2203ELV.00500
2203ELV.00500
    BELDEN
    BELDEN - 2203ELV.00500 - Networking Cable, Euroclass, Premise Horizontal, 4 Pair, Screened, Cat6a, 2...
2203ELV.00500 数据手册
Part Number: 2203ELV Enhanced Category 6A Nonbonded-Pair U/FTP LSZH Cable, CPR Euroclass B2ca Product Description Category 6A (500MHz), 4-Pair, U/FTP shielded, Premise Horizontal Cable, 23 AWG Solid Bare Copper conductors, Foam Polyolefin insulation, each pair with Beldfoil® shield, AWG 26 solid tinned copper drainwire, LSZH jacket, CPR Euroclass B2ca Technical Specifications Product Overview Environmental Space: Indoor - Euroclass B2ca Suitable Applications: Horizontal and building backbone cable; Support current and future Cat. 6a and 6 applications such as; 10GBase-T (10 Gigabit Ethernet), 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI and ATM Physical Characteristics (Overall) Conductor Element AWG Stranding No. of Pairs Individual shielded pair 23 Solid 4 Conductor Count: 8 Total Number of Pairs: 4 Conductor Size: 23 AWG Insulation Element Type Material Nominal Diameter Individual shielded pair Dielectric FPE - Foamed Polyethylene 1.32 mm Color Chart Number Color Pair 1 White / Blue Pair 2 White / Orange Pair 3 White / Green Pair 4 White / Brown Inner Shield Material Element Type Material Coverage [%] Individual shielded pair Tape Aluminum / Polyester 100 % InnerShield, Table Note: Aluminum facing outside Outer Shield Material Material Drainwire Material Drainwire AWG Aluminum/Polyester TC - Tinned Copper 26 Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance LSZH / FRNC 7.9 mm 0.3 mm Construction and Dimensions Min Elongation at Breakof Conductors: 10 % Min Elongation at Breakof Insulation: 100 % Cabling Ripcord Yes, Nylon Description 2 twisted insulated conductors with overall foil, 4 pairs all twisted together with AWG 26 tinned copper drain wire Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max DCR Unbalanced Between Pairs [%] Max. DCR Unbalanced Within Pair [%] 95 Ohm/km 4% 2% Capacitance Max. Capacitance Unbalance Max. Mutual Capacitance 1,600 pF/m 56 pF/m Shielding: U/FTP - Individual Foil Impedance Nominal Characteristic Impedance 100 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss Nom. ACR [dB] Nom. ACRF (ELFEXT) [dB] Nom. Return Loss (RL) Nom. PSANEXT Nom. PSAACRF Nom. TCL Nom. ELTCTL 1 MHz 2.1 dB/100m 73.2 dB 68 dB 67 dB 67 dB 40 dB 35 dB 4 MHz 3.8 dB/100m 62.5 dB 56 dB 23 dB 67 dB 66.2 dB 34 dB 23 dB 10 MHz 5.9 dB/100m 54.4 dB 48 dB 25 dB 67 dB 58.2 dB 30 dB 15 dB 16 MHz 7.5 dB/100m 49.8 dB 43.9 dB 25 dB 67 dB 54.1 dB 28 dB 10.9 dB 31.2 MHz 10.5 dB/100m 42.4 dB 38.1 dB 23.6 dB 67 dB 48.3 dB 25.1 dB 5.1 dB 62.5 MHz 15 dB/100m 33.4 dB 32.1 dB 21.5 dB 65.6 dB 42.3 dB 22 dB 100 MHz 19.1 dB/100m 26.2 dB 28 dB 20.1 dB 62.5 dB 38.2 dB 20 dB 125 MHz 21.5 dB/100m 22.3 dB 26.1 dB 19.4 dB 61 dB 36.3 dB 19 dB 200 MHz 27.6 dB/100m 13.2 dB 22 dB 18 dB 58 dB 32.2 dB 17 dB 250 MHz 31.1 dB/100m 8.3 dB 20 dB 17.3 dB 56.5 dB 30.2 dB 16 dB 300 MHz 34.3 dB/100m 3.9 dB 18.5 dB 17.3 dB 55.3 dB 28.7 dB 500 MHz 45.3 dB/100m -10.4 dB 14 dB 17.3 dB 52 dB 24.2 dB 500 MHz Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] 45 ns/100m 77 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. PSNEXT [dB] Min. ACR [dB] Min. PSACR [dB] Min. ACRF (ELFEXT) [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Min. PSANEXT Min. PSAACRF Min. Min. TCL [dB] ELTCTL [dB] 1 MHz 2.1 dB/100m 75.3 dB 72.3 dB 73.2 dB 70.2 dB 68 dB 65 dB 20 dB 67 dB 67 dB 40 dB 35 dB 4 MHz 3.8 dB/100m 66.3 dB 63.3 dB 62.5 dB 59.5 dB 56 dB 53 dB 23 dB 67 dB 66.2 dB 34 dB 23 dB 10 MHz 5.9 dB/100m 60.3 dB 57.3 dB 54.4 dB 51.4 dB 48 dB 45 dB 25 dB 67 dB 58.2 dB 30 dB 15 dB 16 MHz 7.5 dB/100m 57.2 dB 54.2 dB 49.8 dB 46.8 dB 43.9 dB 40.9 dB 25 dB 67 dB 54.1 dB 28 dB 10.9 dB 31.2 MHz 10.5 dB/100m 52.9 dB 49.9 dB 42.4 dB 39.4 dB 38.1 dB 35.1 dB 23.6 dB 67 dB 48.3 dB 25.1 dB 5.1 dB 62.5 MHz 15 dB/100m 48.4 dB 45.4 dB 33.4 dB 30.4 dB 32.1 dB 29.1 dB 21.5 dB 65.6 dB 42.3 dB 22 dB 100 MHz 19.1 dB/100m 45.3 dB 42.3 dB 26.2 dB 23.2 dB 28 dB 25 dB 20.1 dB 62.5 dB 38.2 dB 20 dB 125 MHz 21.5 dB/100m 43.8 dB 40.8 dB 22.3 dB 19.3 dB 26.1 dB 23.1 dB 19.4 dB 61 dB 36.3 dB 19 dB 200 MHz 27.6 dB/100m 40.8 dB 37.8 dB 13.2 dB 10.2 dB 22 dB 19 dB 18 dB 58 dB 32.2 dB 17 dB 250 MHz 31.1 dB/100m 39.3 dB 36.3 dB 8.3 dB 5.3 dB 20 dB 17 dB 17.3 dB 56.5 dB 30.2 dB 16 dB 300 MHz 34.3 dB/100m 38.1 dB 35.1 dB 3.9 dB 0.9 dB 18.5 dB 15.5 dB 17.3 dB 55.3 dB 28.7 dB 500 MHz 45.3 dB/100m 34.8 dB 31.8 dB -10.4 dB -13.4 dB 14 dB 11 dB 17.3 dB 52 dB 24.2 dB High Freq Table Note: Limits below 4MHz and at 625MHz are for information only. Coupling Attenuation Class: Type II Transfer Impedance Frequency [MHz] Description Transfer Impedance 1 Mhz 10 Mhz Grade 2 Max.50 mOhm/m Max. 100 mOhm/m 30 Mhz Max. 200 mOhm/m 100 Mhz Max. 1000 mOhm/m Transfer Impedance Class: Grade 2 Current Max. Recommended Current [A] 1.5 A Voltage Voltage Rating [V] Max. 72 V DC Temperature Range Installation Temp Range: 0°C To +50°C Operating Temp Range: -30°C To +60°C Mechanical Characteristics Bulk Cable Weight: 66 kg/km Max Recommended Pulling Tension: 79 N Min Bend Radius During Installation: 66 Min Bend Radius During Operation: 33 Standards ISO/IEC Compliance: ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 CPR Euroclass: B2ca-s1a,d1,a1 CENELEC Compliance: EN 50173-1 Ed. 3:2011 Data Category: Category 6A ANSI Compliance: ANSI/TIA/EIA 568-B.2-10 (2009) Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2018-01-04 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1 Burning Load: 790 kJ/m Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Patent: https://www.belden.com/resources/patents History Revision Number: 1 © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
2203ELV.00500 价格&库存
很抱歉,暂时无法提供与“2203ELV.00500”相匹配的价格&库存,您可以联系我们找货
