Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
34416 Hook-up/Lead - UL AWM Style 3191
For more Information
please call
1-800-Belden1
General Description:
CSPE - Chlorosulphonated Polyethylene insulation has excellent heat resistance, color stability and
electrical properties and is recommended for Class 130(B) insulation systems.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
16
26x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
CSPE - Chlorosulphonated Polyethylene 0.045
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.155 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL AWM Style:
3191
UL Rating:
600 V, 105°C
CSA Rating:
600 V, 105°C
CSA Type:
CL1053
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
34416 002500
500 FT
10.500 LB
RED
F
#16 STR CSPE 105C 600V
34416 005500
500 FT
10.500 LB
GREEN, DARK
F
34416 0084000
4,000 FT
84.000 LB
GRAY
CIU
34416 010100
100 FT
2.700 LB
BLACK
34416 0104000
4,000 FT
80.000 LB
BLACK
CIU
34416 010500
500 FT
10.500 LB
BLACK
F
Notes:
C = CRATE REEL PUT-UP.
F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'
I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200'
U = TOPCOAT ADDERS ON STOCK SOLID COLORS. MINIMUM ORDER 10000' PER COLORCOMBINATION. (SEE TOPCOAT ADDER TABLE)
Page 1 of 2
08-26-2016
Revision Number: 1
Revision Date: 01-07-2011
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“34416 010500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 152+34.66376152+4.47480
- 304+30.98730304+4.00020
