72002PU
72002PU
    BELDEN
    BELDEN - 72002PU - Networking Cable, Screened, Cat5e, 26 AWG, 1000 ft, 304.8 m
72002PU 数据手册
Industrial Ethernet Cables SF/UTP Cat 5e – 2 Pair Cables A range of shielded copper cables for use in industrial Ethernet networks, designed to withstand the entire spectrum of environmental and mechanical hazards, from temperature extremes and sunlight, to solvents, oils, chemicals and moisture. Ordering Information Belden European Item Numbers Jacket Material PVC Premium FRNC PUR (Halogen Free) Performance Cat 5e Cat 5e Cat 5e Number of Pairs 2 Pairs 2 Pairs 2 Pairs Stationary Application 72001E 72001NH 72001PU Flexible Application 72002E 72002NH 72002PU Applications • • • • Industrial environments where IP67 may be required Transmission of data in industrial applications via the ethernet protocol Stationary applications, where there is no movement after installation Flexible applications, subject to occasional movement or vibration after installation Features & Benefits • Choice of PVC, Premium FRNC or PUR cable jacket for specific application requirements in the harsh industrial environment • High shield coverage to maintain signal integrity in the industrial ‘noisy’ environment • Oil resistant • Chemical & solvent resistant • Temperature resistant • Abrasion resistant • Excellent mechanical resistance • Weld-splatter resistant PUR cable jacket available on request • IP67 rated • UV resistant • Black cable jacket Construction & Dimensions Mechanical Data – Stationary Application Conductor (24AWG/1 – Solid Bare Copper) 2 Twisted, Polypropylene Insulated Conductors - Pair 1 = White / Blue - Pair 2 = White / Orange Foil Shield – Laminated Aluminium / Polyester Braid Shield – Tinned Copper Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) Sheath Colour 72001E 24AWG/1 1.10mm >80% PVC 6.00mm Black 72001NH 24AWG/1 1.10mm >80% FRNC 6.00mm Black 72001PU 24AWG/1 1.10mm >80% PUR 6.00mm Black Part Number Mechanical Data – Flexible Application Conductor (26AWG/7 – 7x0.16mm Stranded Tinned Copper) 2 Twisted, Polypropylene Insulated Conductors - Pair 1 = White / Blue - Pair 2 = White / Orange Foil Shield – Laminated Aluminium / Polyester Braid Shield – Tinned Copper Part Number Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) Sheath Colour 72002E 26AWG/7 0.98mm >80% PVC 6.00mm Black 72002NH 26AWG/7 0.98mm >80% FRNC 6.00mm Black 72002PU 26AWG/7 0.98mm >80% PUR 6.60mm Black 2 Standards • ISO/IEC 11801 2 • ISO/IEC 24702 • EN 50173-1 • TIA/EIA-568-B.2 nd Edition Electrical Properties 450V A.C. / 300V D.C. 68% 100 +/- 15 Ohm Max Operating Voltage UL Velocity of Propagation @ 4 – 100 MHz Impedance @ 1 – 100 MHz 72001E / 72001NH / 72001PU (AWG24) Frequency Frequency (MHz) 1 4 10 16 20 25 31.25 62.5 100 Insertion Loss (Max) (dB/100m) 2.0 4.1 6.5 8.2 9.3 10.4 11.7 17.0 22.0 NEXT (dB) 65.3 56.3 50.3 47.2 45.8 44.3 42.9 38.3 35.3 ELFEXT (dB/100m) 63.8 51.7 43.8 39.7 37.7 35.8 33.9 27.8 23.8 RETURN LOSS (dB) 20.0 23.0 25.0 25.0 25.0 24.3 23.6 21.5 20.1 NEXT (dB) 65.3 56.3 50.3 47.2 45.8 44.3 42.9 38.3 35.3 ELFEXT (dB/100m) 63.8 51.7 43.8 39.7 37.7 35.8 33.9 27.8 23.8 RETURN LOSS (dB) 20.0 23.0 25.0 25.0 25.0 24.3 23.6 21.5 20.1 72001E / 72002NH / 72002PU (AWG26) Frequency (MHz) 1 4 10 16 20 25 31.25 62.5 100 Insertion Loss (Max) (dB/100m) 3.2 6.0 9.5 12.1 13.6 15.3 17.1 24.8 32.0 3 Mechanical, Physical and/or Environmental Characteristics Flame Resistance Oil Resistance Bending Radius / Setting Radius Halogen Free Maximum Pulling Tension Temperature Range - Installation Temperature Range - Operating IEC 60332-1 IEC 60811-2-1 10 x Diameter / 5 x Diameter IEC 60754-1 / IEC 60754-2 (FRNC and PUR Cable) Jacket) 40N -5 oC to +50 oC -40 oC to +80 oC Version 03 (07/10) 4
72002PU 价格&库存
很抱歉,暂时无法提供与“72002PU”相匹配的价格&库存,您可以联系我们找货
