129463 J221000
129463 J221000
    BELDEN
    ALUM ARMOR 1PR 20AWG BLUE HOSE
129463 J221000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 129463 Twinax - Blue Hose® Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (7x28) tinned copper conductors, polyethylene insulation, overall Beldfoil® (100% coverage) plus a 55% tinned copper braid shield (55% coverage), PVC inner jacket, aluminum interlocked armor, sunlight-resistant PVC outer jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 20 7x28 TC - Tinned Copper .038 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene 0.076 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 55 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 7x28H TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.238 Outer Jacket over Armor (y/n): Y Armor Armor Type: Interlocked Armor Material: Aluminum Diameter over Armor: .441 Overall Cable Overall Nominal Diameter: 0.541 in. Pair Pair Color Code Chart: Number Color 1 Clear & Blue Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +60°C Bulk Cable Weight: 133 lbs/1000 ft. Max. Recommended Pulling Tension: 200 lbs. Min. Bend Radius/Minor Axis: 6.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 129463 Twinax - Blue Hose® Cable NEC/(UL) Specification: CL2, CM CEC/C(UL) Specification: CM EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: Allen Bradley P/N 1770-CD Flame Test UL Flame Test: UL1685 UL Loading Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 78 Nom. Inductance: Inductance (µH/ft) 0.12 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 19.7 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 36 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.6 10 2.1 50 5.0 100 7.5 200 11.0 400 16.0 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: DC Resistance Unbalance: .77 Ohms/1000 ft Max Put Ups and Colors: Item # Putup Ship Weight Color Notes Page 2 of 3 Item Desc 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 129463 Twinax - Blue Hose® Cable 129463 J221000 1,000 FT 145.000 LB BLUE, STRONG 9463 ALUM ARMORED PVC 129463 J226000 6,000 FT 894.000 LB BLUE, STRONG 9463 ALUM ARMORED PVC Revision Number: 2 Revision Date: 11-12-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
129463 J221000 价格&库存
很抱歉,暂时无法提供与“129463 J221000”相匹配的价格&库存,您可以联系我们找货
