2412 008A1000
2412 008A1000
    BELDEN
    BELDEN - 2412 008A1000 - UNSHIELDED MULTIPAIR CABLE 4PR 1000FT 300V GRAY
2412 008A1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2412 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cables For more Information please call 1-800-Belden1 General Description: CAT6+ (350MHz), 4-Pair, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 23 AWG Solid Bare Copper Conductors, Polyolefin Insulation, Tape Separator, Ripcord, PVC Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, POE, POE+,100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 23 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.223 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Separator Material: Patented Dielectric Tape Overall Nominal Diameter: 0.220 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: +5°C To +50°C Operating Temperature Range: 0°C To +75°C Bulk Cable Weight: 24 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 0.750 in. Min. Bend/Installation: 2.250 in. Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2412 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cables Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 ANSI Specification: ANSI/NEMA WC-66, ANSI/ICEA S-90-661, ANSI/UL 444 Other Specification: Third party verified to Category 6 Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Riser C(UL) Flame Test: FT4 CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 2413 Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 17.000 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 537 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 35.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 7.800 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3.000 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 2.000 75.3 75.3 73.3 73.3 20.000 4 3.700 66.3 66.3 62.6 62.6 23.000 Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2412 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cables 8 5.200 61.8 61.8 56.6 56.6 24.500 10 5.800 60.3 60.3 54.5 54.5 25.000 16 7.400 57.2 57.2 49.9 49.9 25.000 20 8.300 55.8 55.8 47.5 47.5 25.000 25 9.300 54.3 54.3 45.1 45.1 24.300 31.25 10.400 52.9 52.9 42.5 42.5 23.600 62.5 15.000 48.4 48.4 33.4 33.4 21.500 100 19.300 45.3 45.3 26.0 26.0 20.800 155 24.600 42.4 42.4 17.9 17.9 19.500 200 28.300 40.8 40.8 12.5 12.5 18.700 250 32.100 39.3 39.3 7.2 7.2 18.000 300 35.600 38.1 36.1 2.5 0.5 17.500 350 38.900 37.1 35.1 -1.8 -3.8 17.000 400 42.000 36.3 34.3 -5.7 -7.7 16.600 450 45.000 35.5 33.5 -9.5 -11.5 16.200 500 47.900 34.8 32.8 -13.1 -15.1 15.900 550 50.600 34.2 32.2 -16.4 -18.4 15.600 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ACRF (dB) Min. PSACRF (dB) 1 100 ± 15 102 ± 15 70.8 67.8 4 100 ± 15 100 ± 15 58.8 55.8 8 100 ± 15 100 ± 15 52.7 49.7 10 100 ± 15 100 ± 15 50.8 47.8 16 100 ± 15 100 ± 15 46.7 43.7 20 100 ± 15 100 ± 15 44.8 41.8 25 100 ± 15 100 ± 15 42.8 39.8 31.25 100 ± 15 100 ± 15 40.9 37.9 62.5 100 ± 15 100 ± 15 34.9 31.9 100 100 ± 15 100 ± 15 30.8 27.8 155 100 ± 22 100 ± 15 27.0 24.0 200 100 ± 22 100 ± 15 24.8 21.8 250 100 ± 32 100 ± 15 22.8 19.8 300 100 ± 32 100 ± 15 21.3 18.3 350 100 ± 32 100 ± 15 19.9 16.9 400 100 ± 32 100 ± 15 18.8 15.8 450 100 ± 32 100 ± 15 17.7 14.7 500 100 ± 32 100 ± 15 16.8 13.8 550 100 ± 32 100 ± 15 16.0 13.0 Notes (Overall) Notes: Jacket sequentially marked at 2 ft./1m intervals. Third party verified to ANSI/TIA-568-C.2, Category 6. Values above 350 MHz are for Engineering Informaton Only. In addition to the colors below, Pink is also available as a special, p/n 2412 012 U1000, or 2412 012 A1000. Reference (Overall) Previous Part Number: 24566415, 25066515T, 24566745, 24566745T, 24566745T+HU, 24566736T, 24566715, 24566715T, 25066885, 25066885T, 25066815T, 24566945, 24566945T, 24566945T+HU, 24566931, 24566931T, 24566931T+HU, 24566936T, 24566915, 24566915T, 24566915T+HU, 24566015, 24566015T, 24566P15, 24566P15T, 24566185, 24566185T, 24566185T+HU, 24566115T, 24566345, 24566345T, 24566345T+HU, 24566336T, 24566315, 24566315T, 24566315T+HU, 24566485, 24566485T, 24566415T, 24566415T Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 2412 002A1000 1,000 FT 27.000 LB RED C CAT6+ 4PR U/UTP CMR RIB 2412 003A1000 1,000 FT 27.000 LB ORANGE CAT6+ 4PR U/UTP CMR RIB 2412 003U1000 1,000 FT 24.000 LB ORANGE CAT6+ 4PR U/UTP CMR BOX 2412 004A1000 1,000 FT 27.000 LB YELLOW CAT6+ 4PR U/UTP CMR RIB 2412 004U1000 1,000 FT 24.000 LB YELLOW CAT6+ 4PR U/UTP CMR BOX 2412 0041000 1,000 FT 24.000 LB YELLOW CAT6+ 4PR U/UTP CMR REEL 2412 0042500 2,500 FT 60.000 LB YELLOW CAT6+ 4PR U/UTP CMR REEL 2412 005A1000 1,000 FT 27.000 LB GREEN, DARK CAT6+ 4PR U/UTP CMR RIB 2412 005U1000 1,000 FT 24.000 LB GREEN, DARK CAT6+ 4PR U/UTP CMR BOX 2412 0051000 1,000 FT 24.000 EA GREEN, DARK CAT6+ 4PR U/UTP CMR REEL 2412 006A1000 1,000 FT 27.000 LB BLUE, LIGHT CAT6+ 4PR U/UTP CMR RIB 2412 006U1000 1,000 FT 24.000 LB BLUE, LIGHT CAT6+ 4PR U/UTP CMR BOX 2412 0061000 1,000 FT 24.000 EA BLUE, LIGHT CAT6+ 4PR U/UTP CMR REEL 2412 0061400 1,400 FT 35.000 LB BLUE, LIGHT CAT6+ 4PR U/UTP CMR REEL Page 3 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2412 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cables 2412 0062500 2,500 FT 60.000 LB BLUE, LIGHT 2412 0065000 5,000 FT 125.000 LB BLUE, LIGHT CAT6+ 4PR U/UTP CMR REEL 2412 007A1000 1,000 FT 27.000 LB VIOLET CAT6+ 4PR U/UTP CMR RIB 2412 007U1000 1,000 FT 24.000 LB VIOLET CAT6+ 4PR U/UTP CMR BOX 2412 008A1000 1,000 FT 27.000 LB GRAY CAT6+ 4PR U/UTP CMR RIB 2412 008U1000 1,000 FT 24.000 LB GRAY CAT6+ 4PR U/UTP CMR BOX 2412 0081000 1,000 FT 24.000 EA GRAY CAT6+ 4PR U/UTP CMR REEL 2412 009A1000 1,000 FT 27.000 LB WHITE CAT6+ 4PR U/UTP CMR RIB 2412 009U1000 1,000 FT 24.000 LB WHITE CAT6+ 4PR U/UTP CMR BOX 2412 0091000 1,000 FT 24.000 EA WHITE CAT6+ 4PR U/UTP CMR REEL 2412 0092500 2,500 FT 60.000 LB WHITE 2412 0095000 5,000 FT 125.000 LB WHITE 2412 010A1000 1,000 FT 27.000 LB BLACK CAT6+ 4PR U/UTP CMR RIB 2412 010U1000 1,000 FT 24.000 LB BLACK CAT6+ 4PR U/UTP CMR BOX 2412 0101000 1,000 FT 24.000 EA BLACK CAT6+ 4PR U/UTP CMR REEL C CAT6+ 4PR U/UTP CMR REEL CAT6+ 4PR U/UTP CMR REEL C CAT6+ 4PR U/UTP CMR REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 6 Revision Date: 06-09-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 4 of 4 02-01-2017
2412 008A1000 价格&库存
很抱歉,暂时无法提供与“2412 008A1000”相匹配的价格&库存,您可以联系我们找货
