7804R B593280
7804R B593280
    BELDEN
    COMPOSITE CAMERA CABLE 1=3280
7804R B593280 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7804R Composite - SMPTE 311M HDTV Cable For more Information please call 1-800-Belden1 General Description: Industry Standard SMPTE 311M Cable, 4 power conductors, 2 SM fibers w/24 and 20 AWG stranded (7x32 and 19x32) TC conductors, PVC insulation, TC braid shield (95% coverage), Belflex® jacket. Usage (Overall) Suitable Applications: SMPTE 311M Camera Cable Multi Conductor Physical Characteristics Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (in.) 2 24 7x32 TC - Tinned Copper 0.024 4 20 19x32 TC - Tinned Copper 0.037 Insulation Insulation Material: Insulation Material Dia. (in.) AWG PVC - Polyvinyl Chloride 0.063 20 PVC - Polyvinyl Chloride 0.050 24 Insulation Color Code Chart: Number Color Description 1 Red 24 AWG 2 Gray 24 AWG 3 White 20 AWG 4 Black 20 AWG 5 White/Black 20 AWG 6 Black/White 20 AWG Electrical Characteristics Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) 24 AWG 23.300 20 AWG 8.800 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.500 Fiber Physical Characteristics Fiber Type: Non-Dispersion Shifted, Single Mode/125/900 Micron Number of Fibers: 2 Mode Field Diameter @ 1310nm: 9.5 +/-1 microns Clad Diameter: 125 microns Core-clad Concentricity Error: < to 1 micron Primary Coating Material: Acrylate Buffer Tube Diameter: 900 microns Buffer Tube Material: PVC - Polyvinyl Chloride Buffer Tube Color Code Chart: Number Color 1 Blue 2 Yellow Optical Characteristics Maximum Attenuation @ 1310nm: 0.8 dB/km Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7804R Composite - SMPTE 311M HDTV Cable Maximum Attenuation @ 1310nm: 0.8 dB/km Physical Characteristics (Overall) Conductor Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Belflex® PVC Blend - Polyvinyl Chloride Blend Strength Member Overall Strength Member Diameter: .089 Strength Member Material: 302 Stainless Steel Overall Cable Overall Nominal Diameter: 0.362 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 80 lbs/1000 ft. Max. Recommended Pulling Tension: 450 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Flex Cycle Rating: UL1581, Sec. 1582: 15,000 Cycles @ 3.6 Crush Resistance: Compression, FOTP-41: 397 lbs. Impact Resistance: FOTP-25: 20 Cycles @ 1.32 lbs. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: SMPTE 311 Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suggested Connectors: SMPTE 304M Connectors Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 7804P Electrical Characteristics (Overall) Other Electrical Characteristic 1: Auxillary Conductors: DC Loop Resistance - 30 Ohms/km nom. (9.1 Ohms/1000ft.) Min. Insullation Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7804R Composite - SMPTE 311M HDTV Cable Other Electrical Characteristic 1: Auxillary Conductors: DC Loop Resistance - 30 Ohms/km nom. (9.1 Ohms/1000ft.) Min. Insullation Resistance - 10, 000 Megaohms x km Dielectric Strength - 1750 V RMS. Signal Conductors: DC Loop Resistance - 150 Ohms/km nom. (45.7 Ohms/1000 ft.) Insulation Resistance - 10, 000 Megaohms/1000 ft. Dielectric Strength: 1750 V RMS Notes (Overall) Notes: Bend Radius is based upon (FOTP-37) @ 20°C. Plenum version and other conductor counts/diameters available by special order. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7804R B591000 1,000 FT 96.000 LB BLACK, MATTE C COMPOSITE CAMERA CABLE 7804R B591640 1,640 FT 152.520 LB BLACK, MATTE C COMPOSITE CAMERA CABLE 7804R B593280 3,280 FT 314.880 LB BLACK, MATTE C COMPOSITE CAMERA CABLE 7804R B59500 500 FT 47.500 LB BLACK, MATTE C COMPOSITE CAMERA CABLE Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 03-27-2015 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
7804R B593280 价格&库存
很抱歉,暂时无法提供与“7804R B593280”相匹配的价格&库存,您可以联系我们找货
