4812 009A1000
4812 009A1000
    BELDEN
    CAT6E+ 4PR U/UTP CMR RIB
4812 009A1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 4812 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT6+ (600MHz), 4-Pair, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 23 AWG Solid Bare Copper Conductors, Polyolefin Insulation, X Spline, Ripcord, PVC Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, POE, POE+,100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, Noisy Environments Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 23 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.255 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Separator Material: Patented X-Spline Center Member Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: +5°C To +50°C Operating Temperature Range: -20°C To +60°C Bulk Cable Weight: 31 lbs/1000 ft. Max. Recommended Pulling Tension: 45 lbs. Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 2.500 in. Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 4812 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes Other Standards: ISO/IEC 11801 ed 2.1 (2008) Class E EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 Other Specification: UL Verified to Category 6 Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Riser C(UL) Flame Test: FT4 CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Sunlight Resistance: No Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 4813 Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15.500 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 68.000 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 25.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 6.600 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 4812 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cable Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 0.772 1.700 83 82 81.3 80.3 1 1.900 81.3 80.3 79.4 78.4 20.000 4 3.500 72.3 71.3 68.8 67.8 23.000 8 4.900 67.8 66.8 62.8 61.8 24.500 10 5.500 66.3 65.3 60.8 59.8 25.000 16 7.000 63.2 62.2 56.3 55.3 25.000 20 7.800 61.8 60.8 54.0 53.0 25.000 25 8.700 60.3 59.3 51.6 50.6 25.000 31.25 9.800 58.9 57.9 49.1 48.1 24.300 62.5 14.100 54.4 53.4 40.3 39.3 22.200 100 18.000 51.3 50.3 33.3 32.3 20.800 155 22.700 48.4 47.4 24.8 23.8 19.500 200 26.200 46.8 45.8 20.6 19.6 18.700 250 29.600 45.3 44.3 15.8 14.8 18.000 300 32.700 44.1 43.1 11.4 10.4 17.500 350 35.600 43.1 42.1 7.5 6.5 17.000 400 38.400 42.3 41.3 3.9 2.9 16.600 450 41.000 41.5 40.5 0.5 -0.5 16.200 500 43.600 40.8 39.8 -2.8 -3.8 15.900 550 46.000 40.2 39.2 -5.8 -6.8 12.900 600 48.400 39.6 38.6 -8.7 -9.7 12.700 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ACRF (dB) Min. PSACRF (dB) 0.772 102 ± 15 77.0 75.0 1 100 ± 15 100 ± 15 74.8 72.8 4 100 ± 15 100 ± 15 62.8 60.8 8 100 ± 15 100 ± 15 56.7 54.7 10 100 ± 15 100 ± 15 54.8 52.8 16 100 ± 15 100 ± 15 50.7 48.7 20 100 ± 15 100 ± 15 48.8 46.8 25 100 ± 15 100 ± 15 46.8 44.8 31.25 100 ± 15 100 ± 15 44.9 42.9 62.5 100 ± 15 100 ± 15 38.9 36.9 100 100 ± 15 100 ± 15 34.8 32.8 155 100 ± 22 100 ± 15 31.0 29.0 200 100 ± 22 100 ± 15 28.8 26.8 250 100 ± 32 100 ± 15 26.8 24.8 300 100 ± 32 100 ± 15 25.3 23.3 350 100 ± 32 100 ± 15 23.9 21.9 400 100 ± 32 100 ± 15 22.8 20.8 450 100 ± 32 100 ± 15 21.7 19.7 500 100 ± 32 100 ± 15 20.8 18.8 550 100 ± 32 100 ± 15 20.0 18.0 600 100 ± 32 100 ± 15 19.2 17.2 Premise Cable Electrical Table 4: Frequency (MHz) Min. TCL (dB) Min. ELTCTL (dB) 0.772 40.000 37.200 1.000 40.000 35.000 4.000 40.000 23.000 8.000 40.000 16.900 10.000 40.000 15.000 16.000 38.000 10.900 20.000 37.000 9.000 25.000 36.000 7.000 31.250 35.100 62.500 32.000 100.000 30.000 155.000 28.100 200.000 27.000 250.000 26.000 Notes (Overall) Notes: Belden IBDN. Jacket sequentially marked at 2 ft./1m intervals. Values above 600 MHz are for Engineering Informaton Only. Third party verified to ANSI/TIA-568-C.2, Page 3 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 4812 Multi-Conductor - Enhanced Category 6 Nonbonded-Pair Cable Notes: Belden IBDN. Jacket sequentially marked at 2 ft./1m intervals. Values above 600 MHz are for Engineering Informaton Only. Third party verified to ANSI/TIA-568-C.2, Category 6. Reference (Overall) Previous Part Number: 24586685, 24586685+US, 24586785, 24586785+US, 25086885, 25086885+US, 24586985, 24586985+US, 24586956, 24586956+US, 24586915, 24586915+US, 24586185, 24586385, 24586385+US, 24586315, 24586315+US, 24586451+US Put Ups and Colors: Item # Putup Ship Weight Color 4812 0021000 1,000 FT 36.000 LB RED CAT6E+ 4PR U/UTP CMR REEL 4812 0041000 1,000 FT 36.000 LB YELLOW CAT6E+ 4PR U/UTP CMR REEL 4812 0051000 1,000 FT 36.000 LB GREEN, DARK CAT6E+ 4PR U/UTP CMR REEL 4812 006A1000 1,000 FT 36.000 LB BLUE, LIGHT CAT6E+ 4PR U/UTP CMR RIB 4812 0061000 1,000 FT 36.000 LB BLUE, LIGHT CAT6E+ 4PR U/UTP CMR REEL 4812 0062500 2,500 FT 82.500 LB BLUE, LIGHT CAT6E+ 4PR U/UTP CMR REEL 4812 0081000 1,000 FT 36.000 LB GRAY CAT6E+ 4PR U/UTP CMR REEL 4812 009A1000 1,000 FT 36.000 LB WHITE CAT6E+ 4PR U/UTP CMR RIB 4812 0091000 1,000 FT 36.000 LB WHITE CAT6E+ 4PR U/UTP CMR REEL 4812 0103000 3,000 FT 102.000 LB BLACK CAT6E+ 4PR U/UTP CMR REEL Revision Number: 13 Notes Item Desc Revision Date: 06-09-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 4 of 4 02-01-2017
4812 009A1000 价格&库存
很抱歉,暂时无法提供与“4812 009A1000”相匹配的价格&库存,您可以联系我们找货
