29502F 0101000
29502F 0101000
    BELDEN
    CABLE 4COND 12AWG BLACK 1000'
29502F 0101000 数据手册
Product: 29502F VFD 300% Gnd, 3C+G #12 Str TC, XLPE Ins+PVC Gnd, OS+TC Brd w/#12 TC Drain, Blk TPE Jkt, 600/1000V TC-ER 90C Dry/Wet 1000V Flexible Motor Supply Cable WTTC Product Description Belden 300% Ground Extra Flexible VFD, 3 Conductor 12AWG (7x24x34) Tinned Copper, XLPE Insulation M4 Color Code+PVC Insulated Ground, Overall Beldfoil®+Tinned Copper Braid(85%) Shield w/12AWG TC Drain, Black TPE Outer Jacket, 600/1000V TC-ER 90C Dry/Wet 1000V Flexible Motor Supply Cable 1000V WTTC 600V CIC TC SUN RES OIL RES II DIR BUR Technical Specifications Product Overview Suitable Applications: Variable Frequency Drives (VFD); AC Motor and Drive Systems, Exposure to high flex, motion, and abrasion, Hard to reach installation areas Construction Details Conductor Element Number of Element AWG Stranding Material Conductor(s) 3 12 7x24x34 TC - Tinned Copper Ground 12 7x24x34 TC - Tinned Copper 1 Insulation Element Material Thickness Color Code Conductor(s) XLPE - Cross-Linked Polyethylene (Thermoset) 0.046 in Black and Numbered Ground Green/Yellow Stripe PVC - Polyvinyl Chloride 0.046 in Outer Shield Material Shield Type Material Coverage Tape + Braid Tri-Laminate (Alum+Poly+Alum) + Tinned Copper (TC) 100% + 85% Outer Jacket Material Material Thickness Nom. Diameter Ripcord TPE - Thermoplastic Elastomer 0.073 in Cable Diameter (Nominal): 0.661 in Yes 0.661 in Electrical Characteristics Electricals Element Nom. Conductor DCR Nom. Capacitance Cond-to-Cond Conductor(s) 1.546 Ohm/1000ft 29 pF/ft Nom. Capacitance Cond-to-Shield 53 pF/ft Voltage UL Voltage Rating 1000 V (TC, WTTC, UL Flexible Motor Supply Cable), 600 V (C(UL) CIC TC) Mechanical Characteristics Temperature UL Rating Operating Nom. Capacitance Cond-to-Other (Conds + Shield) 53 pF/ft Characteristic Impedence 63 Ohm Nom. Velocity of Prop. 55% Max. Current 30 Amps per Conductor at 30ºC (per NEC) 90°C Dry, 90°C Wet -40°C To +90°C Bend Radius Stationary Min. Installation Min. Flexing Min. 3.3 in 5 in 5 in Max. Pull Tension: 458 lbs Bulk Cable Weight: 280 lbs/1000ft Standards and Compliance Environmental Suitability: Indoor, Outdoor, Sunlight Resistance, Oil Resistance, Burial Sustainability: CA Prop 65 Flammability / Fire Resistance: UL1685 UL Loading, FT4, FT4, 1202, 383 Vertical Tray Flame Test (70,000 BTU) NEC / UL Compliance: Article 336, TC-ER, WTTC, XHHW-2, UL Flexible Motor Supply Cable CEC / C(UL) Compliance: CIC, TC ICEA Compliance: S-95-658 European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU, EU Directive 2011/65/EU (ROHS II), EU Directive 2012/19/EU (WEEE) APAC Compliance: China RoHS II (GB/T 26572-2011) History Update and Revision: Revision Number: 0.315 Revision Date: 03-16-2021 © 2021 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
29502F 0101000 价格&库存
很抱歉,暂时无法提供与“29502F 0101000”相匹配的价格&库存,您可以联系我们找货
