7805 010500
7805 010500
    BELDEN
    BELDEN - 7805 010500 - CABLE, COAXIAL, RG-174, 25AWG, 50 OHM, 500FT, BLACK
7805 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7805 Coax - RG-174 Type For more Information please call 1-800-Belden1 General Description: RG-174 type, 25 AWG solid .018" bare copper conductor, solid polyethylene insulation, Beldfoil® + tinned copper braid shield (90% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 25 Solid BC - Bare Copper .018 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene .061 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Braid TC - Tinned Copper 90 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.110 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 9 lbs/1000 ft. Max. Recommended Pulling Tension: 16 lbs. Min. Bend Radius/Minor Axis: 1.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 174/U Series Type: RF 100 Suitability Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7805 Coax - RG-174 Type Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .077 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 31.2 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 32.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.1 Maximum VSWR: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR 5 6000 1.25:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5.000 1.500 10.000 2.200 30.000 3.800 50.000 4.900 150.000 8.600 220.000 10.400 450.000 15.200 900.000 22.000 1500.000 28.700 1800.000 31.700 2000.000 33.400 2500.000 37.800 3000.000 42.000 3500.000 45.400 4500.000 52.300 5800.000 60.900 6000.000 62.000 Nom. Power Rating: Start Freq. (MHz) Rating (W) 30 216 50 154 150 74 220 57 450 34 900 21 1500 14 1800 13 2000 12 2500 10 3000 9 3500 8 4500 7 5800 5 6000 5 Max. Operating Voltage - Non-UL: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7805 Coax - RG-174 Type Voltage 1100 V RMS Notes (Overall) Notes: 100% Sweep tested. 6 GHz. Max. Belden® The Wire in Wireless®. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7805 010100 100 FT 1.700 LB BLACK E RF100 WIRELESS 50 OHM COAX PVC 7805 0101000 1,000 FT 10.000 LB BLACK RF100 WIRELESS 50 OHM COAX PVC 7805 010500 500 FT 5.500 LB BLACK RF100 WIRELESS 50 OHM COAX PVC Notes: E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25' Revision Number: 3 Revision Date: 07-19-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
7805 010500 价格&库存
很抱歉,暂时无法提供与“7805 010500”相匹配的价格&库存,您可以联系我们找货
  • 500+13.51614500+1.74695
  • 1000+12.844191000+1.66010
  • 1500+12.463771500+1.61094
  • 2500+11.997112500+1.55062
  • 3500+11.697353500+1.51188
  • 5000+11.385985000+1.47163
