4694R 0101000
4694R 0101000
    BELDEN
    BELDEN - 4694R 0101000 - Coaxial Cable, 12 GHz, 4K UHD Precision Video, RG6, 18 AWG, 75 ohm, 1000 ft...
4694R 0101000 数据手册
Part Number: 4694R 12 GHz Coax, 4K UHD Precision Video Coax, RG-6/U Type, 75 Ohm, 18 AWG solid, CMR Product Description 12 GHz Coax, 4K UHD Precision Video Cable, RG-6/U Type, 75 Ohm, 18 AWG solid .040" silver plated copper conductor, gas-injected foam HDPE insulation, Duofoil® bonded to core + tinned copper braid shield (95% coverage), CMR, PVC jacket. Technical Specifications Product Overview Environmental Space: Outdoor - Aerial Suitable Applications: SMPTE 2082-1 12 Gb/s UHDTV, SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080P Physical Characteristics (Overall) Conductor AWG Stranding 18 Solid Material Nominal Diameter No. of Coax SPC - Silver Plated Copper 0.040 in Conductor Size: 1 18 AWG Insulation Material Nominal Diameter Gas-injected FHDPE - Foam High Density Polyethylene 0.180 in Outer Shield Material Type Layer Material Material Trade Name Coverage [%] Tape 1 Aluminum/Polyester/Aluminum Bonded Duofoil® (Bonded to Dielectric) 100 % Braid 2 TC - Tinned Copper 95 % Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.274 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Outer Conductor DCR 6.4 Ohm/1000ft 2.8 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 15.9 pF/ft Shielding: Inductance Nominal Inductance 0.106 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Foil + Braid(s) Frequency [MHz] Minimum Return (RL) 5 MHz - 1600 MHz 23 dB 1600 MHz - 4500 MHz 21 dB 4500 MHz - 12000 MHz 15 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.23 dB/100ft 3.58 MHz 0.44 dB/100ft 5 MHz 0.51 dB/100ft 6 MHz 0.56 dB/100ft 7 MHz 0.59 dB/100ft 10 MHz 0.70 dB/100ft 12 MHz 0.75 dB/100ft 25 MHz 1.04 dB/100ft 55 MHz 1.45 dB/100ft 67.5 MHz 1.58 dB/100ft 71.5 MHz 1.62 dB/100ft 88.5 MHz 1.78 dB/100ft 100 MHz 1.89 dB/100ft 135 MHz 2.10 dB/100ft 143 MHz 2.16 dB/100ft 180 MHz 2.44 dB/100ft 270 MHz 2.97 dB/100ft 360 MHz 3.45 dB/100ft 540 MHz 4.30 dB/100ft 720 MHz 5.00 dB/100ft 750 MHz 5.10 dB/100ft 1000 MHz 5.90 dB/100ft 1500 MHz 7.30 dB/100ft 2000 MHz 8.50 dB/100ft 2250 MHz 9.10 dB/100ft 3000 MHz 10.6 dB/100ft 4500 MHz 13.2 dB/100ft 6000 MHz 15.5 dB/100ft 12000 MHz 23.0 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.20 ns/ft 84.5 % Voltage UL Voltage Rating 300 V RMS Electrical Characteristics Notes: Return Loss: Fixed bridge and termination Temperature Range Operating Temp Range: -30°C To +75°C Mechanical Characteristics UV Resistance: Yes Bulk Cable Weight: 41 lbs/1000ft Max Recommended Pulling Tension: 69 lbs Min Bend Radius/Minor Axis: 2.75 in Standards NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG RG Type: 6/U Type Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes Suitability Suitability - Aerial: Yes - Black only, when supported by messenger wire Suitability - Burial: No Suitability - Hazardous Locations: No Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black only Flammability, LS0H, Toxicity Testing UL Flammability: UL1666 Vertical Shaft CSA Flammability: FT4 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # Color 4694R 0091000 4694R 0101000 Black 4694R 0105000 Black 4694R 0061000 Blue, Light 4694R N3U1000 Mil Green 4694R 0031000 Orange 4694R 0071000 Purple 4694R 0021000 Red 4694R 0041000 Yellow © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
4694R 0101000 价格&库存
很抱歉,暂时无法提供与“4694R 0101000”相匹配的价格&库存,您可以联系我们找货
4694R 0101000
  • 1+16113.88674
库存:305
