Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
49403 Molded Cable Assemblies - Modular Keyboard Assembly
For more Information
please call
1-800-Belden1
Description:
6-position modular retractile, used to rapidly interconnect electronic computers and business machines, foil
shield, polypropylene insulation, polyurethane jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material Dia. (mm)
5
26
19x38
TC - Tinned Copper 12.954
Number of Pins:
6
Insulation
Insulation Material:
Insulation Material Wall Thickness (mm)
PP - Polypropylene 0.1524
Connector Characteristics
Connector Characteristics - First End # of
Connector Contacts/positions:
6
Connector Characteristics - First End Connector Modular
Type:
Connector Characteristics - Second End # of
6
Connector Type:
Modular
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
26
19x38
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Outer Jacket Material Nom. Wall Thickness (mm)
PUR - Polyurethane
0.762
Overall Cabling
Overall Nominal Diameter:
2.464 x 2.464 mm
Assembly Dimensional
Assembly Dimensional For Retractile Coil Body
Length (extended):
67.5
Assembly Dimensional for Retractile Coil Body
Length (relaxed):
15
Tail Length
1st End Tail Length:
1.5 +/- .5
Page 1 of 3
10-27-2008
2nd End Tail Length:
1.5 +/- .5
Wiring
Wiring:
Straight Wired
Wiring Diagram Color Code Chart:
Number Color
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Drain Wire
Mechanical Characteristics (Overall)
UL Temperature Rating:
60°C (UL AWM Style 20197)
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
AWM Specification:
UL Style 20197 (30 V 60°C) (cable only)
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Max. Operating Voltage - UL:
Voltage
30V (UL AWM Style 20197)
Notes (Overall)
Notes: Positive locking latch prevents connector from vibrating loose. Polarized connector prevents improper insertion. No tools
required for installation. A longitudinal aluminum/polyester shield protects against ESD and EMI.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
49403 010S2
1 EA
0.109 KG
BLACK
Revision Number: 1
Notes
Item Desc
6 POS MOD RET CABLE RI47867
Revision Date: 09-19-2008
© 2008 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications
described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not
ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the
compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and
Page 2 of 3
10-27-2008
the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide
for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not
to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Page 3 of 3
10-27-2008
很抱歉,暂时无法提供与“49403 010S2”相匹配的价格&库存,您可以联系我们找货
