Bonding &
Grounding
Hardware
Diamond Bonding and Grounding Hardware
Bonding Clamps
Bonding Connector for Meter Pan (CATV Applications)
•• Meter pan connector designed to provide a bonding connection between the
metallic frame of a meter pan and a copper ground wire.
•• Its unique design allows a fixed and positive mechanical contact without
interfering with the opening of the meter pan front cover.
•• Tighten screws to 20 in. lbs. torque.
Installation:
Part Number
Description
SC51-1
For #10/12/14 AWG Copper Ground Wire.
Made of G90 Galvanize Steel + Trivalent
Chromate
Inner
Pack
Outer
Pack
100
1. The tip of the stainless steel mounting screw
is shaped to remove the paint at the point of
contact, thus ensuring positive metal-to-metal
contact with the top of the meter panel. (Always
ensure that the bonding surface is cleaned of
excess paint or rust before mounting the SC511 connector.) For heavily corrosive or marine
environments. use of “RTV” silicone sealer is
recommended at the contact point, between the
screw tip and the top of the meter pan.
2. Back the bolt and nut from the connector enough
to allow it to mount on one of the corner folds of
the metal meter pan back corners.
3. Install the connector with the bottom edges
gripping on the bottom fold of the fixed top
cover of the metal meter pan. Under no
circumstances is the bonding connector to be
mounted on the front cover or any movable
part of the metal meter pan. Tighten the bolt
securely by applying sufficient torque (20 inch
pound) to ensure a firm and positive connection
on the metal meter pan.
4. Remove one inch of insulation from copper
ground wire, use caution to avoid scoring or
damaging ground wire. Insert grounding wire
between washer and grounding nut. Wrap ground
wire clockwise between washer and ground nut.
Insure that slot in grounding washer is aligned
with ground wire. Tighten grounding nut with
CNW6 tool to secure ground wire. Do not over
tighten. Double check that the grounding bolt is
still firmly tight on the metal meter pan enclosure.
If not, tighten it one quarter turn.
Recommended for usage when no other
approved grounding electrode is accessible.
Customer Support: 800.800.6652
www.ppc-online.com
29
A BELDEN BRAND
A BELDEN BRAND
Bonding Clamps
•• Meter pan connector designed to provide a bonding connection between the metallic
SC51-CF
SC51CFKF81
Inner
Pack
Outer
Pack
Meter Pan Connector. For #10/12/14AWG Copper Ground Wire. Made
of Stainless Steel.
100
SC51CF-81
Meter Pan Ground Block for Coaxial Cable with F81 connector. For
#10/12/14AWG Copper Ground Wire. Made of Stainless Steel
100
SC51CFKF81
100
Inner
Pack
Outer
Pack
Part Number
Description
SC51-CF
Bonding Connector for Meter Pan (Telephone Applications)
SC51-2
Part Number Description
SC51CF-85
SC51-1T
Meter Pan Corner Bonding Connector for #14 to #10 AWG Copper
Ground Wire. Connector made of G90 Galvanize Steel + Trivalent
Chromate.
100
SC51-2
Meter Pan Corner Bonding Connector for #6AWG Copper Ground Wire.
Made of G90 Galvanize Steel + Trivalent Chromate
100
SC51CF-85
Meter Pan Bonding Connector for #6AWG Copper Ground Wire. Made of
Stainless Steel
100
Meter Box Ground Clamp
•• Provides a convenient, quick installation of a reliable ground or bond for drops.
•• 2 adjustable sizes: 6-1/2” to 10-1/2”, 11-1/2” to 15-1/2”.
•• Stainless steel bolts, screw and washer.
•• Mechanically galvanized ASTM B695.
•• UL Listed.
•• Will not restrict cover operation.
* Packages of 10 pieces each package.
Part Number
40-20000
40-20001
40-20002
40-20003
40-20004
Description
Meter Box Ground Clamp (S), #12-16 AWG
Meter Box Ground Clamp (L), #12-16 AWG
Meter Box Ground Clamp (S), #14-6 AWG
Clamp
Range
6.5"-10.5"
11.5"-15.5"
6.5"-10.5"
11.5"-15.5"
15.5"-21.5"
Inner
Pack
--1*
1*
1*
Outer
Pack
50
50
5
5
5
IBT1
6.5"-10.5"
1*
5
IBT2
15.5"-21.5"
1*
5
www.ppc-online.com
30
A BELDEN BRAND
Bonding &
Grounding
Hardware
Ground Blocks
Grounding Blocks
Part Number
Description
GBS81K
SC12D2-SS
Single Ground Block - Outdoor Precision F81
#14 AWG through #6 AWG Copper Ground Wire
Single Ground Block with One Precision TBCF81 Connector - 3GHz #14
to #10 AWG Copper Grounding Wire. Made of G90 Galvanize Steel +
Trivalent Ch romate
Single Ground Block with One Precision F81 Connector - 1GHz #14
Trivalent Chromate
Single Ground Block with One Precision KF81-1 Connector - 3GHz #14
Trivalent Chromate
Single Stainless Steel Ground Block with One Precision F81 Connector
- 2GHz #14 to #10 AWG Copper Grounding Wire.
Dual Ground Block with One Precision TBCF81
Connector - 3GHz #14 to #10 AWG Copper Grounding Wire. Made of
Dual Ground Block with One Precision TBCF81 Connector - 3GHz. #14
Trivalent Chromate
Dual Ground Block with Two Precision TBCF81
Connectors - 3GHz #14 to #10 AWG Copper Grounding Wire. Made of
Dual Stainless Steel Ground Block with Two Precision
F81 Connectors - 2GHz #14 to #10 AWG Copper Grounding Wire.
SC12D-SS
Dual Stainless Steel Ground Block with One Precision F81
Connector. 2GHz. Made for #14 to #10AWG Copper Ground Wire
GBS81K
SC12N-81
SC12N81-1G
SC12KF81-1
SC12KF81-1
SC12N-81
SC12-SS
SC12DNS-81
SC12DNS81-25
SC12DN-81
SC12DNS-81
Inner
Pack
Outer
Pack
500
150
150
150
150
100
100
100
100
100
Grounding Bracket
•• Grounding bracket permits upgrading number of drops by mounting 2, 3 or 4 way
splitters simply by using the SC09 splitter ring nut for mounting.
•• Made of G90 Galvanize Steel + Trivalent Chromate..
Part Number
SC46DN
Description
Accepts connector for #14 to #10 AWG Copper Grounding
Wire
Inner
Pack
Outer
Pack
100
Splitter Ring Nut
•• Splitter ring nut especially designed for converting the SC12DN grounding blocks to
accept splitters.
Part Number
Description
Inner
Pack
Outer
Pack
SC09-1
Brass, Nickel Plated, .172" Height
250
5,000
www.ppc-online.com
31
A BELDEN BRAND
A BELDEN BRAND
Grounding Clamps
Span Clamp
•• Span clamp for steel messengered drop cable bonding applications.
•• Unique locking design prevents rotation on steel strand.
Part Number
Description
SC03E-2G
For Two Steel Messenger Wires .051"
to .072" Diameter Used on 1/4" (6.6m)
Steel Strand
Inner
Pack
Outer
Pack
75
"I" Beam Grounding Clamp
•• Grounding clamp used to bond a solid copper ground wire to steel structure.
Part Number
SC07GG
Description
I Beam Grounding Clamp for #14 to
Inner
Pack
Outer
Pack
125
Inner
Pack
Outer
Pack
500
5,000
"B" Ground Wire Clamp
•• Used to secure #6 AWG to #12 AWG ground wire runs.
•• 7/32” hole diameter.
•• 3/8” wide x 9/16” long.
Part Number
Description
23-80002
Ground Wire
Range
#12 (.081") to
#6 (.162") AWG
Ground Connector
•• Ground connector used to connect various size copper ground conductors
with a firm mechanical contact.
•• Made of pure copper with brass fastener.
Part Number
SC42-1
www.ppc-online.com
32
A BELDEN BRAND
Description
Connects #4 or #6AWG to #10, #12 or
#14AWG Copper Ground Wire
Inner
Pack
Outer
Pack
150
1,800
Bonding &
Grounding
Hardware
Grounding Straps
Copper Ground Strap
•• Ground strap used to provide a fixed and permanent connection between a copper
water pipe to a copper ground wire.
•• Made of pure copper (ASTM B152-110) and brass fasteners
(ASTM B16-360 and B134-260.
•• All longitudinal dimensions are based on disassembled pieces.
Part Number
Description
SC13B-1
6.5" Strap, Fits 1/2" to 1" Diameter Pipe to #10/12/14
9" Strap, Fits 1/2" to 2-1/4" Diameter Pipe to #10/12/14
12" Strap, Fits 1/2" to 3" Diameter Pipe to #10/12/14
SC13B-2
SC13B-3
Inner
Pack
Outer
Pack
150
200
150
Galvanized Ground Strap
•• Ground strap used to provide a fixed and permanent connection between a galvanized
steel pipe and a copper ground wire.
•• Made of G90 galvanized steel that meets Salt Test ASTM B117.
Fasteners are made of brass, nickel plated (ASTM B16-360 and
B134-260) to create a neutral for galvanized to copper connection.
Part Number
SC13BZ-1
SC13BZ-2
SC13BZ-3
SC13BZ-4
Description
23-3/4" strap. Fits 1/2" to 6" Diameter Pipe for #10/12/14
Inner
Pack
Outer
Pack
150
200
150
100
www.ppc-online.com
33
A BELDEN BRAND
A BELDEN BRAND
Mechanical - Split Bolt Connectors, Jumper Clamps
High Strength Split Bolt Connectors
•• For copper to copper connections.
•• High strength corrosion resistant copper alloy for use in bonding applications.
•• Highly resistant to corrosion and seasonal cracking.
•• Hex design nut of high strength corrosion-resistant bronze alloy.
•• Pressure bar is copper.
•• UL and CSA listed.
Dimensions (In)
Size
A
B
C
D
Inner
Pack
Outer
Pack
DG2
#2
0.309
0.615
0.875
1.240
100
400
DG4
#4
0.209
0.453
0.688
0.984
100
800
DG6
#6
0.165
0.413
0.625
0.906
100
800
DG8
#8
0.146
0.413
0.562
0.854
100
800
Part Number
Type K - Jumper Clamp
•• For all combinations of aluminum, copper and steel conductors.
•• Cast of high strength bronze alloy CDA836.
•• Furnished with silicon bronze bolt and lockwasher. Lockwasher minimizes loosening
of installed clamp.
•• Parallel groove design; no need to remove bolt for installation.
•• Only one size for all requirements from No. 8 solid copper
to 1/0 ACSR or 2/0 copper.
K1DS
KULDS
A BELDEN BRAND
Outer
Pack
K1DS
Bonds 1/4" and 5/16" Strand to #6 AWG Copper Ground Wire,
Tin Plated Clamp (except for 1 wire groove) with Galvanized
Steel Bolt
100
600
K2DS
Tin Plated Clamp with Galvanized Steel Bolt
100
600
K3DS
Non-Plated Clamp with Galvanized Steel Bolt
100
600
KULDS
Tin Plated Clamp with Bronze Bolt
100
600
www.ppc-online.com
34
Inner
Pack
Bonding &
Grounding
Hardware
Mechanical - Ground Rod Clamps
Type JAB Ground Rod Clamps
•• Cast of high strength corrosion resistant
copper alloy CDA955.
•• Hex head.
•• Long bearing surface of clamp on ground
wire secures ground connection.
•• U.L. Listed for direct burial.
JAB58HDS
JAB34HDS
JAB12HDS
Nominal Rod
Diameter
Wire Range
Dimensions (IN)
Part Number
IN
MM
Max
Min
Max
(MM2)
Min
(MM2)
JAB12H-DS
1/2
12.7
2 Str.
10 Sol.
33.6
5.2
JAB34H-DS
3/4
19.0
1/0 Str.
8 Sol.
53.4
8.3
JAB58H-DS
5/8
15.8
1/0 Str.
8 Sol.
53.4
8.3
A
(Max)
Socket
Screw
A
(Max)
Hex
Bolt
Screw
Thread
Size
7/16"1-19/32 2-3/32 14UNC
7/16"2
2-11/32 14UNC
7/16"1-27/32 2-13/64 14UNC
B
C
D
Package
Quantity
15/16"
63/64"
11/16"
100
11/16"
1"
51/64"
50
51/64"
7/8"
19/32"
50
Type G Ground Rod Clamps
•• A dependable ground connection offered at a
substantial savings.
•• Cast of high strength corrosion-resistant
•• Hex head bolts.
G5DS
G4DS
•• Simplified compact design will make a lasting,
trouble-free connection.
G3DS
Nominal Rod
Diameter
Wire Range
Dimensions (IN)
Min
(MM2)
A
(Max)
Bolt
Part Number
IN
MM
Max
Min
Max
(MM2)
G3-DS
3/8
9.5
4 Str.
10 Sol.
21.6
5.2
G4-DS
1/2
12.7
2 Str.
10 Sol.
33.6
5.2
G5-DS
5/8
15.8
2 Str.
10 Sol.
33.6
5.2
Screw
Thread
Size
5/16"18UNC
3/8"16UNC
3/8"16UNC
B
C
D
E
Package
Quantity
11/16"
1/2"
27/64"
3/8"
100
49/64"
21/32"
33/64"
1/2"
100
29/32"
19/32"
21/32"
1/2"
50
www.ppc-online.com
35
A BELDEN BRAND
A BELDEN BRAND
Mechanical - Grounding Connectors and Clamps
Die Cast Zinc Water Pipe Clamp
•• Budget price clamps.
•• Made of die cast zinc alloy with zinc plated screws.
Conductor Range
Part Number
Water Pipe Size
Maximum
Minimum
Package
Quantity
1/2"-1"
#2 Stranded
#10 Solid
250
BJ1DS
Cast Bronze Water Pipe Clamp
•• For connecting grounding conductor to water pipe or copper tube.
•• Cast of high strength, highly conductive copper alloy.
•• Zinc plated crews plated for corrosion resistance.
•• UL listed.
Part
Number
Water
Pipe
Size
Maximum
Minimum
A
B
C
Package
Quantity
JDS
1/2"-1"
#2 Stranded
#10 Solid
2-3/4
2-11/32
23/32
100
Conductor Range
www.ppc-online.com
36
A BELDEN BRAND
Dimensions (IN)
Bonding &
Grounding
Hardware
Trailer Ground Clamp
•• 7/16” tin plated hex head bolt installs with terminal wrench or crescent wrench.
Square head bolt allows clamp to be installed with pliers.
•• Ground wire hole access from four directions minimizes having to bend ground wire.
•• Designed so ground wire may be installed on clamp prior to mounting the clamp on
metal frame, reducing installation time.
•• Beam and ground wire connection can be separately tightened without disconnect
integrity of ground circuit.
•• High strength copper alloy CDA956 (91% nominal) providing greater conductivity,
durability and excellent corrosion resistant characteristics without reliance on plating.
•• High strength anchoring bolt penetrates paint.
•• Bolts are electro-galvanized. Blade-type ground wire screw
is tin-plated.
Unit
Quantity
Standard
Package
Square Head - 15/16" - 18UNC Bolt
25
100
Slotted Screw Head - 5/16" - 24UNF
25
25
Part Number
Bolt Type
TGCDS
TGCHDS
www.ppc-online.com
37
A BELDEN BRAND
