5582UE U4FC500
5582UE U4FC500
    BELDEN
    CBL 4COND 22AWG FRPVC
5582UE U4FC500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5582UE Multi-Conductor - Commercial Applications For more Information please call 1-800-Belden1 General Description: Security & Alarm Cable, Riser-CMR, 4-22 AWG solid bare copper conductors with polyolefin insulation, PVC jacket with ripcord Usage (Overall) Suitable Applications: Security Systems, Intercom/PA Systems, Sound/Audio Systems, Power Limited Controls, and Single Line Telephone. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 22 Solid BC - Bare Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material PP - Polypropylene Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.017 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 Red 3 Yellow 4 Green Overall Nominal Diameter: 0.130 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 14.300 lbs/1000 ft. Max. Recommended Pulling Tension: 31.200 lbs. Min. Bend Radius/Minor Axis: 1.400 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR NEC Articles: 800 CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5582UE Multi-Conductor - Commercial Applications EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.7 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.2 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 5582UE U4FC500 500 FT 6.500 LB BEIGE U4F Notes Item Desc 5582UE U4FU500 500 FT 7.500 LB BEIGE U4F 5582UE U4F1000 1,000 FT 14.000 LB BEIGE U4F 5582UE 008U1000 1,000 FT 14.000 LB GRAY 4 #22 PP FRPVC 5582UE 0081000 1,000 FT 14.000 LB GRAY 4 #22 PP FRPVC 5582UE 009C500 500 FT 6.500 LB WHITE 4 #22 PP FRPVC 5582UE 009U1000 1,000 FT 14.000 LB WHITE 4 #22 PP FRPVC 4 #22 PP FRPVC 4 #22 PP FRPVC C 4 #22 PP FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 03-11-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
5582UE U4FC500 价格&库存
很抱歉,暂时无法提供与“5582UE U4FC500”相匹配的价格&库存,您可以联系我们找货
