1694A.00153
1694A.00153
    BELDEN
    BELDEN - 1694A.00153 - Coaxial Cable, Precision Video Analog/Digital, RG6, 18 AWG, 75 ohm, 498.69 ft...
1694A.00153 数据手册
1694A Coax - Precision Video Cable for Analog and Digital For more information please call 1-800-Belden1 See Put-ups and Colors Description: 18 AWG .040" solid bare copper conductor, gas-injected foam HDPE insulation, Duofoil® and a 95% tinned copper braid shield, PVC jacket. PHYSICAL CHARACTERISTICS: CONDUCTOR: Number of Coax 1 Total Number of Conductors 1 RG Type 6/U AWG 18 Stranding Solid Conductor Diameter .040 in. Conductor Material BC - Bare Copper INSULATION: Insulation Material Gas-injected FHDPE - Foam High Density Polyethylene Insulation Diameter .180 in. OUTER SHIELD: Outer Shield Material Trade Name Duofoil® Outer Shield Type Tape/Braid Outer Shield Material : Layer Number 1 Trade Name Duofoil® Type Tape 2 Braid Outer Shield %Coverage 100 % Material Aluminum Foil-Polyester Tape-Aluminum Foil TC-Tinned Copper OUTER JACKET: Outer Jacket Material PVC - Polyvinyl Chloride OVERALL NOMINAL DIAMETER: Overall Nominal Diameter .275 in. MECHANICAL CHARACTERISTICS: Operating Temperature Range -30°C To +75°C UL Temperature Rating 75°C Page 1 of 4 % Coverage (%) 100 95 1694A Coax - Precision Video Cable for Analog and Digital Bulk Cable Weight 40 lbs/1000 ft. Max. Recommended Pulling Tension 69 lbs. Min. Bend Radius (Install) 2.75 in. APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE: APPLICABLE STANDARDS: NEC/(UL) Specification CMR CEC/C(UL) Specification CMG FLAME TEST: UL Flame Test UL1666 Vertical Shaft CSA Flame Test FT4 SUITABILITY: Suitability - Indoor All colors Suitability - Outdoor Black only Suitability - Aerial Black only, when supported by a messenger wire Suggested Connectors AMP 221185-1 Dual Crimp Gold Pin BNC (75 Ohms); Amphenol 31-70000 Dual Crimp Gold Pin BNC (75 Ohms); Kings 2065-10-9 Dual Crimp Gold Pin (75 Ohms); Trompeter UPL220-20 Dual Crimp Gold Pin BNC (75 Ohm); ADC BNC1694D Dual Crimp Gold Pin BNC (75 Ohm) PLENUM/NON-PLENUM: Plenum (Y/N) N Non-Plenum Number 1695A ELECTRICAL CHARACTERISTICS: Nom. Characteristic Impedance 75 +/- 1.5 Ohms Nom. Inductance 0.106 µH/ft Nom. Capacitance Conductor to Shield 16.2 pF/ft Nominal Velocity of Propagation 82 % Nominal Delay 1.24 ns/ft Nom. Conductor DC Resistance @ 20 Deg. C 6.4 Ohms/1000 ft Nominal Outer Shield DC Resistance 2.8 Ohms/1000 ft Minimum Structural Return Loss : Description Frequency (MHz) Start Frequency (MHz) Stop Frequency (MHz) 5 851 850 3000 Nom. Attenuation : Page 2 of 4 Minimum Structural Return Loss (dB) 23 21 1694A Coax - Precision Video Cable for Analog and Digital Description Frequency (MHz) Start Frequency (MHz) Stop Frequency (MHz) 1 3.58 5 7 10 67.5 71.5 88.5 100 135 143 180 270 360 540 720 750 1000 1500 2000 2250 3000 Max. Operating Voltage - UL Nom. Attenuation (dB/100 ft.) 0.24 0.45 0.54 0.63 0.72 1.57 1.60 1.75 1.84 2.10 2.16 2.42 2.97 3.43 4.25 4.95 5.00 5.89 7.33 8.57 9.14 10.67 300 V RMS NOTES: Notes PUT-UPS AND COLORS: Item Description 1694A 0011000 #18 PE/GIFHDPE SH FR PVC 1694A 0014500 #18 PE/GIFHDPE SH FR PVC 1694A 0021000 #18 PE/GIFHDPE SH FR PVC 1694A 0024500 #18 PE/GIFHDPE SH FR PVC 1694A 0031000 #18 PE/GIFHDPE SH FR PVC 1694A 0034500 #18 PE/GIFHDPE SH FR PVC 1694A 0041000 #18 PE/GIFHDPE SH FR PVC Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and termination. 100% Sweep tested 5 MHz to 3 GHz. Also available in bundled versions. See 7710A through 7713A. Put-Up (ft.) 1000 Ship Weight (lbs.) 45 Jacket Color BROWN Notes C 4500 202.5 BROWN C 1000 45 RED C 4500 202.5 RED C 1000 45 ORANGE C 4500 202.5 ORANGE C 1000 45 YELLOW C Page 3 of 4 1694A Coax - Precision Video Cable for Analog and Digital 1694A 0044500 1694A 0061000 1694A 0064500 1694A 0071000 1694A 0074500 1694A 0081000 1694A 0084500 1694A 0091000 1694A 0094500 1694A 0101000 1694A 0104500 1694A 010500 1694A N3U1000 1694A N3U4500 #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC 4500 202.5 YELLOW C 1000 45 BLUE, LIGHT C 4500 202.5 BLUE, LIGHT C 1000 45 VIOLET C 4500 202.5 VIOLET C 1000 45 GRAY C 4500 202.5 GRAY C 1000 45 WHITE C 4500 202.5 WHITE C 1000 45 BLACK C 4500 202.5 BLACK C 500 22.5 BLACK C 1000 45 GREEN, MIL C 4500 202.5 GREEN, MIL C C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 12-04-2003 © 2003 Belden Wire & Cable Company All Rights Reserved. Although Belden Electronics Division ("Belden") makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 4 of 4
1694A.00153 价格&库存
很抱歉,暂时无法提供与“1694A.00153”相匹配的价格&库存,您可以联系我们找货
