Part Number: 4855ANH
12 GHz Coax, 4K UHD Precision Video Coax, RG-59 Mini, 75 Ohm, 23 AWG
Solid
Product Description
12 GHz Coax, 4K UHD Precision Video Cable, RG-59 Mini, 75 Ohm, 23 AWG solid .023" silver plated copper conductor, gas-injected foam HDPE insulation,
Duofoil® bonded to the core + tinned copper braid shield (95% coverage), LSZH jacket.
Technical Specifications
Product Overview
Environmental Space:
Indoor - Euroclass Dca
Suitable Applications:
SMPTE 2082-1 12 Gb/s UHDTV, SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080P
Physical Characteristics (Overall)
Conductor
AWG Stranding
23
Solid
Material
Nominal Diameter No. of Coax
SPC - Silver Plated Copper 0.023 in
Conductor Size:
1
23 AWG
Insulation
Material
Nominal Diameter
Gas-injected FHDPE - Foam High Density Polyethylene 0.102 in
Outer Shield Material
Type Layer
Material
Material Trade Name
Coverage [%]
Tape 1
Aluminum / Polyester / Aluminum Bonded Duofoil® (Bonded to Dielectric) 100.0 %
Braid 2
TC - Tinned Copper
Outer Jacket Material
Material
Nominal Diameter
LSZH / FRNC 0.159 in
Electrical Characteristics
Conductor DCR
Nominal Conductor DCR Outer Conductor DCR
19.7 Ohm/1000ft
3.9 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Shield
16.3 pF/ft
Inductance
Nominal Inductance
0.107 µH/ft
Impedance
Nominal Characteristic Impedance
75 Ohm
95.0 %
Return Loss (RL)
Frequency [MHz]
Minimum Return (RL)
5 MHz - 1600 MHz
23 dB
1600 MHz - 4500 MHz
21 dB
4500 MHz - 12000 MHz 15 dB
High Frequency (Nominal/Typical)
Frequency [MHz] Nom. Insertion Loss
1 MHz MHz
0.39 dB/100ft
3.58 MHz MHz
0.78 dB/100ft
5 MHz MHz
0.92 dB/100ft
6 MHz MHz
1 dB/100ft
7 MHz MHz
1.08 dB/100ft
10 MHz MHz
1.2 dB/100ft
12 MHz MHz
1.3 dB/100ft
25 MHz MHz
1.8 dB/100ft
55 MHz MHz
2.6 dB/100ft
67.5 MHz MHz
2.83 dB/100ft
71.5 MHz MHz
2.93 dB/100ft
88.5 MHz MHz
3.22 dB/100ft
100 MHz MHz
3.39 dB/100ft
135 MHz
3.84 dB/100ft
143 MHz
4.00 dB/100ft
180 MHz
4.41 dB/100ft
270 MHz
5.44 dB/100ft
360 MHz
6.34 dB/100ft
540 MHz
7.85 dB/100ft
720 MHz
9.09 dB/100ft
750 MHz
9.28 dB/100ft
1000 MHz
10.8 dB/100ft
1500 MHz
13.2 dB/100ft
2000 MHz
15.3 dB/100ft
2250 MHz
16.3 dB/100ft
3000 MHz
19.0 dB/100ft
4500 MHz
23.6 dB/100ft
6000 MHz
27.7 dB/100ft
12000 MHz
41.2 dB/100ft
Delay
Nominal Delay Nominal Velocity of Propagation (VP) [%]
1.24 ns/ft
82.0 %
Voltage
Non-UL Voltage Rating
300 V RMS
Electrical Characteristics Notes:
Return Loss: Fixed bridge and termination
Other Electrical Characteristic 2:
Percent test
Temperature Range
UL Temp Rating:
75°C
Operating Temp Range:
-30°C To +75°C
Mechanical Characteristics
UV Resistance:
Yes
Bulk Cable Weight:
17 lbs/1000ft
Max Recommended Pulling Tension:
40 lbs
Min Bend Radius/Minor Axis:
1.6 in
Standards
CPR Euroclass:
Dca
RG Type:
Mini 59/U Type
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01
CA Prop 65 (CJ for Wire & Cable):
Yes
Suitability
Suitability - Aerial:
Yes - Black only, when supported by messenger wire
Suitability - Burial:
No
Suitability - Hazardous Locations:
No
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes - Black only
Plenum/Non-Plenum
Plenum (Y/N):
No
Part Number
Variants
Item #
Color
UPC
Length
4855ANH G751000 Aqua
612825443353 305 m
4855ANH G751640 Aqua
612825443407 500 m
4855ANH G753280 Aqua
612825443452 1,000 m
305 m
500 m
1,000 m
4855ANH 0101000
Black
612825443391 305 m
4855ANH 0101640
Black
612825443445 500 m
4855ANH 0103280
Black
612825443490 1,000 m
4855ANH 0101000
Black
305 m
4855ANH 0101640
Black
500 m
4855ANH 0103280
Black
4855ANH 0061000
Blue
612825443377 305 m
4855ANH 0061640
Blue
612825443421 500 m
4855ANH 0063280
Blue
612825443476 1,000 m
4855ANH 0061000
Blue
305 m
4855ANH 0061640
Blue
500 m
4855ANH 0063280
Blue
1,000 m
1,000 m
4855ANH N3U1000 Green 612825443360 305 m
4855ANH N3U1640 Green 612825443414 500 m
4855ANH N3U3280 Green 612825443469 1,000 m
305 m
500 m
1,000 m
4855ANH 0071000
Purple 612825443384 305 m
4855ANH 0071640
Purple 612825443438 500 m
4855ANH 0071000
Purple
305 m
4855ANH 0071640
Purple
500 m
4855ANH 0073280
Purple
1,000 m
Product Notes
Notes:
History
Print legend includes sequential footage marks.
Update and Revision:
Revision Number: 0.16 Revision Date: 06-18-2019
© 2019 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“4855ANH 0101000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+17.346691000+2.24846
