6501FE 8771000
6501FE 8771000
    BELDEN
    CBL 3COND 22AWG FLRST SHLD
6501FE 8771000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 6501FE Multi-Conductor - Commercial Audio Systems For more Information please call 1-800-Belden1 General Description: Security & Commercial Audio Cable, Plenum-CMP, 3-22 AWG stranded bare copper conductors with Flamarrest® insulation, Beldfoil® shield and Flamarrest® jacket with ripcord Usage (Overall) Suitable Applications: Intercom/PA Systems and Sound/Audio Systems. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 3 22 7x30 BC - Bare Copper Total Number of Conductors: 3 Insulation Insulation Material: Insulation Trade Name Insulation Material Flamarrest® Wall Thickness (in.) LS PVC - Low Smoke Polyvinyl Chloride 0.009 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 (7x32) TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® Nom. Wall Thickness (in.) LS PVC - Low Smoke Polyvinyl Chloride .015 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 Red 3 White Overall Nominal Diameter: 0.135 in. Mechanical Characteristics (Overall) Operating Temperature Range: 0°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 14.700 lbs/1000 ft. Max. Recommended Pulling Tension: 32.800 lbs. Min. Bend Radius/Minor Axis: 1.400 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP NEC Articles: 800 CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 6501FE Multi-Conductor - Commercial Audio Systems EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 C(UL) Flame Test: FT6 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 5501FE Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 55 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 99 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 16.1 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.3 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature Rise 2.8 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 6501FE 877U1000 1,000 FT 16.000 LB NATURAL 6501FE 8771000 1,000 FT 16.000 LB NATURAL Notes Item Desc 3 #22 FLRST FS FLRST C 3 #22 FLRST FS FLRST Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 01-20-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
6501FE 8771000 价格&库存
很抱歉,暂时无法提供与“6501FE 8771000”相匹配的价格&库存,您可以联系我们找货
