1583ENH 304M
1583ENH 304M
    BELDEN
    BELDEN - 1583ENH 304M - Networking Cable, Unscreened, Cat5e, 24 AWG, 0.2 mm², 1000 ft, 305 m
1583ENH 304M 数据手册
Product Datasheet P/N 46376 - Rev. 3A Page 1 of 2 Date 01-04-2000 Belden 1583ENH Cat 5 enhanced UTP FRNC Application • • Horizontal and building backbone cable. Support current and future Category 5 enhanced applications, such as: 10 Base-T, 100 Base-T, 1000 Base-T (Gibabit Ethernet), FDDI, ATM Standards General standards: ISO/IEC 11801, EN 50173, TSB 36, TIA/EIA 568-A-5 (enhanced) Future standards like: JTC1 SC25 WG3 N568 and prEN 50288-3-1 Construction & Dimensions • • • • • • • Construction: Conductor: Conductor diameter: Conductor insulation material: Diameter over insulation: Jacket material: Outer diameter: Unshielded 4 twisted pairs solid bare copper AWG 24 (0,51 mm) Polyethylene (PE) 0,90 mm ± 0.05 mm FRNC (Flame retardant) 4,70 mm ± 0.30 mm Colour code Pair 1 Pair 2 Pair 3 Pair 4 White-Blue/Blue White-Orange/Orange White-Green/Green White-Brown/Brown Electrical characteristics (at 20 ºC) Attenuation Frequency Spec. (Max.)1) Typical 1 2.1 2.0 4 4.3 4.0 10 6.6 6.3 16 8.2 8.0 20 9.2 9.0 31.25 11.8 11.3 62.5 17.1 16.2 100 22.0 20.7 MHz dB/100m dB/100m 4 56.3 64 10 50.3 58 16 47.3 55 20 45.8 54 31.25 42.9 51 62.5 38.4 47 100 35.3 44 MHz dB dB 4 53.3 62 10 47.3 56 16 44.3 53 20 42.8 52 31.25 39.9 49 62.5 35.4 45 100 32.3 42 MHz dB/100m dB/100m 1 60.8 71 4 48.7 59 10 40.8 51 16 36.7 46 20 34.7 43 31.25 30.9 39 62.5 24.8 33 100 20.8 28 MHz dB/100m dB/100m 1 63 71 4 52 61 10 44 52 16 39 48 20 37 45 31.25 31 40 62.5 22 31 100 14 24 MHz dB/100m dB/100m 4 49 59 10 41 50 16 36 46 20 34 43 31.25 28 38 62.5 19 29 100 11 22 MHz dB/100m dB/100m NEXT (Near end crosstalk) Frequency Spec. (Min.)1) Typical 1 65.3 73 Power sum NEXT Frequency Spec. (Min.)1) Typical 1 62.3 71 Power sum ELFEXT Frequency Spec. (Min.)2) Typical ACR Frequency Spec. (Min.)1) Typical Power sum ACR Frequency Spec. (Min.)1) Typical 1) 2) 1 60 69 : Specification values according to cable requirements of ISO/IEC 11801 category 5 enhanced : Specification values according to cable requirements of ANSI/TIA/EIA-568-A-5 (enhanced) Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner Product Datasheet P/N 46376 - Rev. 3A Page 2 of 2 Date 01-04-2000 Belden 1583ENH Cat 5 enhanced UTP FRNC Electrical characteristics (at 20 ºC) Nominal mutual capacitance at 1 kHz Maximum conductor DCR NVP - Nominal Velocity of Propagation SKEW – Propagation delay difference (100 MHz) Impedance 1-100 MHz 50 nF/km 93.5 Ohm/km 0.68 c Typical ≤ 10 ns/100m 100 ± 15 Ohm General and environmental characteristics Temperature range - operation Temperature range - installation Minimum bending radius - operation Minimum bending radius - installation Maximum pulling tension Flame retardancy Energy of flame Weight (approx.) Maximum operating voltage Maximum continuous current per conductor (25°C) -20°C - +60°C +0°C - +50°C 19 mm 38 mm 80 N IEC 332-1 250 kJ/m 28 kg/km 48 V rms 1.4 A Ordering information MARKING Text on the cable jacket Inkjet printing BELDEN 1583ENH UTP CAT5E 4PR AWG24 LSNH ISO/IEC 11801 EN50173 VERIFIED 100 OHM Meter marking: Production date marking: JACKET COLOUR Colour Grey Blue Yes Yes RAL code RAL 7032 RAL 5015 PACKAGING (PUT UP) Belden code Delivery length 46376 xxxx 178 305 m 46376 xxxx 028 305 m 46376 xxxx 011 500 m 46376 xxxx 240 1000 m xxxx: Belden colour code Belden colour code 2807 3072 Weight 8,5 kg 8,5 kg 14,0 kg 28,0 kg Remark Unreel box Non returnable reel Non returnable reel Non returnable reel Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
1583ENH 304M 价格&库存
很抱歉,暂时无法提供与“1583ENH 304M”相匹配的价格&库存,您可以联系我们找货
