configuration FI H D H22 P J FX Fiber Cable FI FD Indoor Cable Indoor/Outdoor Cable Fiber Grade (PRI/ SEC) E H F K M OS2/OM4 OS2/OM3 OS2/OM1 OM4/OM1 OM3/OM1 Family Fiber Configuration D 4 Subunits, H13 1 Primary Subunit, 3 Secondary subunits 4 Subunits, H22 2 Primary Subunits, 2 Secondary Subunits 4 Subunits, H31 3 Primary Subunits, 1 Secondary Subunit Distribution Flammability Rating and Protection Plenum Group P Plenum (OFNP) A Plenum Interlocked Aluminum Armor (OFCP) Subunit Type/ Configuration 4.5 mm Subunit, 6 x 900 μm Fiber 5.5 mm Subunit, 12 x 900 μm Fiber J K Riser Group R F Riser (OFNR) Riser Interlocked Aluminum Armor (OFCR) For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. Examples: FIHDH22PJ - Unitized − 6 fiber subunits and for FDEDH31AK's description to say Unitized 12 fiber subunits. FDEDH31AK - FX Indoor/Outdoor Cable, Hybrid Distribution Tight Buffered Cable, Unitized, 48 fiber (36 fiber OS2, 12 fiber OM4), Plenum Armored, Black Jacket 42 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress Reel-In-A-Box Packaging Breakout, Distribution and Mini-Distribution, Indoor Riser & Plenum Rated Lightweight and easy to handle Belden Reel-In-A-Box simplifies fiber cable payout. Rugged box construction and locking reel hub ensures both the box and fiber arrive on the job site intact and the adjustable hub tension always results in the optimal pulling condition. Applications Additional Options • In building backbone • Horizontal distribution for Fiber-to-the-desk • Interconnect Cable (page 34) – Simplex, Duplex and Mini-Round • Passive Optical Networking / Passive Optical LAN • Breakout Cable (page 35) – Up to 4 fibers • Broadcast and A/V in-building installations • Indoor Distribution Cable (page 36) – Up to 12 fibers Reel-In-A-Box Sizes • Indoor/Outdoor Distribution Cable (page 38) – Up to 12 fibers • 500 ft. (152 m) per box • Indoor uMini-Distribution Cable (page 46) – Up to 12 fibers • 1000 ft. (305 m) per box Standard Configurations Belden Part Number Fiber Count OM1 Orange 1000 1 2 1000 2 4 1000 2 4 6 12 1000 12 ft. Box – Interconnect (3 mm Zip Cord), FI1I001PCOBK FI1I002PCOBK ft. Box – Breakout, Plenum FI1B002PBOBK FI1B004PBOBK ft. Box – Distribution, Plenum FI1D002P9OBK FI1D004P9OBK FI1D006P9OBK FI1D012P9OBK ft. Box – uMini-Distribution, Plenum FI1M012P2OBK OM3 Aqua OM4 Erika Violet OS2 Yellow Plenum FI3I001PCABK FI3I002PCABK FI4I001PCEBK FI4I002PCEBK FISI001PCYBK FISI002PCYBK FI3B002PBABK FI3B004PBABK FI4B002PBEBK FI4B004PBEBK FISB002PBYBK FISB004PBYBK FI3D002P9ABK FI3D004P9ABK FI3D006P9ABK FI3D012P9ABK FI4D002P9EBK FI4D004P9EBK FI4D006P9EBK FI4D012P9EBK FISD002P9YBK FISD004P9YBK FISD006P9YBK FISD012P9YBK FI3M012P2ABK FI4M012P2EBK FISM012P2YBK For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. www.belden.com 1.800.BELDEN.1 (800.235.3361) 43 FiberExpress uMini Distribution Cables Indoor Riser & Plenum Rated Reduce diameter and prepare for the future. 250 μm sub-unitized fiber provides the basis for MPO terminations while reducing size and weight all while maintaining compatibility with traditional LC/SC/ST terminations utilizing simple break out kits or labor saving mass fusion splicing. Applications: • In-building backbone • Data Centers • Broadcast and AV in-building installations Base12 Name Indoor Specifications Fiber Count Fiber Sub-Unit OD mm mm in. N/A 3.0 0.12 9 6 3.0 4.8 0.18 11 7 6.5 0.26 38 26 Cable OD Weight Kg/km lb/1000 ft. Tensile Strength lsb-f Operation Installation N lbs-f N lbs-f Indoor uMini-Distribution Cable Bend Radius (vs. Cable OD) Installation 15 x OD Operation 10 x OD NonUnitized 12 250 μm 12 Temperature Range Storage Construction -40°C to 70°C (-40°C to 158°F) Installation (Plenum/LSZH) 0°C to 60°C (32°F to 140°F) Installation (Riser) -10°C to 60°C (14°F to 140°F) Operation (Plenum/LSZH) 0°C to 70°C (32°F to 158°F) Operation (Riser) -20°C to 70°C (-4°F to 158°F) Legend 200.3 45 445 100 200.3 45 668 150 24 36 48 Unitized 12-Fiber Sub-Units 250 μm 72 2.0 7.5 0.30 54 36 96 8.7 0.34 72 49 144 9.9 0.39 80.5 54.1 Rip Cord Numbered Sub-Unit Central Strength Member Aramid Yarn 250 μm Tight Buffered Fiber Filler Unit Outer Jacket Compliance Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. • TIA/EIA-568-C.3 Standard Indoor Configurations • ISO/IEC 11801, 2nd Edition • RoHS II 2011/65/EU • REACH EC1907-2006 • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) • ICEA S-83-596 Belden Part Number Fiber Count • Telcordia GR-409-CORE Non-unitized - Plenum 12 Double-Jacket Unitized - Plenum 12 Unitized - Plenum 24 36 48 72 144 OM3 Aqua OM4 Erika Violet OS2 Yellow FI3M012P2 FI4M012P2 FISM012P2 FI3M012P0 FI4M012P0 FISM012P0 FI3M024P1 FI3M036P1 FI3M048P1 FI3M072P1 FI3M144P1 FI4M024P1 FI4M036P1 FI4M048P1 FI4M072P1 FI4M144P1 FISM024P1 FISM036P1 FISM048P1 FISM072P1 FISM144P1 For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. 44 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. FiberExpress uMini Distribution Cables Indoor Riser & Plenum Rated Base8 Name Indoor Specifications Construction Fiber Fiber Count Sub-Unit OD mm Cable OD Tensile Strength lsb-f Weight Operation mm in. Kg/km lb/1000 ft. N lbs-f Installation N lbs-f Indoor uMini-Distribution Cable NonUnitized 8 Unitized 8-Fiber Sub-Units 8 Bend Radius (vs. Cable OD) Installation 15 x OD Operation 10 x OD Temperature Range 250 μm 250 μm N/A 3.0 3.0 4.8 0.12 0.18 9 11 6 7 200.3 200.3 50 45 445 668 100 Storage Installation (Plenum/LSZH) 0°C to 60°C (32°F to 140°F) Installation (Riser) -10°C to 60°C (14°F to 140°F) Operation (Plenum/LSZH) 0°C to 70°C (32°F to 158°F) Operation (Riser) -20°C to 70°C (-4°F to 158°F) 150 24 6.5 0.26 38 26 32 -40°C to 70°C (-40°C to 158°F) Legend Rip Cord Numbered Sub-Unit 48 Unitized 8-Fiber Sub-Units 7.5 250 μm 0.30 54 36 2.0 Central Strength Member 200.3 45 668 150 Aramid Yarn 250 μm Tight Buffered Fiber 64 8.7 0.34 72 Filler Unit 49 Outer Jacket Compliance • TIA/EIA-568-C.3 • ISO/IEC 11801, 2nd Edition 96 9.9 0.39 80.5 • Telcordia GR-409-CORE 54.1 • RoHS II 2011/65/EU • REACH EC1907-2006 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. • NEC/CEC OFNR/OFN FT.4 (RISER - PVC) • NEC/CEC OFNR/OFN FT.4 (LSZH - FRPE) • NEC/CEC OFNP/OFN FT.6 (PLENUM - PVC or PVDF) Belden Part Number • ICEA S-83-596 Fiber Count Non-Unitized Plenum 8 Double Jacket Unitized - Plenum 8 Unitized Plenum 24 32 48 64 96 OM3 Aqua OM4 Erika Violet OS2 Yellow FI3M008P2 FI4M008P2 FISM008P2 FI3M008P8 FI4M008P8 FISM008P8 FI3M024P8 FI3M032P8 FI3M048P8 FI3M064P8 FI3M096P8 FI4M024P8 FI4M032P8 FI4M048P8 FI4M064P8 FI4M096P8 FISM024P8 FISM032P8 FISM048P8 FISM064P8 FISM096P8 For an exhaustive selection contact Belden customer service or your local Belden Representative for more details. www.belden.com 1.800.BELDEN.1 (800.235.3361) 45 Single-Jacket, All Dielectric Loose Tube Cables Loose Tube — Outdoor Applications: Gel-Filled or Dry Blocked buffer tubes prevent water migration. Full dielectric construction, no grounding required. Available with up to 144 fibers. Length markings in meters for easy determination of cable length. • Medium to high fiber count requirements • Inter-building duct installations • Lashed aerial • Industrial outside plant (OSP Type) Jacket Specifications Jacket Material Outdoor PE Buffer Tube Strength Member Construction Fiber Count Aramid Yarn E-Glass Unitized 6-Fiber Sub-Units Per TIA/EIA 598-B Jacket Color Black Cable OD Tensile Strength lsb-f Installation Operation Weight mm in. 6 10.5 0.41 87 59 12 24 36 48 10.5 0.41 87 59 72 11.5 0.45 106 71 96 13.2 0.52 136 91 144 17 0.67 220 148 PBT Central Strength Member Color Code (Buffer) Name Kg/km lb/1000 ft. N lbs-f N lbs-f 2700 600 890 200 2700 600 890 200 Specifications Temperature Range (Outdoor Series) Storage Operating -40°C to 75°C -40°C to 70°C Min. Bend Radius Installation Long Term 20 x OD 15 x OD Unitized 12-Fiber Sub-Units Legend Rip Cord Numbered Sub Unit Central Strength Member Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. 250 μm Fiber Outer Jacket Moisture Blocking Agent Compliance • TIA/EIA-568-C.3 • ICEA S-87-640 • GR-20-CORE 46 Fiber Count OM1 OM2 Outside Plant — Gel Filled Buffer Tubes 6 FS1L006NF FS2L006NF 12 FS1L012NG FS2L012NG 24 FS1L024NG FS2L024NG 36 FS1L036NG FS2L036NG 48 FS1L048NG FS2L048NG 72 FS1L072NG FS2L072NG 96 FS1L096NG FS2L096NG 144 FS1L144NG FS2L144NG Outside Plant — Dry Buffer Tubes 6 FS1L006NC FS2L006NC 12 FS1L012ND FS2L012ND 24 FS1L024ND FS2L024ND 36 FS1L036ND FS2L036ND 48 FS1L048ND FS2L048ND 72 FS1L072ND FS2L072ND 96 FS1L096ND FS2L096ND 144 FS1L144ND FS2L144ND 1.800.BELDEN.1 (800.235.3361) Belden Part Number OM3 OM4 OS2 FS3L006NF FS3L012NG FS3L024NG FS3L036NG FS3L048NG FS3L072NG FS3L096NG FS3L144NG FS4L006NF FS4L012NG FS4L024NG FS4L036NG FS4L048NG FS4L072NG FS4L096NG FS4L144NG FSSL006NF FSSL012NG FSSL024NG FSSL036NG FSSL048NG FSSL072NG FSSL096NG FSSL144NG FS3L006NC FS3L012ND FS3L024ND FS3L036ND FS3L048ND FS3L072ND FS3L096ND FS3L144ND FS4L006NC FS4L012ND FS4L024ND FS4L036ND FS4L048ND FS4L072ND FS4L096ND FS4L144ND FSSL006NC FSSL012ND FSSL024ND FSSL036ND FSSL048ND FSSL072ND FSSL096ND FSSL144ND www.belden.com Faster. Easier. Better. Single-Jacket, All Dielectric Loose Tube Cables (continued) Loose Tube — Indoor/Outdoor Riser Applications: Gel-Filled or Dry Blocked buffer tubes prevent water migration. All-dielectric strength member. Available as Riser rated cable, thereby eliminating the need for service entrance splicing to in-building cable. Full dielectric construction, no grounding required. Available with up to 144 fibers. Length markings in meters for easy determination of cable length. Name Construction Unitized 6-Fiber Sub-Units Fiber Count 6 • Medium to high fiber count requirements • Inter-building duct installations • Lashed aerial • Indoor/outdoor Jacket Specifications Cable OD mm in. 12.9 0.51 Tensile Strength lsb-f Weight Kg/km lb/1000 ft. 164 110 Installation Operation N lbs-f N lbs-f 2700 600 890 200 Jacket Material Riser PVC Buffer Tube PBT Strength Member Aramid Yarn Central Strength Member 12 24 36 48 Color Code (Buffer) 12.9 0.51 164 110 E-Glass Per TIA/EIA 598-B Jacket Color Black Ratings Unitized 12-Fiber Sub-Units 72 13.7 0.54 190 128 96 15.5 0.61 237 159 Riser UL Type cUL Type Flame Resistance 2700 600 890 OFNR OFN FT4 UL 1666 200 Specifications Min. Bend Radius Installation Long Term 144 19.3 0.76 361 Temperature Range (Riser Series) Storage Operating 243 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. No. of Fibers No. of Fibers Per Bundle -40°C to 75°C -40°C to 70°C Legend Smart Part to Legacy Part Number Cross Rip Cord OM1 Riser (NEC/CEC OFNR/OFN FT.4) 6 6 FD1L006RF 12 12 FD1L012RG 24 12 FD1L024RG 36 12 FD1L036RG 48 12 FD1L048RG 72 12 FD1L072RG 96 12 FD1L096RG 144 12 FD1L144RG Riser (NEC/CEC OFNR/OFN FT.4) 6 6 FD1L006RC 12 12 FD1L012RD 24 12 FD1L024RD 36 12 FD1L036RD 48 12 FD1L048RD 72 12 FD1L072RD 96 12 FD1L096RD 144 12 FD1L144RD www.belden.com 20 x OD 15 x OD OM2 OM3 OM4 OS2 Numbered Sub Unit Indoor/Outdoor — Gel Filled Buffer Tubes FD2L006RF FD3L006RF FD4L006RF FD2L012RG FD3L012RG FD4L012RG FD2L024RG FD3L024RG FD4L024RG FD2L036RG FD3L036RG FD4L036RG FD2L048RG FD3L048RG FD4L048RG FD2L072RG FD3L072RG FD4L072RG FD2L096RG FD3L096RG FD4L096RG FD2L144RG FD3L144RG FD4L144RG Indoor/Outdoor — Dry Buffer Tubes FD2L006RC FD3L006RC FD4L006RC FD2L012RD FD3L012RD FD4L012RD FD2L024RD FD3L024RD FD4L024RD FD2L036RD FD3L036RD FD4L036RD FD2L048RD FD3L048RD FD4L048RD FD2L072RD FD3L072RD FD4L072RD FD2L096RD FD3L096RD FD4L096RD FD2L144RD FD3L144RD FD4L144RD FDSL006RF FDSL012RG FDSL024RG FDSL036RG FDSL048RG FDSL072RG FDSL096RG FDSL144RG Central Strength Member 250 μm Fiber Outer Jacket Moisture Blocking Agent Compliance FDSL006RC FDSL012RD FDSL024RD FDSL036RD FDSL048RD FDSL072RD FDSL096RD FDSL144RD 1.800.BELDEN.1 (800.235.3361) • TIA/EIA-568-C.3 • ICEA S-104-696 • GR-20-CORE 47 Single-Jacket, Single Armor Loose Tube Cables Loose Tube – Outdoor Applications: Gel-Filled or Dry Blocked buffer tubes prevent water migration. Available as Riser rated cable, thereby eliminating the need for service entrance splicing to in-building cable. Rodent resistant. Available in sizes up to 144 fibers. Length markings in meters for easy determination of cable length. Jacket Specifications Name Jacket Material Outdoor Riser Buffer Tube Strength Member PE PVC Thermoplastic Color Code (Buffer) Unitized 6-Fiber Sub-Units Aramid Yarn Central Strength Member Armor Construction E-Glass Corrugated Steel Tape Fiber Count • Direct burial • Low to high fiber count requirements • Inter-building duct installations • Industrial outside plant (OSP Type) Cable OD Tensile Strength lsb-f Installation Operation Weight mm in. Kg/km lb/1000 ft. 6 13.2 0.52 140 94 12 24 36 48 13.2 0.52 140 94 72 14 0.55 161 108 96 15.8 0.62 193 130 144 19.6 0.77 285 192 N lbs-f N lbs-f 2700 600 800 180 2700 600 800 180 Per TIA/EIA 598-B Jacket Color Black Specifications Temperature Range (Outdoor) Storage Operating -40°C to 75°C -40°C to 70°C Min. Bend Radius Installation Long Term Unitized 12-Fiber Sub-Units 20 x OD 15 x OD Legend Corrugated Steel Armor Rip Cord Numbered Sub Unit Central Strength Member 250 μm Fiber Outer Jacket Compliance • TIA/EIA-568-C.3 • ICEA S-87-640 • GR-20-CORE 48 Moisture Blocking Agent Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. No. of Fibers No. of Fibers Per Bundle Outside Plant — 6 6 12 12 24 12 48 12 72 12 96 12 144 12 Outside Plant — 6 6 12 12 24 12 48 12 72 12 96 12 144 12 OM1 OM2 Gel Filled Buffer Tubes FS1L0066F FS2L0066F FS1L0126G FS2L0126G FS1L0246G FS2L0246G FS1L0486G FS2L0486G FS1L0726G FS2L0726G FS1L0966G FS2L0966G FS1L1446G FS2L1446G Dry Buffer Tubes FS1L0066C FS2L0066C FS1L0126D FS2L0126D FS1L0246D FS2L0246D FS1L0486D FS2L0486D FS1L0726D FS2L0726D FS1L0966D FS2L0966D FS1L1446D FS2L1446D 1.800.BELDEN.1 (800.235.3361) Belden Part Number OM3 OM4 OS2 FS3L0066F FS3L0126G FS3L0246G FS3L0486G FS3L0726G FS3L0966G FS3L1446G FS4L0066F FS4L0126G FS4L0246G FS4L0486G FS4L0726G FS4L0966G FS4L1446G FSSL0066F FSSL0126G FSSL0246G FSSL0486G FSSL0726G FSSL0966G FSSL1446G FS3L0066C FS3L0126D FS3L0246D FS3L0486D FS3L0726D FS3L0966D FS3L1446D FS4L0066C FS4L0126D FS4L0246D FS4L0486D FS4L0726D FS4L0966D FS4L1446D FSSL0066C FSSL0126D FSSL0246D FSSL0486D FSSL0726D FSSL0966D FSSL1446D www.belden.com Faster. Easier. Better. Double-Jacket, Armored Loose Tube Cables Loose Tube – Outdoor Applications: Gel-filled buffer tubes prevent water migration. Available as Riser rated cable, thereby eliminating the need for service entrance splicing to in-building cable. Rodent resistant. Available in sizes up to 216 fibers. Length markings in meters for easy determination of cable length. Name Construction Unitized 6-Fiber Sub-Units Fiber Count 6 12 24 36 48 • Direct burial • Low to high fiber count requirements • Inter-building duct installations • Industrial outside plant (OSP Type) Cable OD Tensile Strength lsb-f Installation Operation Weight mm in. Kg/km lb/1000 ft. 15.5 0.62 200 134 N lbs-f N lbs-f 2670 600 890 200 Jacket Specifications Jacket Material Outdoor Riser Buffer Tube Strength Member 15.5 0.62 200 Armor 16.4 0.65 206 Thermoplastic Aramid Yarn Central Strength Member 134 Color Code (Buffer) 72 PE PVC E-Glass Corrugated Steel Tape Per TIA/EIA 598-B Jacket Color 138 Black Specifications Unitized 12-Fiber Sub-Units 2670 96 18.2 0.72 254 600 890 200 170 Temperature Range (Outdoor) Storage Operating -40°C to 75°C -40°C to 70°C Min. Bend Radius Installation Long Term 144 22.9 0.9 385 259 20 x OD 15 x OD Legend Outer Jacket Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Rip Cord Numbered Sub-Unit No. of Fibers Outdoor 6 12 24 36 48 72 96 144 No. of Fibers Per Bundle OM1 OM2 OM3 OM4 OS2 6 12 12 12 12 12 12 12 FS1H0066F FS1H0126G FS1H0246G FS1H0366G FS1H0486G FS1H0726G FS1H0966G FS1H1446G FS2H0066F FS2H0126G FS2H0246G FS2H0366G FS2H0486G FS2H0726G FS2H0966G FS2H1446G FS3H0066F FS3H0126G FS3H0246G FS3H0366G FS3H0486G FS3H0726G FS3H0966G FS3H1446G FS4H0066F FS4H0126G FS4H0246G FS4H0366G FS4H0486G FS4H0726G FS4H0966G FS4H1446G FSSH0066F FSSH0126G FSSH0246G FSSH0366G FSSH0486G FSSH0726G FSSH0966G FSSH1446G Belden Part Number Central Strength Member 250 μm Fiber Inner Jacket www.belden.com 1.800.BELDEN.1 (800.235.3361) Moisture Blocking Gel Compliance Steel Corrugated Armor • TIA/EIA-568-C.3 • ICEA S-87-640 • GR-20-CORE 49 Double-Jacket, Armored Loose Tube Cables (continued) Loose Tube – Indoor/Outdoor Riser Rated Applications: Gel-filled buffer tubes prevent water migration. Available as Riser rated cable, thereby eliminating the need for service entrance splicing to in-building cable. Rodent resistant. Available in sizes up to 216 fibers. Length markings in meters for easy determination of cable length. Jacket Specifications Name Jacket Material Riser Buffer Tube Strength Member Color Code (Buffer) Fiber Count Thermoplastic Aramid Yarn Unitized 6-Fiber Sub-Units E-Glass Corrugated Steel Tape Per TIA/EIA 598-B Jacket Color • Low to high fiber count requirements • Inter-building duct installations • Indoor/outdoor Cable OD Weight mm in. 6 13.7 0.54 205 138 12 24 36 48 13.7 0.54 205 138 72 16.8 0.66 256 172 96 17.8 0.7 307 206 144 22.4 0.88 449 302 PVC Central Strength Member Armor Construction • Direct burial Kg/km lb/1000 ft. Tensile Strength lsb-f Installation Operation N lbs-f N lbs-f 2700 600 890 200 2700 600 890 200 Black Ratings Riser OFCR Specifications Temperature Range (Riser) Storage Operating Unitized 12-Fiber Sub-Units -40°C to 80°C -40°C to 70°C Min. Bend Radius Installation Long Term 20 x OD 15 x OD Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Legend Outer Jacket Rip Cord Numbered Sub-Unit Central Strength Member 250 μm Fiber Inner Jacket Moisture Blocking Gel Steel Corrugated Armor No. of Fibers Belden Part Number OM1 OM2 OM3 OFCR/OFC FT.4) Indoor/Outdoor FD1H0065F FD2H0065F FD3H0065F FD1H0125G FD2H0125G FD3H0125G FD1H0245G FD2H0245G FD3H0245G FD1H0365G FD2H0365G FD3H0365G FD1H0485G FD2H0485G FD3H0485G FD1H0725G FD2H0725G FD3H0725G FD1H0965G FD2H0965G FD3H0965G FD1H1445G FD2H1445G FD3H1445G No. of Fibers Per Bundle Riser (NEC/CEC 6 6 12 12 24 12 36 12 48 12 72 12 96 12 144 12 OM4 OS2 FD4H0065F FD4H0125G FD4H0245G FD4H0365G FD4H0485G FD4H0725G FD4H0965G FD4H1445G FDSH0065F FDSH0125G FDSH0245G FDSH0365G FDSH0485G FDSH0725G FDSH0965G FDSH1445G Compliance • TIA/EIA-568-C.3 • ICEA S-104-696 • GR-20-CORE 50 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. Double-Jacket, Heavy-Duty Loose Tube Cables Loose Tube — Outdoor Applications: Gel-filled buffer tubes prevent water migration. Available with up to 216 fibers. • Direct burial • Harsh environments • Applications requiring good ozone-, moisture- and weather-resistance Name Construction Fiber Count Cable OD mm Tensile Strength lsb-f Installation Operation Weight in. Kg/km lb/1000 ft. N lbs-f N lbs-f 2 Unitized 12-Fiber Sub-Units 4 12.5 0.49 125 84 2700 600 890 200 Jacket Specifications Jacket Material Outdoor 6 Buffer Tube 12 Strength Member 24 Central Strength Member 36 12.5 0.49 125 84 Core Wrap 48 Color Code (Buffer) PE PBT Aramid Yarn E-Glass Water Swellable Tape Per TIA/EIA 598-B Jacket Color 72 13.4 0.53 144 Black 97 Specifications Unitized 12-Fiber Sub-Units 2700 96 15.2 0.6 180 600 890 200 121 Temperature Range Storage Operating -40°C to 75°C -40°C to 70°C Min. Bend Radius Installation Long Term 20 x OD 15 x OD Legend 144 19 0.75 274 Outer Jacket 184 Rip Cord Numbered Sub Unit Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. No. of Fibers Outdoor 2 4 6 8 12 18 24 36 48 72 96 144 216 No. of Fibers Per Bundle OM1 2 4 6 8 12 12 12 12 12 12 12 12 12 FS1H002NF FS1H004NF FS1H006NF FS1H008NG FS1H012NG FS1H018NG FS1H024NG FS1H036NG FS1H048NG FS1H072NG FS1H096NG FS1H144NG FS1H216NG www.belden.com Central Strength Member 250 μm Fiber Belden Part Number OM2 OM3 OM4 Inner Jacket OS2 Moisture Blocking Gel FS2H002NF FS2H004NF FS2H006NF FS2H008NG FS2H012NG FS2H018NG FS2H024NG FS2H036NG FS2H048NG FS2H072NG FS2H096NG FS2H144NG FS2H216NG FS3H002NF FS3H004NF FS3H006NF FS3H008NG FS3H012NG FS3H018NG FS3H024NG FS3H036NG FS3H048NG FS3H072NG FS3H096NG FS3H144NG FS3H216NG FS4H002NF FS4H004NF FS4H006NF FS4H008NG FS4H012NG FS4H018NG FS4H024NG FS4H036NG FS4H048NG FS4H072NG FS4H096NG FS4H144NG FS4H216NG FSSH002NF FSSH004NF FSSH006NF FSSH008NG FSSH012NG FSSH018NG FSSH024NG FSSH036NG FSSH048NG FSSH072NG FSSH096NG FSSH144NG FSSH216NG 1.800.BELDEN.1 (800.235.3361) Aramid Strength Members Compliance • TIA/EIA-568-C.3 • ICEA S-87-640 • GR-20-CORE 51 Central Tube Cables Loose Tube — Outdoor, and Outdoor Armored Applications: Economical option for low fiber counts. Quick and easy end preparation. Fully waterblocked with gel-filled buffer tube. No rods – easy handling. Crush, impact and abrasion resistant. • Campus OSP backbones • Drop cable • Telecommunications and data trunk • Direct burial (armored only) • Lashed aerial Jacket Specifications Name Jacket Material PBT Color Code (Buffer) Fiberglass Jacket Color Black in. 7.8 0.31 Kg/km lb/1000 ft. Installation Operation N lbs-f N lbs-f Single Subunit 50 34 2700 600 890 200 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Belden Part Number Specifications Temperature Range Storage Operating 2 4 6 8 12 24 Corrugated Steel Tape Per TIA/EIA 598-B mm Tensile Strength lsb-f Weight Outdoor Water Swellable Tape Strength Member Armor Cable OD Fiber Count PE Buffer Tube Core Wrap Construction -40°C to 75°C -40°C to 70°C Min. Bend Radius Installation Long Term 20 x OD 15 x OD Legend No. of Fibers OM1 OM2 OM3 OM4 OS2 Outdoor 2 4 6 8 10 12 FS1C002N0 FS1C004N0 FS1C006N0 FS1C008N0 FS1C010N0 FS1C012N0 FS2C002N0 FS2C004N0 FS2C006N0 FS2C008N0 FS2C010N0 FS2C012N0 FS3C002N0 FS3C004N0 FS3C006N0 FS3C008N0 FS3C010N0 FS3C012N0 FS4C002N0 FS4C004N0 FS4C006N0 FS4C008N0 FS4C010N0 FS4C012N0 FSSC002N0 FSSC004N0 FSSC006N0 FSSC008N0 FSSC010N0 FSSC012N0 Name Construction Outer Jacket Strength Elements Buffer Tube Cable OD Fiber Count mm in. 12.2 0.48 Tensile Strength lsb-f Weight Kg/km lb/1000 ft. Installation Operation N lbs-f N lbs-f 2700 600 890 200 Water Blocking Gel Outdoor Armored Corrugated Steel Armor Compliance 2 4 6 8 12 24 Single Subunit • TIA/EIA-568-C.3 • GR-20-CORE • ICEA S-87-640 140 95 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Belden Part Number No. of Fibers OM1 Outdoor Armored 2 FS1C00260 4 FS1C00460 6 FS1C00660 8 FS1C00860 10 FS1C01060 12 FS1C01260 52 1.800.BELDEN.1 (800.235.3361) OM2 OM3 OM4 OS2 FS2C00260 FS2C00460 FS2C00660 FS2C00860 FS2C01060 FS2C01260 FS3C00260 FS3C00460 FS3C00660 FS3C00860 FS3C01060 FS3C01260 FS4C00260 FS4C00460 FS4C00660 FS4C00860 FS4C01060 FS4C01260 FSSC00260 FSSC00460 FSSC00660 FSSC00860 FSSC01060 FSSC01260 www.belden.com Faster. Easier. Better. FiberExpress Drop Cables Tight Buffer - Indoor/Outdoor Riser Indoor/Outdoor Specifications: *Environmental Protection Fast installation, easy termination. Cables provide easy routing and 900 μm tightbuffered fiber support fast and robust field terminations. Ideal for fiber to the subscriber applications. • UV Resistant Jacket • Moisture Resistant Jacket • Fungus Resistant Jacket • Water blocking aramid Name Construction Fiber Count Cable OD mm 1 Fiber Drop Cable 1 4.8 in. 0.19 Tensile Strength lsb-f Weight Kg/km lb/1000 ft. 21 14 Operation Installation N N 200 lbs-f 40 445 lbs-f Specifications Temperature Range Storage Operating -40°C to 75°C -40°C to 70°C 100 Above specifications provide a general representation for the product family. Improved specifications may exist for Riser, Plenum or LSZH constructions. Consult individual technical data sheets for exact specifications. Min. Bend Radius Installation Long Term 0.2" (5 mm) 0.2" (5 mm) Temperature Range Belden Part Number Fiber Count Black White Drop cable with ITU G.657.B3 Glass — Riser 1 FDCP001R9 FDCP001R9W Drop cable with ITU G.657.B3 Glass — Riser — 450m Reel-In-A-Box Put-Up 1 FDCP001R9NBY FDCP001R9WBY Temperature Range Storage Operating -40°C to 75°C -40°C to 70°C Legend Atamid Yarn 900 um Tight Buffered Fiber Outer Jacket Compliance • TIA/EIA-568-C.3 • ICEA-S-104-696 • C(ETL)US TYPE OFNR • CSA OFN FT4 • TPR.9424 www.belden.com 1.800.BELDEN.1 (800.235.3361) 53 Part Number Index Part No. A0643206 A0643207 A0649869 AC301420 AC302349 AX100041 AX100045 AX100066 AX100068 AX100094 AX100098 AX100116 AX100220 AX100221 AX100222 AX100223 AX100495 AX100528 AX100532 AX100534 AX100540 AX100542 AX100951 AX101100 AX101101 AX101320 AX101321 AX101326 AX101407 AX101409 AX101729 AX101731 AX101741 AX101743 AX102242 AX102243 AX102244 AX102282 AX102283 AX102288 AX102683 AX102684 AX102685 AX103151 AX103912 AX103913 AX103928 54 Page 28 28 17 17 17 17 17 17 17 17 17 17 29 29 29 29 17 17 17 17 17 17 5 5 5 15 15 15 17 17 17 17 17 17 15, 29 15, 29 15, 29 15 15 15 15, 29 15, 29 15, 29 5 16 16 16 Part No. AX103930 AX103932 AX103934 AX104019 AX104023 AX104024 AX104210 AX104214 AX104215 AX104271 AX104276 AX104278 AX104279 AX104280 AX104281 AX104282 AX104283 AX104286 AX104289 AX104290 AX104291 AX104293 AX104572 AX104593 AX104615 AX104681 AX104682 AX104683 AX104684 AX104685 AX104695 AX104696 AX104934 AX104937 AX104938 AX104939 AX105002-B25 AX105162 AX105164 AX105165 AX105166 AX105167 AX105200-B25 AX105202-B25 AX105203-B25 AX105203-S1 AX105205-B25 Page 16 16 16 15 15 15 15 15 15 5 5 5 5 5 5 5 5 5 5 5 5 5 15 5 29 9 9 9 9 10, 15 5 5 17 15, 29 15, 29 15, 29 29 9 9 9 9 9 4 4 4 4 4 Part No. AX105207-B25 AX105208-B25 AX105208-S1 AX105209-B25 AX105209-S1 AX105210-B25 AX105212-B25 AX105213-B25 AX105213-S1 AX105214-B25 AX105215-B25 AX105252-B25 AX105253-B25 AX105254-B25 AX105379 AX105505-AL AX105505-BK AX105505-WH AX105537 AX105561 AX105563 AX105564 AX105565 AX105641-AL AX105641-BK AX105641-EW AX105643-AL AX105643-BK AX105643-EW AX105646-B25 AX105672 AX105673 AX105674 AX105675 AX105676 AX105678 AX105691-B25 AX105692-B25 AX105693-B25 AX105694-B25 AX105697-AL AX105697-BK AX105697-WH AX105700 AX105812 AX105813 AX106817 1.800.BELDEN.1 (800.235.3361) Page 4 4 4 4 4 4 4 4 4 4 4 4 4 4 9 29 29 29 17 17 9 9 9 15, 29 15, 29 15, 29 15, 29 15, 29 15, 29 29 9 9 9 9 9 9 29 29 29 29 29 29 29 15 9 9 16 Part No. AX106818 AX203567 AX203568 AX203569 AX203895 AX203930 FC1H06SDFS FC1H12LDFS FC1H12MPFS FC1U06SDMF FC1U06SDMF1T FC1U12LDMF FC1U12LDMF1T FC3H06SDFS FC3H12LDFS FC3H12MPFS FC3H16LD4F FC3H18LDMF FC3H18LDMF1A FC3L06SDMF FC3L06SDMF1A FC3L12LD4F FC3L12LDMF FC3L12LDMF1A FC3R06SDMF FC3R06SDMF1A FC3R12LDMF FC3R12LDMF1A FC3U04LD4F FC3U06SDMF FC3U06SDMF1A FC3U08LD4F FC3U12LD4F FC3U12LDMF FC3U12LDMF1A FC3U034MMF FC3U064MMF FC4H06SDFS FC4H12LDFS FC4H12MPFS FC4H16LD4F FC4H18LDMF FC4H18LDMF1E FC4L06SDMF FC4L06SDMF1E FC4L12LD4F FC4L12LDMF Page 16 5 5 5 5 5 10 10 10 10 10 10 10 10 10 10 12 10 10 11 11 12 11 11 11 11 11 11 12 10 10 12 12 10 10 12 12 10 10 10 12 10 10 11 11 12 11 Part No. Page FC4L12LDMF1E FC4R06SDMF FC4R06SDMF1E FC4R12LDMF FC4R12LDMF1E FC4U04LD4F FC4U06SDMF FC4U06SDMF1E FC4U08LD4F FC4U12LD4F FC4U12LDMF FC4U12LDMF1E FC4U034MMF FC4U064MMF FCSH06SDFS FCSH12LAFS FCSH12LDFS FCSH12MPFS FCSH12SBFS FCSH12STFS FCSH16LD4F FCSH18LAMF FCSH18LAMF1G FCSH18LDMF FCSH18LDMF1B FCSL06SDMF FCSL06SDMF1B FCSL12LD4F FCSL12LDMF FCSL12LDMF1B FCSR06SDMF FCSR06SDMF1B FCSR12LDMF FCSR12LDMF1B FCSU04LD4F FCSU06SAMF FCSU06SAMF1G FCSU06SDMF FCSU06SDMF1B FCSU08LD4F FCSU12LAMF FCSU12LAMF1G FCSU12LD4F FCSU12LDMF FCSU12LDMF1B FCSU12SBMF FCSU12SBMF1G 11 11 11 11 11 12 10 10 12 12 10 10 12 12 10 10 10 10 10 10 12 10 10 10 10 11 11 12 11 11 11 11 11 11 12 10 10 10 10 12 10 10 12 10 10 10 10 www.belden.com Faster. Easier. Better. Part No. FCSU12SCMF FCSU12SCMF1B FCSU034MMF FCSU064MMF FCZ00BBFS FD1D002L9 FD1D002P9 FD1D002R9 FD1D006A9 FD1D006F9 FD1D006L9 FD1D006P9 FD1D006R9 FD1D012A9 FD1D012F9 FD1D012L9 FD1D012P9 FD1D012R9 FD1D024A9 FD1D024AJ FD1D024F9 FD1D024L9 FD1D024P9 FD1D024PJ FD1D024R9 FD1D024RJ FD1D048AK FD1D048LK FD1D048PK FD1D072AK FD1D072LK FD1D072PK FD1D096AK FD1D096LK FD1D096PK FD1D144AK FD1D144LK FD1D144PK FD1H0065F FD1H0125G FD1H0245G FD1H0365G FD1H0485G FD1H0725G FD1H0965G FD1H1445G FD1L006RC FD1L006RF FD1L012RD www.belden.com Page 10 10 12 12 10 37 37 37 41 41 37 37 37 41 41 37 37 37 41 41 41 37 37 37 37 37 41 37 37 41 37 37 41 37 37 41 37 37 50 50 50 50 50 50 50 50 47 47 47 Part No. FD1L012RG FD1L024RD FD1L024RG FD1L036RD FD1L036RG FD1L048RD FD1L048RG FD1L072RD FD1L072RG FD1L096RD FD1L096RG FD1L144RD FD1L144RG FD2H0065F FD2H0125G FD2H0245G FD2H0365G FD2H0485G FD2H0725G FD2H0965G FD2H1445G FD2L006RC FD2L006RF FD2L012RD FD2L012RG FD2L024RD FD2L024RG FD2L036RD FD2L036RG FD2L048RD FD2L048RG FD2L072RD FD2L072RG FD2L096RD FD2L096RG FD2L144RD FD2L144RG FD3D002L9 FD3D002P9 FD3D002R9 FD3D006A9 FD3D006F9 FD3D006L9 FD3D006P9 FD3D006R9 FD3D012A9 FD3D012F9 FD3D012L9 FD3D012P9 Page 47 47 47 47 47 47 47 47 47 47 47 47 47 50 50 50 50 50 50 50 50 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 37 37 37 41 41 37 37 37 41 41 37 37 Part No. FD3D012R9 FD3D024A9 FD3D024AJ FD3D024F9 FD3D024L9 FD3D024P9 FD3D024PJ FD3D024R9 FD3D024RJ FD3D048AK FD3D048LK FD3D048PK FD3D072AK FD3D072LK FD3D072PK FD3D096AK FD3D096LK FD3D096PK FD3D144AK FD3D144LK FD3D144PK FD3H0065F FD3H0125G FD3H0245G FD3H0365G FD3H0485G FD3H0725G FD3H0965G FD3H1445G FD3L006RC FD3L006RF FD3L012RD FD3L012RG FD3L024RD FD3L024RG FD3L036RD FD3L036RG FD3L048RD FD3L048RG FD3L072RD FD3L072RG FD3L096RD FD3L096RG FD3L144RD FD3L144RG FD4D002L9 FD4D002P9 FD4D002R9 FD4D006A9 Page 37 41 41 41 37 37 37 37 37 41 37 37 41 37 37 41 37 37 41 37 37 50 50 50 50 50 50 50 50 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 37 37 37 41 Part No. FD4D006F9 FD4D006L9 FD4D006P9 FD4D006R9 FD4D012A9 FD4D012F9 FD4D012L9 FD4D012P9 FD4D012R9 FD4D024A9 FD4D024AJ FD4D024F9 FD4D024L9 FD4D024P9 FD4D024PJ FD4D024R9 FD4D024RJ FD4D048AK FD4D048LK FD4D048PK FD4D072AK FD4D072LK FD4D072PK FD4D096AK FD4D096LK FD4D096PK FD4D144AK FD4D144LK FD4D144PK FD4H0065F FD4H0125G FD4H0245G FD4H0365G FD4H0485G FD4H0725G FD4H0965G FD4H1445G FD4L006RC FD4L006RF FD4L012RD FD4L012RG FD4L024RD FD4L024RG FD4L036RD FD4L036RG FD4L048RD FD4L048RG FD4L072RD FD4L072RG 1.800.BELDEN.1 (800.235.3361) Page 41 37 37 37 41 41 37 37 37 41 41 41 37 37 37 37 37 41 37 37 41 37 37 41 37 37 41 37 37 50 50 50 50 50 50 50 50 47 47 47 47 47 47 47 47 47 47 47 47 Part No. FD4L096RD FD4L096RG FD4L144RD FD4L144RG FDCP001R9 FDCP001R9NBY FDCP001R9W FDCP001R9WBY FDSD002L9 FDSD002P9 FDSD002R9 FDSD006A9 FDSD006F9 FDSD006L9 FDSD006P9 FDSD006R9 FDSD012A9 FDSD012F9 FDSD012L9 FDSD012P9 FDSD012R9 FDSD024A9 FDSD024AJ FDSD024F9 FDSD024L9 FDSD024P9 FDSD024PJ FDSD024R9 FDSD024RJ FDSD048AK FDSD048LK FDSD048PK FDSD072AK FDSD072LK FDSD072PK FDSD096AK FDSD096LK FDSD096PK FDSD144AK FDSD144LK FDSD144PK FDSH0065F FDSH0125G FDSH0245G FDSH0365G FDSH0485G FDSH0725G FDSH0965G FDSH1445G Page 47 47 47 47 53 53 53 53 37 37 37 41 41 37 37 37 41 41 37 37 37 41 41 41 37 37 37 37 37 41 37 37 41 37 37 41 37 37 41 37 37 50 50 50 50 50 50 50 50 55 Part No. FDSL006RC FDSL006RF FDSL012RD FDSL012RG FDSL024RD FDSL024RG FDSL036RD FDSL036RG FDSL048RD FDSL048RG FDSL072RD FDSL072RG FDSL096RD FDSL096RG FDSL144RD FDSL144RG FF1U06SD FF1U12LD FF3H18LD FF3H18MP FF3U06SD FF3U12LD FF3U12MP FF4H18LD FF4H18MP FF4U06SD FF4U12LD FF4U12MP FFSH18LA FFSH18LD FFSH18MP FFSU06SA FFSU06SD FFSU12LA FFSU12LD FFSU12MP FFSU12SB FFSU12SC FFSU12ST FFZH00BB FFZH06KC FFZH08KC FI1B002LB FI1B002PB FI1B002PBOBK FI1B004LB FI1B004PB FI1B004PBOBK 56 Page 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 15 15 15 33 33 43 33 33 43 Part No. FI1B006LB FI1B006PB FI1B012LB FI1B012PB FI1D002P9 FI1D002P9OBK FI1D002R9 FI1D004P9OBK FI1D006A9 FI1D006F9 FI1D006P9 FI1D006P9OBK FI1D006R9 FI1D012A9 FI1D012F9 FI1D012P9 FI1D012P9OBK FI1D012R9 FI1D024A9 FI1D024AJ FI1D024F9 FI1D024P9 FI1D024PJ FI1D024R9 FI1D024RJ FI1D036PK FI1D048AK FI1D048PK FI1D072AK FI1D072PK FI1D096AK FI1D096PK FI1D144AK FI1D144PK FI1I001PCOBK FI1I002PCOBK FI1M012P2OBK FI3B002LB FI3B002PB FI3B002PBABK FI3B004LB FI3B004PB FI3B004PBABK FI3B006LB FI3B006PB FI3B012LB FI3B012PB FI3D002P9 Page 33 33 33 33 35 43 35 43 39 39 35 43 35 39 39 35 43 35 39 39 39 35 35 35 35 35 39 35 39 35 39 35 39 35 43 43 43 33 33 43 33 33 43 33 33 33 33 35 Part No. FI3D002P9ABK FI3D002R9 FI3D004P9ABK FI3D006A9 FI3D006F9 FI3D006P9 FI3D006P9ABK FI3D006R9 FI3D012A9 FI3D012F9 FI3D012P9 FI3D012P9ABK FI3D012R9 FI3D024A9 FI3D024AJ FI3D024F9 FI3D024P9 FI3D024PJ FI3D024R9 FI3D024RJ FI3D036PK FI3D048AK FI3D048PK FI3D072AK FI3D072PK FI3D096AK FI3D096PK FI3D144AK FI3D144PK FI3I001PCABK FI3I001RB FI3I001RC FI3I002P0 FI3I002PCABK FI3I002RB FI3I002RC FI3I008P0 FI3I012P0 FI3M008P2 FI3M008P8 FI3M012P0 FI3M012P2 FI3M012P2ABK FI3M024P1 FI3M024P8 FI3M032P8 FI3M036P1 FI3M048P1 1.800.BELDEN.1 (800.235.3361) Page 43 35 43 39 39 35 43 35 39 39 35 43 35 39 39 39 35 35 35 35 35 39 35 39 35 39 35 39 35 43 32 32 32 43 32 32 32 32 45 45 44 44 43 44 45 45 44 44 Part No. FI3M048P8 FI3M064P8 FI3M072P1 FI3M096P8 FI3M144P1 FI4B002LB FI4B002PB FI4B002PBEBK FI4B004LB FI4B004PB FI4B004PBEBK FI4B006LB FI4B006PB FI4B012LB FI4B012PB FI4D002P9 FI4D002P9EBK FI4D002R9 FI4D004P9EBK FI4D006A9 FI4D006F9 FI4D006P9 FI4D006P9EBK FI4D006R9 FI4D012A9 FI4D012F9 FI4D012P9 FI4D012P9EBK FI4D012R9 FI4D024A9 FI4D024AJ FI4D024F9 FI4D024P9 FI4D024PJ FI4D024R9 FI4D024RJ FI4D036PK FI4D048AK FI4D048PK FI4D072AK FI4D072PK FI4D096AK FI4D096PK FI4D144AK FI4D144PK FI4I001PCEBK FI4I001RB FI4I001RC Page 45 45 44 45 44 33 33 43 33 33 43 33 33 33 33 35 43 35 43 39 39 35 43 35 39 39 35 43 35 39 39 39 35 35 35 35 35 39 35 39 35 39 35 39 35 43 32 32 Part No. Page FI4I002P0 FI4I002PCEBK FI4I002RB FI4I002RC FI4I008P0 FI4I012P0 FI4M008P2 FI4M008P8 FI4M012P0 FI4M012P2 FI4M012P2EBK FI4M024P1 FI4M024P8 FI4M032P8 FI4M036P1 FI4M048P1 FI4M048P8 FI4M064P8 FI4M072P1 FI4M096P8 FI4M144P1 FISB002LB FISB002PB FISB002PBYBK FISB004LB FISB004PB FISB004PBYBK FISB006LB FISB006PB FISB012LB FISB012PB FISD002P9 FISD002P9YBK FISD002R9 FISD004P9YBK FISD006A9 FISD006F9 FISD006P9 FISD006P9YBK FISD006R9 FISD012A9 FISD012F9 FISD012P9 FISD012P9YBK FISD012R9 FISD024A9 FISD024AJ FISD024F9 32 43 32 32 32 32 45 45 44 44 43 44 45 45 44 44 45 45 44 45 44 33 33 43 33 33 43 33 33 33 33 35 43 35 43 39 39 35 43 35 39 39 35 43 35 39 39 39 www.belden.com Faster. Easier. Better. Part No. FISD024P9 FISD024PJ FISD024R9 FISD024RJ FISD036PK FISD048AK FISD048PK FISD072AK FISD072PK FISD096AK FISD096PK FISD144AK FISD144PK FISI001PCYBK FISI001RB FISI001RC FISI002P0 FISI002PCYBK FISI002RB FISI002RC FISI008P0 FISI012P0 FISM008P2 FISM008P8 FISM012P0 FISM012P2 FISM012P2YBK FISM024P1 FISM024P8 FISM032P8 FISM036P1 FISM048P1 FISM048P8 FISM064P8 FISM072P1 FISM096P8 FISM144P1 FP1LDLD002M FP1LDLD003M FP1LDLD005M FP1LDSD002M FP1LDSD003M FP1LDSD005M FP1LDST002M FP1LDST003M FP1LDST005M FP1SDSD002M FP1SDSD003M www.belden.com Page 35 35 35 35 35 39 35 39 35 39 35 39 35 43 32 32 32 43 32 32 32 32 45 45 44 44 43 44 45 45 44 44 45 45 44 45 44 19 19 19 19 19 19 19 19 19 19 19 Part No. FP1SDSD005M FP1STST002M FP1STST003M FP1STST005M FP3LDLD002M FP3LDLD003M FP3LDLD005M FP3LDSD002M FP3LDSD003M FP3LDSD005M FP3LDST002M FP3LDST003M FP3LDST005M FP3LU4F002M FP3LU4F003M FP3LU4F005M FP3LULU002M FP3LULU003M FP3LULU005M FP3LUMF002M FP3LUMF003M FP3LUMF005M FP3MFMF002M FP3MFMF003M FP3MFMF005M FP3NFNF002M FP3NFNF003M FP3NFNF005M FP3SDSD002M FP3SDSD003M FP3SDSD005M FP3STST002M FP3STST003M FP3STST005M FP4LDLD002M FP4LDLD003M FP4LDLD005M FP4LDSD002M FP4LDSD003M FP4LDSD005M FP4LU4F002M FP4LU4F003M FP4LU4F005M FP4LULU002M FP4LULU003M FP4LULU005M FP4LUMF002M FP4LUMF003M Page 19 19 19 19 19 19 19 19 19 19 19 19 19 21 21 21 19 19 19 21 21 21 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 21 21 21 19 19 19 21 21 Part No. FP4LUMF005M FP4MFMF002M FP4MFMF003M FP4MFMF005M FP4NFNF002M FP4NFNF003M FP4NFNF005M FP4SDSD002M FP4SDSD003M FP4SDSD005M FP4STST002M FP4STST003M FP4STST005M FP34F4F002M FP34F4F003M FP34F4F005M FP44F4F002M FP44F4F003M FP44F4F005M FPS4F4F002M FPS4F4F003M FPS4F4F005M FPSLALA002M FPSLALA003M FPSLALA005M FPSLASA002M FPSLASA003M FPSLASA005M FPSLDLD002M FPSLDLD003M FPSLDLD005M FPSLDSD002M FPSLDSD003M FPSLDSD005M FPSLDST002M FPSLDST003M FPSLDST005M FPSLFLF002M FPSLFLF003M FPSLFLF005M FPSLILI002M FPSLILI003M FPSLILI005M FPSLU4F002M FPSLU4F003M FPSLU4F005M FPSLULU002M FPSLULU003M Page 21 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 21 21 21 19 19 Part No. FPSLULU005M FPSLUMF002M FPSLUMF003M FPSLUMF005M FPSMFMF002M FPSMFMF003M FPSMFMF005M FPSNFNF002M FPSNFNF003M FPSNFNF005M FPSSASA002M FPSSASA003M FPSSASA005M FPSSDSD002M FPSSDSD003M FPSSDSD005M FPSSTST002M FPSSTST003M FPSSTST005M FS1C002N0 FS1C004N0 FS1C006N0 FS1C008N0 FS1C010N0 FS1C012N0 FS1C00260 FS1C00460 FS1C00660 FS1C00860 FS1C01060 FS1C01260 FS1H002NF FS1H004NF FS1H006NF FS1H008NG FS1H012NG FS1H018NG FS1H024NG FS1H036NG FS1H048NG FS1H072NG FS1H096NG FS1H144NG FS1H216NG FS1L006NC FS1L006NF FS1L012ND FS1L012NG 1.800.BELDEN.1 (800.235.3361) Page 19 21 21 21 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 52 52 52 52 52 52 52 52 52 52 52 52 51 51 51 51 51 51 51 51 51 51 51 51 51 46 46 46 46 Part No. FS1L024ND FS1L024NG FS1L036ND FS1L036NG FS1L048ND FS1L048NG FS1L072ND FS1L072NG FS1L096ND FS1L096NG FS1L144ND FS1L144NG FS2C002N0 FS2C004N0 FS2C006N0 FS2C008N0 FS2C010N0 FS2C012N0 FS2C00260 FS2C00460 FS2C00660 FS2C00860 FS2C01060 FS2C01260 FS2H002NF FS2H004NF FS2H006NF FS2H008NG FS2H012NG FS2H018NG FS2H024NG FS2H036NG FS2H048NG FS2H072NG FS2H096NG FS2H144NG FS2H216NG FS2L006NC FS2L006NF FS2L012ND FS2L012NG FS2L024ND FS2L024NG FS2L036ND FS2L036NG FS2L048ND FS2L048NG FS2L072ND Page 46 46 46 46 46 46 46 46 46 46 46 46 52 52 52 52 52 52 52 52 52 52 52 52 51 51 51 51 51 51 51 51 51 51 51 51 51 46 46 46 46 46 46 46 46 46 46 46 57 Part No. FS2L072NG FS2L096ND FS2L096NG FS2L144ND FS2L144NG FS3C002N0 FS3C004N0 FS3C006N0 FS3C008N0 FS3C010N0 FS3C012N0 FS3C00260 FS3C00460 FS3C00660 FS3C00860 FS3C01060 FS3C01260 FS3H002NF FS3H004NF FS3H006NF FS3H008NG FS3H012NG FS3H018NG FS3H024NG FS3H036NG FS3H048NG FS3H072NG FS3H096NG FS3H144NG FS3H216NG FS3L006NC FS3L006NF FS3L012ND FS3L012NG FS3L024ND FS3L024NG FS3L036ND FS3L036NG FS3L048ND FS3L048NG FS3L072NG FS3L096ND FS3L096NG FS3L144ND FS3L144NG FS4C002N0 FS4C004N0 FS4C006N0 FS4C008N0 58 Page 46 46 46 46 46 52 52 52 52 52 52 52 52 52 52 52 52 51 51 51 51 51 51 51 51 51 51 51 51 51 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 52 52 52 52 Part No. FS4C010N0 FS4C012N0 FS4C00260 FS4C00460 FS4C00660 FS4C00860 FS4C01060 FS4C01260 FS4H002NF FS4H004NF FS4H006NF FS4H008NG FS4H012NG FS4H018NG FS4H024NG FS4H036NG FS4H048NG FS4H072NG FS4H096NG FS4H144NG FS4H216NG FS4L006NC FS4L006NF FS4L012ND FS4L012NG FS4L024ND FS4L024NG FS4L036ND FS4L036NG FS4L048ND FS4L048NG FS4L072ND FS4L072NG FS4L096ND FS4L096NG FS4L144ND FS4L144NG FSSC002N0 FSSC004N0 FSSC006N0 FSSC008N0 FSSC010N0 FSSC012N0 FSSC00260 FSSC00460 FSSC00660 FSSC00860 FSSC01060 FSSC01260 Page 52 52 52 52 52 52 52 52 51 51 51 51 51 51 51 51 51 51 51 51 51 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 52 52 52 52 52 52 52 52 52 52 52 52 Part No. FSSH002NF FSSH004NF FSSH006NF FSSH008NG FSSH012NG FSSH018NG FSSH024NG FSSH036NG FSSH048NG FSSH072NG FSSH096NG FSSH144NG FSSH216NG FSSL006NC FSSL006NF FSSL012ND FSSL012NG FSSL024ND FSSL024NG FSSL036ND FSSL036NG FSSL048ND FSSL048NG FSSL072ND FSSL072NG FSSL096ND FSSL096NG FSSL144ND FSSL144NG FT1SC3MMPS01 FT1SC250PR12 FT1SC900PR12 FT1SC900PS01 FT1SD3MMPS01 FT1ST3MMPS01 FT1ST900PR12 FT1ST900PS01 FT3LC2MMPS01 FT3LC250PR12 FT3LC900PR12 FT3LC900PS01 FT3LD2MMPS01 FT3MM3MMPS01 FT3MM250PS01 FT3SC3MMPS01 FT3SC250PR12 FT3SC900PR12 FT3SC900PS01 FT3SD3MMPS01 1.800.BELDEN.1 (800.235.3361) Page 51 51 51 51 51 51 51 51 51 51 51 51 51 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 Part No. FT3ST3MMPS01 FT3ST900PR12 FT3ST900PS01 FT4LC2MMPS01 FT4LC250PR12 FT4LC900PR12 FT4LC900PS01 FT4LD2MMPS01 FT4MM3MMPS01 FT4MM250PS01 FT4SC3MMPS01 FT4SC900PR12 FT4SC900PS01 FT4SD3MMPS01 FTSLA2MMPS01 FTSLB2MMPS01 FTSLB250PR12 FTSLB900PR12 FTSLB900PS01 FTSLC2MMPS01 FTSLC250PR12 FTSLC900PR12 FTSLC900PS01 FTSLD2MMPS01 FTSMM3MMPS01 FTSMM250PS01 FTSSA3MMPS01 FTSSB3MMPS01 FTSSB250PR12 FTSSB900PR12 FTSSB900PS01 FTSSC3MMPS01 FTSSC250PR12 FTSSC900PR12 FTSSC900PS01 FTSSD3MMPS01 FTSST3MMPS01 FTSST900PR12 FTSST900PS01 FW3MBF06LD FW3MBP06LD FW3MBS06LD FW4MBF06LD FW4MBP06LD FW4MBS06LD FWSMBF06LA FWSMBF06LD FWSMBP06LA FWSMBP06LD Page 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 28 28 28 28 28 28 28 28 28 28 Part No. Page FWSMBS06LA FWSMBS06LD FWSWBF01SB FWSWBF01SC FWSWBF02SB FWSWBF02SC FWSWBF04SB FWSWBF04SC FXBUBO250B25N FXBUCLLDB25N FXBUCLSDB25N FXFACLLDB25A FXFACLLDB25B FXFACLLDB25E FXFACLLDB25G FXFACLLDB25T FXFACLLMB25N FXFUBRDHM FXFUBRDHS FXFUBRSHM FXFUHS9T2CB25 FXFUHS250DB25 FXFUHS900AB25 FXFUHSRIBEB12 SCSH1232SLF SCSH2116SLF SCSH2216LLF SCSH4108LLF SCSH4208MLF SCSU1208SLF SCSU1216SLF SCSU2208SLF TC3H02LDLDLD TC3H06LDMFLD TC3H06LDMFMM TC3H044F4F4M TC4H02LDLDLD TC4H02LDLDLD7A TC4H06LDMFLD TC4H06LDMFLD7A TC4H06LDMFMM TC4H06LDMFMM7A TC4H044F4F4M TC4H044F4F4M7A XPE-S0003 9810-0100 9811-0200 9813-0400 28 28 28 28 28 28 28 28 4 4 4 18 18 18 18 18 18 9 9 9 7 7 7, 16 7 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 15 15 15 15 www.belden.com Faster. Easier. Better. SmartPart Number Configurator Fiber Optic Cable To use the configuration matrices, make a selection from each category (some selections will require measurements) and combine to form a custom part number. Part number example from configuration shown below: FI3B004PB FI 3 B 004 P B FX Fiber Cable Fiber Type Family Fiber Count Fire Rating & Protection Subunit Type / Configuration Breakout Cable FI Indoor Cable 1 OM1 FD Indoor/Outdoor Cable 3 OM3 B Breakout 002 2 Fibers Plenum Group 004 4 Fibers P Plenum (OFNP) 4 OM4 006 6 Fibers A Plenum Interlocked Aluminum Armor (OFCP) S OS2 (G.657.A1) 008 8 Fibers B 2.0 mm, 1 x 900 μm Fiber Riser Group 010 10 Fibers R Riser (OFNR) 012 12 Fibers F Riser Interlocked Aluminum Armor (OFCR) Non-Unitized Distribuion Cable FI Indoor Cable 1 OM1 FD Indoor/Outdoor Cable 3 OM3 D Distribution 002 2 Fibers Plenum Group 004 4 Fibers P Plenum (OFNP) 4 OM4 006 6 Fibers A Plenum Interlocked Aluminum Armor (OFCP) S OS2 (G.657.A1) 012 12 Fibers 024 24 Fibers 9 900 μm Fiber Riser Group R Riser (OFNR) F Riser Interlocked Aluminum Armor (OFCR) Unitized Distribuion Cable FI Indoor Cable 1 OM1 FD Indoor/Outdoor Cable 3 OM3 D Distribution 024 24 Fibers Plenum Group 036 36 Fibers P Plenum (OFNP) 4 OM4 048 48 Fibers A Plenum Interlocked Aluminum Armor (OFCP) S OS2 (G.657.A1) Hybrid Assignments 072 72 Fibers (Primary/Secondary) E OS2/OM4 F OS2/OM1 J 4.5 mm, 6 x 900 μm Fiber K 5.5 mm, 12 x 900 μm Fiber Riser Group 096 96 Fibers R Riser (OFNR) 144 144 Fibers F Riser Interlocked Aluminum Armor (OFCR) Hybrid Configurations H OS2/OM3 H31 4 Subunits K OM4/OM1 H22 4 Subunits M OM3/OM1 H13 4 Subunits Mini-Distribution Cable (Non-Unitized) FI Indoor Cable 3 OM3 M Mini-Distribution Plenum Group 012 12 Fibers 4 OM4 P Plenum (OFNP) S OS2 (G.657.A1) 0 250 μm Fiber 2 3.0 mm, 12 x 250 μm Fiber A Plenum Interlocked Aluminum Armor (OFCP) Mini-Distribution Cable (Unitized) FI Indoor Cable 3 OM3 M Mini-Distribution Plenum Group 024 24 Fibers 4 OM4 036 36 Fibers P Plenum (OFNP) S OS2 (G.657.A1) 048 48 Fibers A Plenum Interlocked Aluminum Armor (OFCP) 1 2.0 mm, 12 x 250 μm Fiber 072 72 Fibers 096 96 Fibers 144 144 Fibers Loose-Tube FI Indoor Cable 1 OM1 012 12 Fibers FS Outdoor Cable 3 OM3 024 24 Fibers N CM (OFN) 4 OM4 036 36 Fibers 6 CM Corrugated Steel Tape Armor S OS2 (G.657.A1) 048 48 Fibers L CM D 12 Fibers per Tube Dry Loose-Tube (Single-Jacket) G 12 Fibers per Tube Gel Riser Group 072 72 Fibers R Riser (OFNR) 096 96 Fibers 5 Riser Corrugated Steel Tape Armor (OFCR) 144 144 Fibers www.belden.com 1.800.BELDEN.1 (800.235.3361) 59 GLOBAL LOCATIONS For worldwide Sales and Technical Support, visit: www.belden.com UNITED STATES CANADA MEXICO Division Headquarters National Business Center Regional Office 401 Pennsylvania Parkway, #200 Indianapolis, IN USA Phone: (1)-317-818-6300 Inside Sales: 800-235-3361 Fax: (1)-317-818-6382 info@belden.com Belden Canada Inc. 2310 Alfred-Nobel St-Laurent Quebec H4S 2B4 Canada Phone: 514-822-2345 Fax: 514-822-7979 info@belden.com Insurgentes Sur #1602 Piso 1 Oficina 102 Código Constructor Del. Benito Juárez , C.P. 03940 Mexico Phone: +52 55-5523-7733 Fax: +52 55-5528-8077 ventas.mexico@belden.com ©Copyright 2017, Belden Inc. Printed in U. S. A. Fiber Catalog | V7_CA_ECOS_BDC_0117_A_AG
FPSLDST002M 价格&库存
很抱歉,暂时无法提供与“FPSLDST002M”相匹配的价格&库存,您可以联系我们找货
