1502R 009500
1502R 009500
    BELDEN
    2 #18 PVC +2 FS #22 FHDPEFRPVC
1502R 009500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1502R Multi-Conductor - Multimedia Control Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, FPE insulation (data), STP (Data) w/Beldfoil®, TC drain wire, 18 AWG (16x30) TC conductors, unshielded (power) pair, F-R PVC insulation (power), F-R PVC Jacket (Available in Black, White, or Aqua) Physical Characteristics (Overall) Conductor AWG: # Conductors # Pairs AWG Stranding Conductor Material 2 1 22 7x30 TC - Tinned Copper 1 18 16x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Trade Name Insulation Material Wall Thickness (in.) AWG Datalene® .025 22 F-R PVC - Flame Retardant Polyvinyl Chloride .013 18 HDFPE - High Density Foam Polyethylene Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material 22 AWG Pair Beldfoil® Coverage (%) Stranding Dia. (in.) Conductor Material Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG Stranding Conductor Material 24 AWG 7x32 TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material F-R PVC - Flame Retardant Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.250 in. Pair Pair Color Code Chart: Number Color 1 Blue & White 2 Red & Black Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 40 lbs/1000 ft. Max. Recommended Pulling Tension: 59.800 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1502R Multi-Conductor - Multimedia Control Cable CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1502P Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) 22 AWG Pair 100 Nom. Inductance: Description Inductance (µH/ft) 22 AWG .232 18 AWG .168 Nom. Capacitance Conductor to Conductor: Description Capacitance (pF/ft) 22 AWG Pair 14 18 AWG Pair 29 Nom. Capacitance Cond. to Other Conductor & Shield: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Capacitance (pF/ft) 22 AWG Pair 38 Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) 22 AWG 16.3 18 AWG 6.9 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 3.8 Amps per conductor @ 25°C (22 AWG); 7.2 Amps per conductor @ 25°C (18 AWG) Notes (Overall) Notes: Sequential footage marking every two feet. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1502R G751000 1,000 FT 44.000 LB AQUA C 2 #18 PVC +2 FS #22 FHDPEFRPVC 1502R G75500 500 FT 22.000 LB AQUA C 2 #18 PVC +2 FS #22 FHDPEFRPVC 1502R 0091000 1,000 FT 44.000 LB WHITE C 2 #18 PVC +2 FS #22 FHDPEFRPVC 1502R 009500 500 FT 22.000 LB WHITE C 2 #18 PVC +2 FS #22 FHDPEFRPVC 1502R 0101000 1,000 FT 44.000 LB BLACK C 2 #18 PVC +2 FS #22 FHDPEFRPVC 1502R 01010000 10,000 FT 470.000 LB BLACK 1502R 010500 500 FT 22.000 LB BLACK 1502R 0105000 5,000 FT 215.000 LB BLACK 2 #18 PVC +2 FS #22 FHDPEFRPVC C 2 #18 PVC +2 FS #22 FHDPEFRPVC 2 #18 PVC +2 FS #22 FHDPEFRPVC Notes: C = CRATE REEL PUT-UP. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1502R Multi-Conductor - Multimedia Control Cable Revision Number: 1 Revision Date: 07-30-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1502R 009500 价格&库存
很抱歉,暂时无法提供与“1502R 009500”相匹配的价格&库存,您可以联系我们找货
